RTEMS 5.2-rc1
reg_htu.h
1/* The header file is generated by make_header.py from HTU.json */
2/* Current script's version can be found at: */
3/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5/*
6 * Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7 *
8 * Czech Technical University in Prague
9 * Zikova 1903/4
10 * 166 36 Praha 6
11 * Czech Republic
12 *
13 * All rights reserved.
14 *
16 * modification, are permitted provided that the following conditions are met:
17 *
18 * 1. Redistributions of source code must retain the above copyright notice, this
19 * list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright notice,
21 * this list of conditions and the following disclaimer in the documentation
22 * and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26 * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27 * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28 * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29 * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30 * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32 * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33 * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34 *
35 * The views and conclusions contained in the software and documentation are those
36 * of the authors and should not be interpreted as representing official policies,
37 * either expressed or implied, of the FreeBSD Project.
38*/
39#ifndef LIBBSP_ARM_TMS570_HTU
40#define LIBBSP_ARM_TMS570_HTU
41
42#include <bsp/utility.h>
43
44typedef struct{
45 uint32_t GC; /*Global Control Register*/
46 uint32_t CPENA; /*Control Packet Enable Register*/
47 uint32_t BUSY0; /*Control Packet Busy Register 0*/
48 uint32_t BUSY1; /*Control Packet Busy Register 1*/
49 uint32_t BUSY2; /*Control Packet Busy Register 2*/
50 uint32_t BUSY3; /*Control Packet Busy Register 3*/
51 uint32_t ACPE; /*Active Control Packet and Error Register*/
52 uint8_t reserved1 [4];
53 uint32_t RLBECTRL; /*Request Lost and Bus Error Control Register*/
54 uint32_t BFINTS; /*Buffer Full Interrupt Enable Set Register*/
55 uint32_t BFINTC; /*Buffer Full Interrupt Enable Clear Register*/
56 uint8_t reserved2 [8];
57 uint32_t INTOFF0; /*Interrupt Offset Register 0*/
58 uint32_t INTOFF1; /*Interrupt Offset Register 1*/
59 uint32_t BIM; /*Buffer Initialization Mode Register*/
60 uint32_t RLOSTFL; /*Request Lost Flag Register*/
61 uint32_t BFINTFL; /*Buffer Full Interrupt Flag Register*/
62 uint32_t BERINTFL; /*BER Interrupt Flag Register*/
63 uint32_t MP1S; /*Memory Protection 1 Start Address Register*/
64 uint32_t MP1E; /*Memory Protection 1 End Address Register*/
65 uint32_t DCTRL; /*Debug Control Register*/
66 uint32_t WPR; /*Watch Point Register*/
67 uint32_t WMR; /*Watch Mask Register*/
68 uint32_t ID; /*Module Identification Register*/
69 uint32_t PCR; /*Parity Control Register*/
70 uint32_t PAR; /*Parity Address Register*/
71 uint8_t reserved3 [4];
72 uint32_t MPCS; /*Memory Protection Control and Status Register*/
73 uint32_t MP0S; /*Memory Protection 0 Start Address Register*/
74 uint32_t MP0E; /*Memory Protection 0 End Address Register*/
76
77
78/*-----------------------TMS570_HTU_GC-----------------------*/
79/* field: VBUSHOLD - Hold the VBUS bus */
80#define TMS570_HTU_GC_VBUSHOLD BSP_BIT32(24)
81
82/* field: HTUEN - Transfer Unit Enable Bit */
83#define TMS570_HTU_GC_HTUEN BSP_BIT32(16)
84
85/* field: DEBM - Debug Mode */
86#define TMS570_HTU_GC_DEBM BSP_BIT32(8)
87
88/* field: HTURES - HTU Software Reset Request */
89#define TMS570_HTU_GC_HTURES BSP_BIT32(0)
90
91
92/*----------------------TMS570_HTU_CPENA----------------------*/
93/* field: CPENA - CP Enable Bits */
94#define TMS570_HTU_CPENA_CPENA(val) BSP_FLD32(val,0, 15)
95#define TMS570_HTU_CPENA_CPENA_GET(reg) BSP_FLD32GET(reg,0, 15)
96#define TMS570_HTU_CPENA_CPENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
97
98
99/*----------------------TMS570_HTU_BUSY0----------------------*/
100/* field: BUSY0A - Busy Flag for CP A of DCP 0 */
101#define TMS570_HTU_BUSY0_BUSY0A BSP_BIT32(24)
102
103/* field: BUSY0B - Busy Flag for CP B of DCP 0 */
104#define TMS570_HTU_BUSY0_BUSY0B BSP_BIT32(16)
105
106/* field: BUSY1A - Busy Flag for CP A of DCP 1 */
107#define TMS570_HTU_BUSY0_BUSY1A BSP_BIT32(8)
108
109/* field: BUSY1B - Busy Flag for CP B of DCP 1 */
110#define TMS570_HTU_BUSY0_BUSY1B BSP_BIT32(0)
111
112
113/*----------------------TMS570_HTU_BUSY1----------------------*/
114/* field: BUSY2A - Busy Flag for CP A of DCP 2 */
115#define TMS570_HTU_BUSY1_BUSY2A BSP_BIT32(24)
116
117/* field: BUSY2B - Busy Flag for CP B of DCP 2 */
118#define TMS570_HTU_BUSY1_BUSY2B BSP_BIT32(16)
119
120/* field: BUSY3A - Busy Flag for CP A of DCP 3 */
121#define TMS570_HTU_BUSY1_BUSY3A BSP_BIT32(8)
122
123/* field: BUSY3B - Busy Flag for CP B of DCP 3 */
124#define TMS570_HTU_BUSY1_BUSY3B BSP_BIT32(0)
125
126
127/*----------------------TMS570_HTU_BUSY2----------------------*/
128/* field: BUSY4A - Busy Flag for CP A of DCP 4 */
129#define TMS570_HTU_BUSY2_BUSY4A BSP_BIT32(24)
130
131/* field: BUSY4B - Busy Flag for CP B of DCP 4 */
132#define TMS570_HTU_BUSY2_BUSY4B BSP_BIT32(16)
133
134/* field: BUSY5A - Busy Flag for CP A of DCP 5 */
135#define TMS570_HTU_BUSY2_BUSY5A BSP_BIT32(8)
136
137/* field: BUSY5B - Busy Flag for CP B of DCP 5 */
138#define TMS570_HTU_BUSY2_BUSY5B BSP_BIT32(0)
139
140
141/*----------------------TMS570_HTU_BUSY3----------------------*/
142/* field: BUSY6A - Busy Flag for CP A of DCP 6 */
143#define TMS570_HTU_BUSY3_BUSY6A BSP_BIT32(24)
144
145/* field: BUSY6B - Busy Flag for CP B of DCP 6 */
146#define TMS570_HTU_BUSY3_BUSY6B BSP_BIT32(16)
147
148/* field: BUSY7A - Busy Flag for CP A of DCP 7 */
149#define TMS570_HTU_BUSY3_BUSY7A BSP_BIT32(8)
150
151/* field: BUSY7B - Busy Flag for CP B of DCP 7 */
152#define TMS570_HTU_BUSY3_BUSY7B BSP_BIT32(0)
153
154
155/*----------------------TMS570_HTU_ACPE----------------------*/
156/* field: ERRF - Error Flag */
157#define TMS570_HTU_ACPE_ERRF BSP_BIT32(31)
158
159
160/*--------------------TMS570_HTU_RLBECTRL--------------------*/
161/* field: BERINTENA - Bus Error Interrupt Enable Bit */
162#define TMS570_HTU_RLBECTRL_BERINTENA BSP_BIT32(16)
163
164/* field: CORL - Continue On Request Lost Error */
165#define TMS570_HTU_RLBECTRL_CORL BSP_BIT32(8)
166
167/* field: RLINTENA - Request Lost Interrupt Enable Bit */
168#define TMS570_HTU_RLBECTRL_RLINTENA BSP_BIT32(0)
169
170
171/*---------------------TMS570_HTU_BFINTS---------------------*/
172/* field: BFINTENA - Bus Full Interrupt Enable Bits. */
173#define TMS570_HTU_BFINTS_BFINTENA(val) BSP_FLD32(val,0, 15)
174#define TMS570_HTU_BFINTS_BFINTENA_GET(reg) BSP_FLD32GET(reg,0, 15)
175#define TMS570_HTU_BFINTS_BFINTENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
176
177
178/*---------------------TMS570_HTU_BFINTC---------------------*/
179/* field: BFINTDIS - */
180#define TMS570_HTU_BFINTC_BFINTDIS(val) BSP_FLD32(val,0, 15)
181#define TMS570_HTU_BFINTC_BFINTDIS_GET(reg) BSP_FLD32GET(reg,0, 15)
182#define TMS570_HTU_BFINTC_BFINTDIS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
183
184
185/*---------------------TMS570_HTU_INTOFF0---------------------*/
186/* field: INTTYPE0 - Interrupt Type of Interrupt Line 0. */
187#define TMS570_HTU_INTOFF0_INTTYPE0(val) BSP_FLD32(val,8, 10)
188#define TMS570_HTU_INTOFF0_INTTYPE0_GET(reg) BSP_FLD32GET(reg,8, 10)
189#define TMS570_HTU_INTOFF0_INTTYPE0_SET(reg,val) BSP_FLD32SET(reg, val,8, 10)
190
191/* field: CPOFF0 - CP Offset. */
192#define TMS570_HTU_INTOFF0_CPOFF0(val) BSP_FLD32(val,0, 4)
193#define TMS570_HTU_INTOFF0_CPOFF0_GET(reg) BSP_FLD32GET(reg,0, 4)
194#define TMS570_HTU_INTOFF0_CPOFF0_SET(reg,val) BSP_FLD32SET(reg, val,0, 4)
195
196
197/*---------------------TMS570_HTU_INTOFF1---------------------*/
198/* field: INTTYPE1 - INTTYPE1 Interrupt Type of Interrupt Line 1. */
199#define TMS570_HTU_INTOFF1_INTTYPE1(val) BSP_FLD32(val,8, 10)
200#define TMS570_HTU_INTOFF1_INTTYPE1_GET(reg) BSP_FLD32GET(reg,8, 10)
201#define TMS570_HTU_INTOFF1_INTTYPE1_SET(reg,val) BSP_FLD32SET(reg, val,8, 10)
202
203/* field: CPOFF1 - CP Offset. */
204#define TMS570_HTU_INTOFF1_CPOFF1(val) BSP_FLD32(val,0, 4)
205#define TMS570_HTU_INTOFF1_CPOFF1_GET(reg) BSP_FLD32GET(reg,0, 4)
206#define TMS570_HTU_INTOFF1_CPOFF1_SET(reg,val) BSP_FLD32SET(reg, val,0, 4)
207
208
209/*-----------------------TMS570_HTU_BIM-----------------------*/
210/* field: BIM - Buffer Initialization Mode */
211#define TMS570_HTU_BIM_BIM(val) BSP_FLD32(val,0, 7)
212#define TMS570_HTU_BIM_BIM_GET(reg) BSP_FLD32GET(reg,0, 7)
213#define TMS570_HTU_BIM_BIM_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
214
215
216/*---------------------TMS570_HTU_RLOSTFL---------------------*/
217/* field: CPRLFL - CP Request Lost Flags */
218#define TMS570_HTU_RLOSTFL_CPRLFL(val) BSP_FLD32(val,0, 15)
219#define TMS570_HTU_RLOSTFL_CPRLFL_GET(reg) BSP_FLD32GET(reg,0, 15)
220#define TMS570_HTU_RLOSTFL_CPRLFL_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
221
222
223/*---------------------TMS570_HTU_BFINTFL---------------------*/
224/* field: BFINTFL - Buffer Full Interrupt Flags */
225#define TMS570_HTU_BFINTFL_BFINTFL(val) BSP_FLD32(val,0, 15)
226#define TMS570_HTU_BFINTFL_BFINTFL_GET(reg) BSP_FLD32GET(reg,0, 15)
227#define TMS570_HTU_BFINTFL_BFINTFL_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
228
229
230/*--------------------TMS570_HTU_BERINTFL--------------------*/
231/* field: BERINTFL - Bus Error Interrupt Flags */
232#define TMS570_HTU_BERINTFL_BERINTFL(val) BSP_FLD32(val,0, 15)
233#define TMS570_HTU_BERINTFL_BERINTFL_GET(reg) BSP_FLD32GET(reg,0, 15)
234#define TMS570_HTU_BERINTFL_BERINTFL_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
235
236
237/*----------------------TMS570_HTU_MP1S----------------------*/
238/* field: STARTADDRESS1 - he start address defines at which main memory address the region begins. */
239/* Whole 32 bits */
240
241/*----------------------TMS570_HTU_MP1E----------------------*/
242/* field: ENDADDRESS1 - The end address defines at which address the region ends. */
243/* Whole 32 bits */
244
245/*----------------------TMS570_HTU_DCTRL----------------------*/
246/* field: CPNUM - CP Number. These bit fields indicate the CP which should cause the watch point to match. */
247#define TMS570_HTU_DCTRL_CPNUM(val) BSP_FLD32(val,24, 27)
248#define TMS570_HTU_DCTRL_CPNUM_GET(reg) BSP_FLD32GET(reg,24, 27)
249#define TMS570_HTU_DCTRL_CPNUM_SET(reg,val) BSP_FLD32SET(reg, val,24, 27)
250
251/* field: HTUDBGS - HTU Debug Status. */
252#define TMS570_HTU_DCTRL_HTUDBGS BSP_BIT32(16)
253
254/* field: DBREN - Debug Request Enable */
255#define TMS570_HTU_DCTRL_DBREN BSP_BIT32(0)
256
257
258/*-----------------------TMS570_HTU_WPR-----------------------*/
259/* field: WP - Watch Point Register */
260/* Whole 32 bits */
261
262/*-----------------------TMS570_HTU_WMR-----------------------*/
263/* field: WM - Watch Mask Register */
264/* Whole 32 bits */
265
266/*-----------------------TMS570_HTU_ID-----------------------*/
267/* field: CLASS - Module Class */
268#define TMS570_HTU_ID_CLASS(val) BSP_FLD32(val,16, 23)
269#define TMS570_HTU_ID_CLASS_GET(reg) BSP_FLD32GET(reg,16, 23)
270#define TMS570_HTU_ID_CLASS_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
271
272/* field: TYPE - Subtype within a Class */
273#define TMS570_HTU_ID_TYPE(val) BSP_FLD32(val,8, 15)
274#define TMS570_HTU_ID_TYPE_GET(reg) BSP_FLD32GET(reg,8, 15)
275#define TMS570_HTU_ID_TYPE_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
276
277/* field: REV - Module Revision Number */
278#define TMS570_HTU_ID_REV(val) BSP_FLD32(val,0, 7)
279#define TMS570_HTU_ID_REV_GET(reg) BSP_FLD32GET(reg,0, 7)
280#define TMS570_HTU_ID_REV_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
281
282
283/*-----------------------TMS570_HTU_PCR-----------------------*/
284/* field: COPE - Continue on Parity Error */
285#define TMS570_HTU_PCR_COPE BSP_BIT32(16)
286
287/* field: TEST - Test. */
288#define TMS570_HTU_PCR_TEST BSP_BIT32(8)
289
290/* field: PARITY_ENA - Enable/Disable Parity Checking. */
291#define TMS570_HTU_PCR_PARITY_ENA(val) BSP_FLD32(val,0, 3)
292#define TMS570_HTU_PCR_PARITY_ENA_GET(reg) BSP_FLD32GET(reg,0, 3)
293#define TMS570_HTU_PCR_PARITY_ENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
294
295
296/*-----------------------TMS570_HTU_PAR-----------------------*/
297/* field: PEFT - Parity Error Fault Flag. */
298#define TMS570_HTU_PAR_PEFT BSP_BIT32(16)
299
300/* field: PAOFF - PAOFF */
301#define TMS570_HTU_PAR_PAOFF(val) BSP_FLD32(val,0, 8)
302#define TMS570_HTU_PAR_PAOFF_GET(reg) BSP_FLD32GET(reg,0, 8)
303#define TMS570_HTU_PAR_PAOFF_SET(reg,val) BSP_FLD32SET(reg, val,0, 8)
304
305
306/*----------------------TMS570_HTU_MPCS----------------------*/
307/* field: CPNUM0 - Control Packet Number for single memory protection region configuration. */
308#define TMS570_HTU_MPCS_CPNUM0(val) BSP_FLD32(val,24, 27)
309#define TMS570_HTU_MPCS_CPNUM0_GET(reg) BSP_FLD32GET(reg,24, 27)
310#define TMS570_HTU_MPCS_CPNUM0_SET(reg,val) BSP_FLD32SET(reg, val,24, 27)
311
312/* field: MPEFT1 - MPEFT1 */
313#define TMS570_HTU_MPCS_MPEFT1 BSP_BIT32(17)
314
315/* field: MPEFT0 - Memory Protection Error Fault Flag 0. */
316#define TMS570_HTU_MPCS_MPEFT0 BSP_BIT32(16)
317
318/* field: CPNUM1 - Control Packet Number for single memory protection region configuration. */
319#define TMS570_HTU_MPCS_CPNUM1(val) BSP_FLD32(val,8, 11)
320#define TMS570_HTU_MPCS_CPNUM1_GET(reg) BSP_FLD32GET(reg,8, 11)
321#define TMS570_HTU_MPCS_CPNUM1_SET(reg,val) BSP_FLD32SET(reg, val,8, 11)
322
323
324/*----------------------TMS570_HTU_MP0S----------------------*/
325/* field: ISTARTADDRESS0 - The start address defines at which main memory address the region begins. */
326/* Whole 32 bits */
327
328/*----------------------TMS570_HTU_MP0E----------------------*/
329/* field: ENDADDRESS0 - The end address defines at which address the region ends. */
330/* Whole 32 bits */
331
332
333#endif /* LIBBSP_ARM_TMS570_HTU */
#define PAR
physical addr reg base for rd and wr
Definition: wd80x3.h:113
Utility macros.
Definition: reg_htu.h:44
