RTEMS 5.2-rc1
Macros | Enumerations | Functions
fb.c File Reference
framebuffer support. More...
#include <sys/types.h>
#include <bsp.h>
#include <bsp/raspberrypi.h>
#include <bsp/mailbox.h>
#include <bsp/vc.h>
#include <bsp/rpi-fb.h>
#include <libcpu/arm-cp15.h>
#include <rtems/libio.h>
#include <rtems/fb.h>
#include <rtems/framebuffer.h>
#include <rtems/score/atomic.h>
#include <rtems/bspIo.h>
#define SCREEN_WIDTH   1024
#define SCREEN_HEIGHT   768
#define BPP   32
enum  mode_err_ret_val {
  NO_SUITABLE_MODE = -1 , BAD_FORMAT = -2 , AUTO_SELECT = -3 , DONT_INIT = -4 ,
  NO_MODE_REQ = -5 , NO_SUITABLE_MODE = -1 , BAD_FORMAT = -2 , AUTO_SELECT = -3 ,
  DONT_INIT = -4 , NO_MODE_REQ = -5
int rpi_get_fix_screen_info (struct fb_fix_screeninfo *info)
int rpi_get_var_screen_info (struct fb_var_screeninfo *info)
bool rpi_fb_hdmi_is_present (void)
int rpi_fb_init (void)
rtems_device_driver frame_buffer_initialize (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 Frame Buffer Initialization Entry Point. More...
rtems_device_driver frame_buffer_open (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 Frame Buffer Open Entry Point. More...
rtems_device_driver frame_buffer_close (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 Frame Buffer Close Entry Point. More...
rtems_device_driver frame_buffer_read (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 Frame Buffer Read Entry Point. More...
rtems_device_driver frame_buffer_write (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 Frame Buffer Write Entry Point. More...
rtems_device_driver frame_buffer_control (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 Frame Buffer IO Control Entry Point. More...
◆ frame_buffer_close()
rtems_device_driver frame_buffer_close ( rtems_device_major_number  major,
void *  arg
This method closes a specific device supported by the frame buffer device driver.
Parameters
[in]majoris the device driver major number
[in]minoris the device driver minor number
[in]argis the parameters to this call
Returns
This method returns RTEMS_SUCCESSFUL when the device is successfully closed.
◆ frame_buffer_control()
rtems_device_driver frame_buffer_control ( rtems_device_major_number  major,
void *  arg
This method performs an IO Control operation on a specific device supported by the frame buffer device driver.
Parameters
Returns
This method returns RTEMS_SUCCESSFUL when the device driver IO control operation is successfully performed.
◆ frame_buffer_initialize()
rtems_device_driver frame_buffer_initialize ( rtems_device_major_number  major,
void *  arg
This method initializes the frame buffer device driver.
Parameters
Returns
This method returns RTEMS_SUCCESSFUL when the device driver is successfully initialized.
◆ frame_buffer_open()
rtems_device_driver frame_buffer_open ( rtems_device_major_number  major,
void *  arg
This method opens a specific device supported by the frame buffer device driver.
Parameters
Returns
This method returns RTEMS_SUCCESSFUL when the device driver is successfully opened.
◆ frame_buffer_read()
rtems_device_driver frame_buffer_read ( rtems_device_major_number  major,
void *  arg
This method reads from a specific device supported by the frame buffer device driver.
Parameters
Returns
This method returns RTEMS_SUCCESSFUL when the device is successfully read from.
◆ frame_buffer_write()
rtems_device_driver frame_buffer_write ( rtems_device_major_number  major,
void *  arg
This method writes to a specific device supported by the frame buffer device driver.
Parameters
Returns
This method returns RTEMS_SUCCESSFUL when the device is successfully written.
