RTEMS 5.2-rc1
schedulercbs.h
1
12/*
13 * Copryight (c) 2011 Petr Benes.
14 * Copyright (C) 2011 On-Line Applications Research Corporation (OAR).
15 *
16 * The license and distribution terms for this file may be
17 * found in the file LICENSE in this distribution or at
18 * http://www.rtems.org/license/LICENSE.
19 */
20
21#ifndef _RTEMS_SCORE_SCHEDULERCBS_H
22#define _RTEMS_SCORE_SCHEDULERCBS_H
23
24#include <rtems/score/chain.h>
27#include <rtems/score/rbtree.h>
29#include <rtems/rtems/signal.h>
30#include <rtems/rtems/timer.h>
31#include <rtems/score/thread.h>
32
33#ifdef __cplusplus
34extern "C" {
35#endif
36
47#define SCHEDULER_CBS_MAXIMUM_PRIORITY SCHEDULER_EDF_MAXIMUM_PRIORITY
48
55#define SCHEDULER_CBS_ENTRY_POINTS \
56 { \
57 _Scheduler_EDF_Initialize, /* initialize entry point */ \
58 _Scheduler_EDF_Schedule, /* schedule entry point */ \
59 _Scheduler_EDF_Yield, /* yield entry point */ \
60 _Scheduler_EDF_Block, /* block entry point */ \
61 _Scheduler_CBS_Unblock, /* unblock entry point */ \
62 _Scheduler_EDF_Update_priority, /* update priority entry point */ \
63 _Scheduler_EDF_Map_priority, /* map priority entry point */ \
64 _Scheduler_EDF_Unmap_priority, /* unmap priority entry point */ \
65 SCHEDULER_OPERATION_DEFAULT_ASK_FOR_HELP \
66 _Scheduler_CBS_Node_initialize, /* node initialize entry point */ \
67 _Scheduler_default_Node_destroy, /* node destroy entry point */ \
68 _Scheduler_CBS_Release_job, /* new period of task */ \
69 _Scheduler_CBS_Cancel_job, /* cancel period of task */ \
70 _Scheduler_default_Tick, /* tick entry point */ \
71 _Scheduler_default_Start_idle /* start idle entry point */ \
72 SCHEDULER_OPERATION_DEFAULT_GET_SET_AFFINITY \
73 }
74
75/* Return values for CBS server. */
76#define SCHEDULER_CBS_OK 0
77#define SCHEDULER_CBS_ERROR_GENERIC -16
78#define SCHEDULER_CBS_ERROR_NO_MEMORY -17
79#define SCHEDULER_CBS_ERROR_INVALID_PARAMETER -18
80#define SCHEDULER_CBS_ERROR_UNAUTHORIZED -19
81#define SCHEDULER_CBS_ERROR_UNIMPLEMENTED -20
82#define SCHEDULER_CBS_ERROR_MISSING_COMPONENT -21
83#define SCHEDULER_CBS_ERROR_INCONSISTENT_STATE -22
84#define SCHEDULER_CBS_ERROR_SYSTEM_OVERLOAD -23
85#define SCHEDULER_CBS_ERROR_INTERNAL_ERROR -24
86#define SCHEDULER_CBS_ERROR_NOT_FOUND -25
87#define SCHEDULER_CBS_ERROR_FULL -26
88#define SCHEDULER_CBS_ERROR_EMPTY -27
89#define SCHEDULER_CBS_ERROR_NOSERVER SCHEDULER_CBS_ERROR_NOT_FOUND
90
92extern const uint32_t _Scheduler_CBS_Maximum_servers;
93
95typedef uint32_t Scheduler_CBS_Server_id;
96
100);
101
105typedef struct {
107 time_t deadline;
109 time_t budget;
111
115typedef struct {
126
134
138typedef struct {
143
144 Priority_Node *deadline_node;
146
147
153
162 const Scheduler_Control *scheduler,
163 Thread_Control *the_thread,
164 Scheduler_Node *node
165);
166
177 const Scheduler_Control *scheduler,
178 Thread_Control *the_thread,
179 Priority_Node *priority_node,
180 uint64_t deadline,
181 Thread_queue_Context *queue_context
182);
183
193 const Scheduler_Control *scheduler,
194 Thread_Control *the_thread,
195 Priority_Node *priority_node,
196 Thread_queue_Context *queue_context
197);
198
207
223 Scheduler_CBS_Server_id server_id,
224 rtems_id task_id
225);
226
242 Scheduler_CBS_Server_id server_id,
243 rtems_id task_id
244);
245
253int _Scheduler_CBS_Cleanup (void);
254
272 Scheduler_CBS_Budget_overrun budget_overrun_callback,
273 rtems_id *server_id
274);
275
289);
290
305 Scheduler_CBS_Server_id server_id,
306 time_t *approved_budget
307);
308
322 Scheduler_CBS_Server_id server_id,
323 time_t *remaining_budget
324);
325
340 Scheduler_CBS_Server_id server_id,
341 time_t *exec_time,
342 time_t *abs_time
343);
344
358 Scheduler_CBS_Server_id server_id,
360);
361
374 rtems_id task_id,
375 Scheduler_CBS_Server_id *server_id
376);
377
392 Scheduler_CBS_Server_id server_id,
393 Scheduler_CBS_Parameters *parameters
394);
395
404 Thread_Control *the_thread
405);
406
416 const Scheduler_Control *scheduler,
417 Scheduler_Node *node,
418 Thread_Control *the_thread,
419 Priority_Control priority
420);
421
422#ifdef __cplusplus
423}
424#endif
425
428#endif
429/* end of include file */
Classic Timer Manager API.
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:83
uint64_t Priority_Control
The thread priority control.
Definition: priority.h:70
int _Scheduler_CBS_Get_server_id(rtems_id task_id, Scheduler_CBS_Server_id *server_id)
Gets a thread server id.
Definition: schedulercbsgetserverid.c:25
Scheduler_CBS_Server _Scheduler_CBS_Server_list[]
void _Scheduler_CBS_Release_job(const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Node *priority_node, uint64_t deadline, Thread_queue_Context *queue_context)
Releases a job.
Definition: schedulercbsreleasejob.c:24
int _Scheduler_CBS_Create_server(Scheduler_CBS_Parameters *params, Scheduler_CBS_Budget_overrun budget_overrun_callback, rtems_id *server_id)
Creates a new server with specified parameters.
Definition: schedulercbscreateserver.c:24
int _Scheduler_CBS_Cleanup(void)
Cleans up resources associated to the CBS Library.
Definition: schedulercbscleanup.c:24
void _Scheduler_CBS_Budget_callout(Thread_Control *the_thread)
Invoked when a limited time quantum is exceeded.
Definition: schedulercbs.c:24
void(* Scheduler_CBS_Budget_overrun)(Scheduler_CBS_Server_id server_id)
Definition: schedulercbs.h:98
int _Scheduler_CBS_Get_remaining_budget(Scheduler_CBS_Server_id server_id, time_t *remaining_budget)
Retrieves remaining budget for the current server instance.
Definition: schedulercbsgetremainingbudget.c:24
int _Scheduler_CBS_Get_approved_budget(Scheduler_CBS_Server_id server_id, time_t *approved_budget)
Retrieves the approved budget.
Definition: schedulercbsgetapprovedbudget.c:25
int _Scheduler_CBS_Detach_thread(Scheduler_CBS_Server_id server_id, rtems_id task_id)
Detaches from the CBS Server.
Definition: schedulercbsdetachthread.c:25
int _Scheduler_CBS_Destroy_server(Scheduler_CBS_Server_id server_id)
Detaches all tasks from a server and destroys it.
Definition: schedulercbsdestroyserver.c:25
void _Scheduler_CBS_Cancel_job(const Scheduler_Control *scheduler, Thread_Control *the_thread, Priority_Node *priority_node, Thread_queue_Context *queue_context)
Cancels a job.
Definition: schedulercbsreleasejob.c:54
int _Scheduler_CBS_Get_execution_time(Scheduler_CBS_Server_id server_id, time_t *exec_time, time_t *abs_time)
Gets relative time info.
Definition: schedulercbsgetexecutiontime.c:25
void _Scheduler_CBS_Node_initialize(const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority)
Initializes a CBS specific scheduler node of the_thread.
Definition: schedulercbsnodeinit.c:23
int _Scheduler_CBS_Attach_thread(Scheduler_CBS_Server_id server_id, rtems_id task_id)
Attaches a task to an already existing server.
Definition: schedulercbsattachthread.c:24
int _Scheduler_CBS_Initialize(void)
Definition: schedulercbs.c:54
void _Scheduler_CBS_Unblock(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Unblocks a thread.
Definition: schedulercbsunblock.c:28
int _Scheduler_CBS_Get_parameters(Scheduler_CBS_Server_id server_id, Scheduler_CBS_Parameters *params)
Retrieves CBS scheduling parameters.
Definition: schedulercbsgetparameters.c:26
Definition: schedulercbs.h:95
int _Scheduler_CBS_Set_parameters(Scheduler_CBS_Server_id server_id, Scheduler_CBS_Parameters *parameters)
Sets parameters for CBS scheduling.
Definition: schedulercbssetparameters.c:25
Signals API.
Priority Handler API.
Constants and Structures Associated with the Red-Black Tree Handler.
Data Related to the Manipulation of Threads for the EDF Scheduler.
Chain Handler API.
Constants and Structures Associated with the Scheduler.
Constants and Structures Related with the Thread Control Block.
The priority node to build up a priority aggregation.
Definition: priority.h:98
Definition: schedulercbs.h:138
Scheduler_CBS_Server * cbs_server
Definition: schedulercbs.h:142
Scheduler_EDF_Node Base
Definition: schedulercbs.h:140
Definition: schedulercbs.h:105
time_t deadline
Definition: schedulercbs.h:107
time_t budget
Definition: schedulercbs.h:109
Definition: schedulercbs.h:115
Scheduler_CBS_Parameters parameters
Definition: schedulercbs.h:123
rtems_id task_id
Definition: schedulercbs.h:121
bool initialized
Indicates if this CBS server is initialized.
Definition: schedulercbs.h:132
Scheduler_CBS_Budget_overrun cbs_budget_overrun
Definition: schedulercbs.h:125
Scheduler node specialization for EDF schedulers.
Definition: scheduleredf.h:90
Scheduler node for per-thread data.
Definition: schedulernode.h:79
Thread queue context for the thread queue methods.
Definition: threadq.h:198
Scheduler control.
Definition: scheduler.h:269
Definition: thread.h:732
