RTEMS 5.2-rc1
DP8390 Support
DP8390 Ethernet Controller Support. More...
file  wd80x3.h
Controller DP8390.
#define DATAPORT   0x10
 Port Window.
#define RESET   0x1f
 Issue a read for reset.
#define W83CREG   0x00
 I/O port definition.
#define ADDROM   0x08
page 0 read or read/write registers
#define CMDR   0x00+RO
#define CLDA0   0x01+RO
 current local dma addr 0 for read
#define CLDA1   0x02+RO
 current local dma addr 1 for read
#define BNRY   0x03+RO
 boundary reg for rd and wr
#define TSR   0x04+RO
 tx status reg for rd
#define NCR   0x05+RO
 number of collision reg for rd
#define FIFO   0x06+RO
#define ISR   0x07+RO
 interrupt status reg for rd and wr
#define CRDA0   0x08+RO
 current remote dma address 0 for rd
#define CRDA1   0x09+RO
 current remote dma address 1 for rd
#define RSR   0x0C+RO
 rx status reg for rd
#define CNTR0   0x0D+RO
 tally cnt 0 for frm alg err for rd
#define CNTR1   RO+0x0E
 tally cnt 1 for crc err for rd
#define CNTR2   0x0F+RO
 tally cnt 2 for missed pkt for rd
page 0 write registers
#define PSTART   0x01+RO
 page start register
#define PSTOP   0x02+RO
 page stop register
#define TPSR   0x04+RO
#define TBCR0   0x05+RO
 tx byte count 0 reg
#define TBCR1   0x06+RO
 tx byte count 1 reg
#define RSAR0   0x08+RO
 remote start address reg 0
#define RSAR1   0x09+RO
 remote start address reg 1
#define RBCR0   0x0A+RO
 remote byte count reg 0
#define RBCR1   0x0B+RO
 remote byte count reg 1
#define RCR   0x0C+RO
 rx configuration reg
#define TCR   0x0D+RO
 tx configuration reg
#define DCR   RO+0x0E
 data configuration reg
#define IMR   0x0F+RO
 interrupt mask reg
page 1 registers
#define PAR   0x01+RO
 physical addr reg base for rd and wr
#define CURR   0x07+RO
 current page reg for rd and wr
#define MAR   0x08+RO
 multicast addr reg base fro rd and WR
#define MARsize   8
 size of multicast addr space
W83CREG command bits
#define MSK_RESET   0x80
 W83CREG masks.
#define MSK_ENASH   0x40
#define MSK_DECOD   0x3F
 memory decode bits, corresponding
CMDR command bits
#define MSK_STP   0x01
 stop the chip
#define MSK_STA   0x02
 start the chip
#define MSK_TXP   0x04
 initial txing of a frm
#define MSK_RRE   0x08
 remote read
#define MSK_RWR   0x10
 remote write
#define MSK_RD2   0x20
 no DMA used
#define MSK_PG0   0x00
 select register page 0
#define MSK_PG1   0x40
 select register page 1
#define MSK_PG2   0x80
 select register page 2
ISR and TSR status bits
#define MSK_PRX   0x01
#define MSK_PTX   0x02
#define MSK_RXE   0x04
#define MSK_TXE   0x08
#define MSK_OVW   0x10
#define MSK_CNT   0x20
#define MSK_RDC   0x40
#define MSK_RST   0x80
DCR command bits
#define MSK_WTS   0x01
 word transfer mode selection
#define MSK_BOS   0x02
 byte order selection
#define MSK_LAS   0x04
 long addr selection
#define MSK_BMS   0x08
 burst mode selection
#define MSK_ARM   0x10
 autoinitialize remote
#define MSK_FT00   0x00
 burst lrngth selection
#define MSK_FT01   0x20
#define MSK_FT10   0x40
#define MSK_FT11   0x60
RCR command bits
#define MSK_SEP   0x01
 save error pkts
#define MSK_AR   0x02
 accept runt pkt
#define MSK_AB   0x04
 8390 RCR
#define MSK_AM   0x08
 accept multicast
#define MSK_PRO   0x10
 accept all pkt with physical adr
#define MSK_MON   0x20
 monitor mode
TCR command bits
#define MSK_CRC   0x01
 inhibit CRC, do not append crc
#define MSK_LOOP   0x02
 set loopback mode
#define MSK_BCST   0x04
 Accept broadcasts.
#define MSK_LB01   0x06
 encoded loopback control
#define MSK_ATD   0x08
 auto tx disable
#define MSK_OFST   0x10
 collision offset enable
receive status bits
#define SMK_PRX   0x01
 rx without error
#define SMK_CRC   0x02
 CRC error.
#define SMK_FAE   0x04
 frame alignment error
#define SMK_FO   0x08
 FIFO overrun.
#define SMK_MPA   0x10
 missed pkt
#define SMK_PHY   0x20
 physical/multicase address
#define SMK_DIS   0x40
 receiver disable. set in monitor mode
#define SMK_DEF   0x80
 deferring
transmit status bits
#define SMK_PTX   0x01
 tx without error
#define SMK_DFR   0x02
 non deferred tx
#define SMK_COL   0x04
 tx collided
#define SMK_ABT   0x08
 tx abort because of excessive collisions
#define SMK_CRS   0x10
 carrier sense lost
#define SMK_FU   0x20
 FIFO underrun.
#define SMK_CDH   0x40
 collision detect heartbeat
#define SMK_OWC   0x80
 out of window collision
◆ FIFO
@breif FIFO for rd
◆ TPSR
@breif tx start page start reg
