RTEMS 5.2-rc1
The generic libchip serial driver interface. More...
| struct | _console_fns |
| struct | _console_flow |
| struct | _console_tbl |
| struct | _console_data |
Typedefs | |
| typedef uint8_t(* | getRegister_f) (uintptr_t port, uint8_t reg) |
| typedef void(* | setRegister_f) (uintptr_t port, uint8_t reg, uint8_t value) |
| typedef uint8_t(* | getData_f) (uintptr_t port) |
| typedef void(* | setData_f) (uintptr_t port, uint8_t value) |
| typedef struct _console_fns | console_fns |
| typedef struct _console_flow | console_flow |
| typedef struct _console_tbl | console_tbl |
| typedef struct _console_data | console_data |
Enumerations | |
| enum | console_devs { SERIAL_MC68681 , SERIAL_NS16550 , SERIAL_NS16550_WITH_FDR , SERIAL_Z85C30 , SERIAL_CUSTOM } |
| void | bsp_console_select (void) |
| Selects the minor number of the console device. More... | |
| console_tbl ** | Console_Port_Tbl |
| unsigned long | Console_Port_Count |
| console_tbl | Console_Configuration_Ports [] |
| unsigned long | Console_Configuration_Count |
| console_data * | Console_Port_Data |
| rtems_device_minor_number | Console_Port_Minor |
| typedef struct _console_data console_data |
This type defination provides data for the console port.
| typedef struct _console_tbl console_tbl |
This type defination provides an structure that is used to uniquely identify a specific serial port.
| getData_f |
This type function provides a hook for the bsp specific method that gets data from the specified port.
| setData_f |
This type function provides a hook for the bsp specific method that sets register data from the given port and register to the given value.
This type function provides a hook for the bsp specific method that writes value to the specified port.
| enum console_devs |
This type defination provides an enumerated type of all supported libchip console drivers.
| void bsp_console_select | ( | void | ) |
extern |
The number of serial ports defined in Console_Configuration_Ports
extern |
The statically configured serial port information tables which are used to initially populate the dynamic tables.
extern |
This is the number of serial ports defined in the Console_Port_Tbl.
extern |
This is an array of per port information.
extern |
This is a dynamically sized set of tables containing the serial port information.
