RTEMS 5.2-rc1
RTEMS Run-Time Link Editor Chain Iterator. More...
#include "rtl-chain-iterator.h"Functions | |
| bool | rtems_rtl_chain_iterate (rtems_chain_control *chain, rtems_chain_iterator iterator, void *data) |
| int | rtems_rtl_chain_count (rtems_chain_control *chain) |
A means of executing an iterator on a chain.
| int rtems_rtl_chain_count | ( | rtems_chain_control * | chain | ) |
Count the number of nodes on the chain.
| chain | The chain to count the nodes of. |
| bool rtems_rtl_chain_iterate | ( | rtems_chain_control * | chain, |
| rtems_chain_iterator | iterator, | ||
| void * | data | ||
Iterate a chain of nodes invoking the iterator handler. Supply a data pointer the iterator moves data between the invoker and the iterator.
The iterator allows removal of the node from the chain.
| chain | The chain of nodes to iterator over. |
| iterator | The iterator handler called once for each node. |
| data | Pointer to the data used by the iterator. |
| true | The whole chain was iterated over. |
| false | The iterator returned false. |
