RTEMS 5.2-rc1
#include "chip.h"Macros | |
| #define | USE_SPI_DMA |
| #define | DMA_SPI_LLI 2 |
| uint32_t | SPID_Configure (Spid *pSpid, Spi *pSpiHw, uint8_t spiId, uint32_t spiMode, sXdmad *pXdmad) |
| Initializes the Spid structure and the corresponding SPI & DMA hardware. select value. The driver will uses DMA channel 0 for RX and DMA channel 1 for TX. The DMA channels are freed automatically when no SPI command processing. More... | |
| void | SPID_ConfigureCS (Spid *pSpid, uint32_t dwCS, uint32_t dwCsr) |
| Configures the parameters for the device corresponding to the cs value. More... | |
| uint32_t | SPID_SendCommand (Spid *pSpid, SpidCmd *pCommand) |
| Starts a SPI master transfer. This is a non blocking function. It will return as soon as the transfer is started. More... | |
| uint32_t | SPID_IsBusy (const Spid *pSpid) |
| Check if the SPI driver is busy. More... | |
Implementation for the SPI Flash with xDMA driver.
| #define DMA_SPI_LLI 2 |
xDMA Link List size for SPI transmission
| #define USE_SPI_DMA |
xDMA support
| uint32_t SPID_Configure | ( | Spid * | pSpid, |
| Spi * | pSpiHw, | ||
| uint8_t | spiId, | ||
| uint32_t | spiMode, | ||
| sXdmad * | pXdmad | ||
| pSpid | Pointer to a Spid instance. |
| pSpiHw | Associated SPI peripheral. |
| spiId | SPI peripheral identifier. |
| pDmad | Pointer to a Dmad instance. |
| void SPID_ConfigureCS | ( | Spid * | pSpid, |
| uint32_t | dwCS, | ||
| uint32_t | dwCsr | ||
| cs | number corresponding to the SPI chip select. |
| csr | SPI_CSR value to setup. |
| uint32_t SPID_IsBusy | ( | const Spid * | pSpid | ) |
| pCommand | Pointer to the SPI command to execute. |
