RTEMS 5.2-rc1
Data Structures | Macros | Variables
ps2_mouse.h File Reference
Keyboard and mouse definitions. More...
struct  aux_queue
#define KBD_REPORT_UNKN   /* Report unknown scan codes */
#define KBD_REPORT_TIMEOUTS   /* Report keyboard timeouts */
#define KBD_INIT_TIMEOUT   1000 /* Timeout in ms for initializing the keyboard */
#define KBC_TIMEOUT   250 /* Timeout in ms for sending to keyboard controller */
#define KBD_TIMEOUT   1000 /* Timeout in ms for keyboard command acknowledge */
#define KBD_STATUS_REG   0x64 /* Status register (R) */
#define KBD_CNTL_REG   0x64 /* Controller command register (W) */
#define KBD_DATA_REG   0x60 /* Keyboard data register (R/W) */
#define KBD_CCMD_READ_MODE   0x20 /* Read mode bits */
#define KBD_CCMD_WRITE_MODE   0x60 /* Write mode bits */
#define KBD_CCMD_GET_VERSION   0xA1 /* Get controller version */
#define KBD_CCMD_MOUSE_DISABLE   0xA7 /* Disable mouse interface */
#define KBD_CCMD_MOUSE_ENABLE   0xA8 /* Enable mouse interface */
#define KBD_CCMD_TEST_MOUSE   0xA9 /* Mouse interface test */
#define KBD_CCMD_SELF_TEST   0xAA /* Controller self test */
#define KBD_CCMD_KBD_TEST   0xAB /* Keyboard interface test */
#define KBD_CCMD_KBD_DISABLE   0xAD /* Keyboard interface disable */
#define KBD_CCMD_KBD_ENABLE   0xAE /* Keyboard interface enable */
#define KBD_CCMD_WRITE_AUX_OBUF
#define KBD_CCMD_WRITE_MOUSE   0xD4 /* Write the following byte to the mouse */
#define KBD_CMD_SET_LEDS   0xED /* Set keyboard leds */
#define KBD_CMD_SET_RATE   0xF3 /* Set typematic rate */
#define KBD_CMD_ENABLE   0xF4 /* Enable scanning */
#define KBD_CMD_DISABLE   0xF5 /* Disable scanning */
#define KBD_CMD_RESET   0xFF /* Reset */
#define KBD_REPLY_POR   0xAA /* Power on reset */
#define KBD_REPLY_ACK   0xFA /* Command ACK */
#define KBD_REPLY_RESEND   0xFE /* Command NACK, send the cmd again */
#define KBD_STAT_OBF   0x01 /* Keyboard output buffer full */
#define KBD_STAT_IBF   0x02 /* Keyboard input buffer full */
#define KBD_STAT_SELFTEST   0x04 /* Self test successful */
#define KBD_STAT_CMD   0x08 /* Last write was a command write (0=data) */
#define KBD_STAT_UNLOCKED   0x10 /* Zero if keyboard locked */
#define KBD_STAT_MOUSE_OBF   0x20 /* Mouse output buffer full */
#define KBD_STAT_GTO   0x40 /* General receive/xmit timeout */
#define KBD_STAT_PERR   0x80 /* Parity error */
#define AUX_STAT_OBF   (KBD_STAT_OBF | KBD_STAT_MOUSE_OBF)
#define KBD_MODE_KBD_INT   0x01 /* Keyboard data generate IRQ1 */
#define KBD_MODE_MOUSE_INT   0x02 /* Mouse data generate IRQ12 */
#define KBD_MODE_SYS   0x04 /* The system flag (?) */
#define KBD_MODE_NO_KEYLOCK   0x08 /* The keylock doesn't affect the keyboard if set */
#define KBD_MODE_DISABLE_KBD   0x10 /* Disable keyboard interface */
#define KBD_MODE_DISABLE_MOUSE   0x20 /* Disable mouse interface */
#define KBD_MODE_KCC   0x40 /* Scan code conversion to PC format */
#define KBD_MODE_RFU   0x80
#define AUX_SET_RES   0xE8 /* Set resolution */
#define AUX_SET_SCALE11   0xE6 /* Set 1:1 scaling */
#define AUX_SET_SCALE21   0xE7 /* Set 2:1 scaling */
#define AUX_GET_SCALE   0xE9 /* Get scaling factor */
#define AUX_SET_STREAM   0xEA /* Set stream mode */
#define AUX_SET_SAMPLE   0xF3 /* Set sample rate */
#define AUX_ENABLE_DEV   0xF4 /* Enable aux device */
#define AUX_DISABLE_DEV   0xF5 /* Disable aux device */
#define AUX_RESET   0xFF /* Reset aux device */
#define AUX_ACK   0xFA /* Command byte ACK. */
#define AUX_BUF_SIZE
#define kbd_read_input()   inb(KBD_DATA_REG)
#define kbd_read_status()   inb(KBD_STATUS_REG)
#define kbd_write_output(val)   outb(val, KBD_DATA_REG)
#define kbd_write_command(val)   outb(val, KBD_CNTL_REG)
#define AUX_IRQ   12
unsigned char pckbd_read_mask
unsigned char aux_device_present
◆ AUX_BUF_SIZE
Value:
512 /* This might be better divisible by
three to make overruns stay in sync
but then the read function would need
a lock etc - ick */
◆ KBD_CCMD_WRITE_AUX_OBUF
Value:
0xD3 /* Write to output buffer as if
initiated by the auxiliary device */
