RTEMS 5.2-rc1
pio_capture.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
30#ifndef PIO_CAPTURE_H
31#define PIO_CAPTURE_H
32
33/*----------------------------------------------------------------------------
34 * Types
35 *----------------------------------------------------------------------------*/
36
41typedef struct _SpioCaptureInit {
42
44 uint8_t dsize;
46 uint16_t dPDCsize;
48 uint32_t *pData;
52 uint8_t halfSampling;
56 void (*CbkDataReady)(struct _SpioCaptureInit *);
58 void (*CbkOverrun)(struct _SpioCaptureInit *);
62 void (*CbkBuffFull)(struct _SpioCaptureInit *);
64 void *pParam;
65
67
68
69/*----------------------------------------------------------------------------
70 * Global Functions
71 *----------------------------------------------------------------------------*/
72extern void PIO_CaptureDisableIt(uint32_t itToDisable);
73extern void PIO_CaptureEnableIt(uint32_t itToEnable);
74extern void PIO_CaptureEnable(void);
75extern void PIO_CaptureDisable(void);
76extern void PIO_CaptureInit(SpioCaptureInit *pInit);
77
78#endif /* #ifndef PIO_CAPTURE_H */
79
Disable the PIO Capture.
Definition: pio_capture.c:206
Initialize the PIO Capture.
Definition: pio_capture.c:232
Enable Interrupt of the PIO Capture.
Definition: pio_capture.c:178
Enable the PIO Capture.
Definition: pio_capture.c:189
Disable Interrupt of the PIO Capture.
Definition: pio_capture.c:166
PIO Parallel Capture structure for initialize.
Definition: pio_capture.h:41
uint16_t dPDCsize
Definition: pio_capture.h:46
Definition: pio_capture.h:52
void(* CbkOverrun)(struct _SpioCaptureInit *)
Definition: pio_capture.h:58
uint32_t * pData
Definition: pio_capture.h:48
void(* CbkBuffFull)(struct _SpioCaptureInit *)
Definition: pio_capture.h:62
void * pParam
Definition: pio_capture.h:64
void(* CbkEndReception)(struct _SpioCaptureInit *)
Definition: pio_capture.h:60
uint8_t dsize
Definition: pio_capture.h:44
uint8_t alwaysSampling
Definition: pio_capture.h:50
uint8_t modeFirstSample
Definition: pio_capture.h:54
void(* CbkDataReady)(struct _SpioCaptureInit *)
Definition: pio_capture.h:56
