RTEMS 5.2-rc1
Macros | Functions
pio_capture.c File Reference
#include "chip.h"
#include <assert.h>
#define PIO_PCISR_RXBUFF   (0x1u<<3)
#define PIO_PCISR_ENDRX   (0x1u<<2)
void PIO_CaptureHandler (void)
 The PIO_CaptureHandler must be called by the PIO Capture Interrupt Service Routine with the corresponding PIO Capture instance.
void PIO_CaptureDisableIt (uint32_t itToDisable)
 Disable Interrupt of the PIO Capture. More...
void PIO_CaptureEnableIt (uint32_t itToEnable)
 Enable Interrupt of the PIO Capture. More...
void PIO_CaptureEnable (void)
 Enable the PIO Capture.
void PIO_CaptureDisable (void)
 Disable the PIO Capture.
void PIO_CaptureInit (SpioCaptureInit *pInit)
 Initialize the PIO Capture. More...
Implementation of PIO Parallel Capture.
◆ PIO_CaptureDisableIt()
void PIO_CaptureDisableIt ( uint32_t  itToDisable)
Parameters
itToDisable: Interrupt to disable
◆ PIO_CaptureEnableIt()
void PIO_CaptureEnableIt ( uint32_t  itToEnable)
Parameters
itToEnable: Interrupt to enable
◆ PIO_CaptureInit()
void PIO_CaptureInit ( SpioCaptureInit pInit)
Parameters
dsize: 0 = The reception data in the PIO_PCRHR register is a BYTE (8-bit). 1 = The reception data in the PIO_PCRHR register is a HALF-WORD (16-bit). 2/3 = The reception data in the PIO_PCRHR register is a WORD (32-bit).
alwaysSamplingALWYS: Parallel Capture Mode Always Sampling 0 = The parallel capture mode samples the data when both data enables are active. 1 = The parallel capture mode samples the data whatever the data enables are.
halfSamplingHALFS: Parallel Capture Mode Half Sampling 0 = The parallel capture mode samples all the data. 1 = The parallel capture mode samples the data only one time out of two.
modeFirstSampleFRSTS: Parallel Capture Mode First Sample This bit is useful only if the HALFS bit is set to 1. If data are numbered in the order that they are received with an index from 0 to n: 0 = Only data with an even index are sampled. 1 = Only data with an odd index are sampled.
