RTEMS 5.2-rc1
reg_tcr.h
1/* The header file is generated by make_header.py from TCR.json */
2/* Current script's version can be found at: */
3/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5/*
6 * Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7 *
8 * Czech Technical University in Prague
9 * Zikova 1903/4
10 * 166 36 Praha 6
11 * Czech Republic
12 *
13 * All rights reserved.
14 *
16 * modification, are permitted provided that the following conditions are met:
17 *
18 * 1. Redistributions of source code must retain the above copyright notice, this
19 * list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright notice,
21 * this list of conditions and the following disclaimer in the documentation
22 * and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26 * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27 * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28 * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29 * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30 * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32 * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33 * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34 *
35 * The views and conclusions contained in the software and documentation are those
36 * of the authors and should not be interpreted as representing official policies,
37 * either expressed or implied, of the FreeBSD Project.
38*/
39#ifndef LIBBSP_ARM_TMS570_TCR
40#define LIBBSP_ARM_TMS570_TCR
41
42#include <bsp/utility.h>
43
44typedef struct{
45 uint32_t TCR[128]; /*Transfer Configuration RAM*/
46 uint32_t TCR_Parity[128]; /*TCR Parity Test Mode*/
48
49
50/*-----------------------TMS570_TCR_TCR-----------------------*/
51/* field: STXR - Set Transmit Request. */
52#define TMS570_TCR_TCR_STXR BSP_BIT32(18)
53
54/* field: THTSM - Transfer Header to System Memory. */
55#define TMS570_TCR_TCR_THTSM BSP_BIT32(17)
56
57/* field: TPTSM - Transfer Payload to System Memory. */
58#define TMS570_TCR_TCR_TPTSM BSP_BIT32(16)
59
60/* field: THTCC - Transfer Header to Communication Controller. */
61#define TMS570_TCR_TCR_THTCC BSP_BIT32(15)
62
63/* field: TPTCC - Transfer Payload to Communication Controller. */
64#define TMS570_TCR_TCR_TPTCC BSP_BIT32(14)
65
66/* field: TSO - Transfer Start Offset. */
67#define TMS570_TCR_TCR_TSO(val) BSP_FLD32(val,0, 13)
68#define TMS570_TCR_TCR_TSO_GET(reg) BSP_FLD32GET(reg,0, 13)
69#define TMS570_TCR_TCR_TSO_SET(reg,val) BSP_FLD32SET(reg, val,0, 13)
70
71
72/*-------------------TMS570_TCR_TCR_Parity-------------------*/
73/* field: PAB2 - Parity Bit for TCRx Byte 2. Parity information for byte 2 of TCRx(18-16). */
74#define TMS570_TCR_TCR_Parity_PAB2 BSP_BIT32(16)
75
76/* field: PAB1 - Parity Bit for TCRx Byte 1. Parity information for byte 1 of TCRx(15:8). */
77#define TMS570_TCR_TCR_Parity_PAB1 BSP_BIT32(8)
78
79/* field: PAB0 - Parity Bit for Byte 0. */
80#define TMS570_TCR_TCR_Parity_PAB0 BSP_BIT32(0)
81
82
83
84#endif /* LIBBSP_ARM_TMS570_TCR */
#define TCR
tx configuration reg
Definition: wd80x3.h:99
Utility macros.
Definition: reg_tcr.h:44
