RTEMS 5.2-rc1
Data Structures | Typedefs | Functions
rtems-trace-buffer-vars.h File Reference
Access to the RTEMS Trace Buffer Generator (TBG). More...
struct  __rtld_trace_sig_arg
typedef __rtld_trace_sig_arg rtems_trace_sig_arg
typedef __rtld_trace_sig rtems_trace_sig
uint32_t rtems_trace_names_size (void)
const char * rtems_trace_names (const uint32_t index)
uint32_t rtems_trace_enables_size (void)
uint32_t rtems_trace_enables (const uint32_t index)
uint32_t rtems_trace_triggers_size (void)
uint32_t rtems_trace_triggers (const uint32_t index)
const rtems_trace_sigrtems_trace_signatures (const uint32_t index)
bool rtems_trace_enable_set (const uint32_t index)
bool rtems_trace_trigger_set (const uint32_t index)
bool rtems_trace_buffering_present (void)
uint32_t rtems_trace_buffering_mode (void)
uint32_t rtems_trace_buffering_buffer_size (void)
uint32_t * rtems_trace_buffering_buffer (void)
uint32_t rtems_trace_buffering_buffer_in (void)
bool rtems_trace_buffering_finished (void)
bool rtems_trace_buffering_triggered (void)
void rtems_trace_buffering_start (void)
void rtems_trace_buffering_stop (void)
void rtems_trace_buffering_resume (void)
◆ rtems_trace_buffering_buffer()
uint32_t * rtems_trace_buffering_buffer ( void  )
Return the base of the trace buffering buffer.
◆ rtems_trace_buffering_buffer_in()
uint32_t rtems_trace_buffering_buffer_in ( void  )
Return the buffer level. This is only stable if tracing has finished.
◆ rtems_trace_buffering_buffer_size()
uint32_t rtems_trace_buffering_buffer_size ( void  )
Return the size of the trace buffering buffer in words.
◆ rtems_trace_buffering_finished()
bool rtems_trace_buffering_finished ( void  )
The tracing has finished.
◆ rtems_trace_buffering_mode()
uint32_t rtems_trace_buffering_mode ( void  )
Return the trace buffering mode flags.
◆ rtems_trace_buffering_present()
bool rtems_trace_buffering_present ( void  )
The application has been linked with Trace Buffering generated code.
◆ rtems_trace_buffering_resume()
void rtems_trace_buffering_resume ( void  )
Resume tracing by setting the finished flag.
◆ rtems_trace_buffering_start()
void rtems_trace_buffering_start ( void  )
Start tracing by clearing the triggered flag, setting to 0 and clearing the finished flag.
◆ rtems_trace_buffering_stop()
void rtems_trace_buffering_stop ( void  )
Stop tracing by setting the finished flag.
◆ rtems_trace_buffering_triggered()
bool rtems_trace_buffering_triggered ( void  )
Trace has been triggered and enable trace functions are being recorded.
◆ rtems_trace_enable_set()
bool rtems_trace_enable_set ( const uint32_t  index)
Return true is the enable bit is set for the trace function index.
◆ rtems_trace_enables()
uint32_t rtems_trace_enables ( const uint32_t  index)
Return the enable 32bit bitmap indexed into the enables array. No range checking.
◆ rtems_trace_enables_size()
uint32_t rtems_trace_enables_size ( void  )
Returns the number of words in the enables array.
◆ rtems_trace_names()
const char * rtems_trace_names ( const uint32_t  index)
Return the name given an index. No range checking.
◆ rtems_trace_names_size()
uint32_t rtems_trace_names_size ( void  )
Returns the number of trace functions.
◆ rtems_trace_signatures()
const rtems_trace_sig * rtems_trace_signatures ( const uint32_t  index)
Return the trace function signature.
◆ rtems_trace_trigger_set()
bool rtems_trace_trigger_set ( const uint32_t  index)
Return true is the trigger bit is set for the trace function index.
◆ rtems_trace_triggers()
uint32_t rtems_trace_triggers ( const uint32_t  index)
Return the trigger 32bit bitmap indexed into the triggers array. No range checking.
◆ rtems_trace_triggers_size()
uint32_t rtems_trace_triggers_size ( void  )
Returns the number of words in the triggers array.
