RTEMS 5.2-rc1
rstc.c File Reference
#include <chip.h>
void RSTC_ConfigureMode (uint32_t mr)
void RSTC_SetUserResetEnable (uint8_t enable)
void RSTC_SetUserResetInterruptEnable (uint8_t enable)
void RSTC_SetExtResetLength (uint8_t powl)
void RSTC_ProcessorReset (void)
void RSTC_ExtReset (void)
uint8_t RSTC_GetNrstLevel (void)
uint8_t RSTC_IsUserResetDetected (void)
uint8_t RSTC_IsBusy (void)
uint32_t RSTC_GetStatus (void)
◆ RSTC_ConfigureMode()
void RSTC_ConfigureMode ( uint32_t  mr)
Configure the mode of the RSTC peripheral. The configuration is computed by the lib (RSTC_RMR_*).
Parameters
mrDesired mode configuration.
◆ RSTC_ExtReset()
void RSTC_ExtReset ( void  )
Asserts the NRST pin for external resets.
◆ RSTC_GetNrstLevel()
uint8_t RSTC_GetNrstLevel ( void  )
Return NRST pin level (1 or 0).
◆ RSTC_GetStatus()
uint32_t RSTC_GetStatus ( void  )
Get the status
◆ RSTC_IsBusy()
uint8_t RSTC_IsBusy ( void  )
Return 1 if a software reset command is being performed by the reset controller. The reset controller is busy.
◆ RSTC_IsUserResetDetected()
uint8_t RSTC_IsUserResetDetected ( void  )
Returns 1 if at least one high-to-low transition of NRST (User Reset) has been detected since the last read of RSTC_RSR.
◆ RSTC_ProcessorReset()
void RSTC_ProcessorReset ( void  )
Resets the processor.
◆ RSTC_SetExtResetLength()
void RSTC_SetExtResetLength ( uint8_t  powl)
Setup the external reset length. The length is asserted during a time of pow(2, powl+1) Slow Clock(32KHz). The duration is between 60us and 2s.
Parameters
powlPower length defined.
◆ RSTC_SetUserResetEnable()
void RSTC_SetUserResetEnable ( uint8_t  enable)
Enable/Disable the detection of a low level on the pin NRST as User Reset
Parameters
enable1 to enable & 0 to disable.
◆ RSTC_SetUserResetInterruptEnable()
void RSTC_SetUserResetInterruptEnable ( uint8_t  enable)
Enable/Disable the interrupt of a User Reset (USRTS bit in RSTC_RST).
Parameters
