RTEMS 5.2-rc1
RTEMS Run-Time Linker Unwind DWARF Support. More...
#include "rtl-elf.h"Go to the source code of this file.
Typedefs | |
| typedef long | rtems_rtl_elf_unwind_dw2_sleb128 |
| typedef unsigned long | rtems_rtl_elf_unwind_dw2_uleb128 |
| bool | rtems_rtl_elf_unwind_dw2_parse (const rtems_rtl_obj *obj, const char *name, uint32_t flags) |
| bool | rtems_rtl_elf_unwind_dw2_register (const rtems_rtl_obj *obj) |
| bool | rtems_rtl_elf_unwind_dw2_deregister (const rtems_rtl_obj *obj) |
| const uint8_t * | rtems_rtl_elf_unwind_dw2_read_uleb128 (const uint8_t *data, rtems_rtl_elf_unwind_dw2_uleb128 *val) |
| const uint8_t * | rtems_rtl_elf_unwind_dw2_read_sleb128 (const uint8_t *data, rtems_rtl_elf_unwind_dw2_sleb128 *val) |
| bool | rtems_rtl_elf_unwind_dw2_relocate (const Elf_Addr *where, Elf_Word value, Elf_Word mask) |
| bool rtems_rtl_elf_unwind_dw2_deregister | ( | const rtems_rtl_obj * | obj | ) |
Architecture specific handler to remove an object file's unwind information from the base image.
| obj | The object file. |
| true | The unwind information has been deregistered. |
| false | The unwind information could not be deregistered. |
| bool rtems_rtl_elf_unwind_dw2_parse | ( | const rtems_rtl_obj * | obj, |
| const char * | name, | ||
| uint32_t | flags | ||
Architecture specific handler to check if a section contains exception handler data..
| name | The section's name. |
| uint32 | flags The object file's flags. |
| true | The section contains unwind information. |
| false | The section does not contain unwind information. |
| const uint8_t * rtems_rtl_elf_unwind_dw2_read_uleb128 | ( | const uint8_t * | data, |
| rtems_rtl_elf_unwind_dw2_uleb128 * | val | ||
Read signed and unsigned LEB128 values.
| bool rtems_rtl_elf_unwind_dw2_register | ( | const rtems_rtl_obj * | obj | ) |
Architecture specific handler to add an object file's unwind information to the base image.
| true | The unwind information has been registered. |
| false | The unwind information could not be registered. |
