RTEMS 5.2-rc1
Constants and Structures Related with the Thread Control Block. More...
#include <rtems/score/atomic.h>#include <rtems/score/context.h>#include <rtems/score/freechain.h>#include <rtems/score/isrlock.h>#include <rtems/score/objectdata.h>#include <rtems/score/priority.h>#include <rtems/score/schedulernode.h>#include <rtems/score/stack.h>#include <rtems/score/states.h>#include <rtems/score/threadq.h>#include <rtems/score/timestamp.h>#include <rtems/score/watchdog.h>Go to the source code of this file.
| struct | Thread_Entry_idle |
| Data for idle thread entry. More... | |
| struct | Thread_Entry_numeric |
| Data for thread entry with one numeric argument and no return value. More... | |
| struct | Thread_Entry_pointer |
| Data for thread entry with one pointer argument and a pointer return value. More... | |
| struct | Thread_Entry_information |
| Thread entry information. More... | |
| struct | Thread_Start_information |
| struct | Thread_Scheduler_control |
| Thread scheduler control. More... | |
| union | Thread_Wait_information_Object_argument_type |
| Union type to hold a pointer to an immutable or a mutable object. More... | |
| struct | Thread_Wait_information |
| Information required to manage a thread while it is blocked. More... | |
| struct | Thread_Timer_information |
| Information required to manage a thread timer. More... | |
| struct | Thread_Proxy_control |
| struct | Thread_Action |
| Thread action. More... | |
| struct | Thread_Keys_information |
| Per-thread information for POSIX Keys. More... | |
| struct | Thread_Action_control |
| Control block to manage thread actions. More... | |
| struct | Thread_Life_control |
| Thread life control. More... | |
| struct | Thread_Capture_control |
| struct | _Thread_Control |
| struct | Thread_Control_add_on |
| Thread control add-on. More... | |
| struct | Thread_Information |
| The thread object information. More... | |
| #define | RTEMS_SCORE_THREAD_ENABLE_EXHAUST_TIMESLICE |
| #define | RTEMS_SCORE_THREAD_ENABLE_SCHEDULER_CALLOUT |
| #define | THREAD_API_FIRST THREAD_API_RTEMS |
| #define | THREAD_API_LAST THREAD_API_POSIX |
| #define | THREAD_DEFAULT_MAXIMUM_NAME_SIZE 16 |
| The default maximum size of a thread name in characters (including the terminating '\0' character). More... | |
| #define | _Thread_queue_Heads_size sizeof(Thread_queue_Heads) |
| Size of the thread queue heads of a particular application. More... | |
| #define | THREAD_INFORMATION_DEFINE_ZERO(name, api, cls) |
| #define | THREAD_INFORMATION_DEFINE(name, api, cls, max) |
Typedefs | |
| typedef void *Thread | RTEMS_DEPRECATED |
| typedef CPU_Uint32ptr | Thread_Entry_numeric_type |
| Type of the numeric argument of a thread entry function with at least one numeric argument. More... | |
| typedef void(* | Thread_CPU_budget_algorithm_callout) (Thread_Control *) |
| typedef unsigned int | Thread_Wait_flags |
| This type is able to contain several flags used to control the wait class and state of a thread. More... | |
| typedef struct Thread_Action | Thread_Action |
| typedef void(* | Thread_Action_handler) (Thread_Control *the_thread, Thread_Action *action, ISR_lock_Context *lock_context) |
| Thread action handler. More... | |
| typedef void(* | rtems_per_thread_routine) (Thread_Control *) |
| typedef struct Thread_Configured_control | Thread_Configured_control |
| The configured thread control block. More... | |
| typedef Thread_queue_Heads | Thread_queue_Configured_heads |
| The configured thread queue heads. More... | |
Enumerations | |
| enum | Thread_CPU_budget_algorithms { THREAD_CPU_BUDGET_ALGORITHM_NONE , THREAD_CPU_BUDGET_ALGORITHM_RESET_TIMESLICE , THREAD_CPU_BUDGET_ALGORITHM_EXHAUST_TIMESLICE , THREAD_CPU_BUDGET_ALGORITHM_CALLOUT } |
| enum | Thread_APIs { THREAD_API_RTEMS , THREAD_API_POSIX } |
| enum | Thread_Life_state { THREAD_LIFE_PROTECTED = 0x1 , THREAD_LIFE_RESTARTING = 0x2 , THREAD_LIFE_TERMINATING = 0x4 , THREAD_LIFE_CHANGE_DEFERRED = 0x8 , THREAD_LIFE_DETACHED = 0x10 } |
| Thread life states. More... | |
| void | rtems_iterate_over_all_threads (rtems_per_thread_routine routine) RTEMS_DEPRECATED |
| Deprecated, use rtems_task_iterate() instead. More... | |
| Objects_Control * | _Thread_Allocate_unlimited (Objects_Information *information) |
| Return an inactive thread object or NULL. More... | |
| const Thread_Control_add_on | _Thread_Control_add_ons [] |
| Thread control add-ons. More... | |
| const size_t | _Thread_Control_add_on_count |
| Thread control add-on count. More... | |
| const size_t | _Thread_Initial_thread_count |
| Count of configured threads. More... | |
| const size_t | _Thread_Maximum_name_size |
| Maximum size of a thread name in characters (including the terminating '\0' character). More... | |
| Thread_Information | _Thread_Information |
| The internal thread objects information. | |
| char | _Thread_Idle_stacks [] |
| The idle thread stacks. More... | |
This include file contains all constants and structures associated with the thread control block.
