RTEMS 5.2-rc1
pci_bus.h
1/* PCI bus driver Interface.
2 *
3 * COPYRIGHT (c) 2008 Cobham Gaisler AB.
4 *
5 * The license and distribution terms for this file may be
6 * found in the file LICENSE in this distribution or at
7 * http://www.rtems.org/license/LICENSE.
8 *
9 */
10
11/* General part of drvmgr PCI Bus driver. The driver is typically
12 * initialized from the PCI host driver separating the host
13 * driver from the common parts in PCI drivers.
14 * The PCI library must be initialized before starting the
15 * PCI bus driver. The PCI library have set up BARs and
16 * assigned system IRQs for targets.
17 * This PCI bus driver rely on the PCI library (pci.c) for
18 * interrupt registeration (pci_interrupt_register) and PCI
19 * target set up.
20 */
21
22#ifndef __PCI_BUS_H__
23#define __PCI_BUS_H__
24
25#include <drvmgr/drvmgr.h>
26#include <pci.h>
27#include <pci/access.h>
28
29#ifdef __cplusplus
30extern "C" {
31#endif
32
33/* PCI Driver ID generation (VENDOR: 16-bit, DEVICE: 16-bit) */
34#define DRIVER_PCI_ID(vendor, device) \
35 DRIVER_ID(DRVMGR_BUS_TYPE_PCI, \
36 ((((vendor) & 0xffff) << 16) | ((device) & 0xffff)))
37
38/* PCI Driver ID generation (CLASS: 24-bit) */
39#define DRIVER_PCI_CLASS(class) \
40 DRIVER_ID(DRVMGR_BUS_TYPE_PCI, ((1 << 32) | ((class) & 0xffffff)))
41
42/* PCI driver IDs (DRIVER_PCI_VENDOR_DEVICE or DRIVER_PCI_CLASS_NAME) */
43#define DRIVER_PCI_GAISLER_RASTAIO_ID DRIVER_PCI_ID(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_RASTA_IO)
44#define DRIVER_PCI_GAISLER_RASTATMTC_ID DRIVER_PCI_ID(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_RASTA_TMTC)
45#define DRIVER_PCI_GAISLER_GR701_ID DRIVER_PCI_ID(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_701)
46#define DRIVER_PCI_GAISLER_RASTAADCDAC_ID DRIVER_PCI_ID(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_RASTA_ADCDAC)
47#define DRIVER_PCI_GAISLER_TMTC_1553_ID DRIVER_PCI_ID(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_TMTC_1553)
48#define DRIVER_PCI_GAISLER_RASTA_SPW_ROUTER_ID DRIVER_PCI_ID(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_RASTA_SPW_RTR)
49#define DRIVER_PCI_GAISLER_LEON4_N2X_ID DRIVER_PCI_ID(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_LEON4_N2X)
50#define DRIVER_PCI_GAISLER_CPCI_GR740_ID DRIVER_PCI_ID(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_CPCI_GR740)
51
52struct pci_dev_id {
53 uint16_t vendor;
54 uint16_t device;
55 uint16_t subvendor;
56 uint16_t subdevice;
57 uint32_t class; /* 24 lower bits */
58};
59
61 uint16_t vendor;
62 uint16_t device;
63 uint16_t subvendor;
64 uint16_t subdevice;
65 uint32_t class; /* 24 lower bits */
66 uint32_t class_mask; /* 24 lower bits */
67};
68#define PCIID_DEVVEND(vendor, device) \
69 {vendor, device, PCI_ID_ANY, PCI_ID_ANY, 0, 0}
70#define PCIID_END_TABLE {0, 0, 0, 0, 0, 0}
71
72enum {
73 /* A Device has up to 6 BARs and an optional ROM BAR */
74 PCIDEV_RES_BAR1 = 0,
75 PCIDEV_RES_BAR2 = 1,
76 PCIDEV_RES_BAR3 = 2,
77 PCIDEV_RES_BAR4 = 3,
78 PCIDEV_RES_BAR5 = 4,
79 PCIDEV_RES_BAR6 = 5,
80 PCIDEV_RES_ROM = 6,
81};
82/* Maximum Number of Resources of a device */
83#define PCIDEV_RES_CNT (PCIDEV_RES_ROM + 1)
84
85/* IO, MEMIO or MEM resource. Can be BAR, ROM or Bridge Window */
86struct pcibus_res {
87 uint32_t address; /* Base Address, CPU accessible */
88 uint32_t size; /* 0=Unimplemented, 0!=Resource Size */
89 struct pci_res *res; /* PCI-layer resource */
90};
91
93 struct pci_dev_id id;
94 uint8_t rev;
95 uint8_t irq; /* 0 = NO IRQ */
96 pci_dev_t pcidev;
97 struct pcibus_res resources[PCIDEV_RES_CNT];
98 struct pci_dev *pci_device;
99};
100
102 struct drvmgr_drv general; /* General bus info */
103 /* PCI specific bus information */
104 struct pci_dev_id_match *ids; /* Supported hardware */
105};
106
107/* Access routines */
109 drvmgr_r8 r8;
110 drvmgr_r16 r16;
111 drvmgr_r32 r32;
112 drvmgr_r64 r64;
113 drvmgr_w8 w8;
114 drvmgr_w16 w16;
115 drvmgr_w32 w32;
116 drvmgr_w64 w64;
117};
118
119/* Let driver configure PCI bus driver */
121 struct drvmgr_map_entry *maps_up;
122 struct drvmgr_map_entry *maps_down;
123};
124
125/* PCI Configuration Space Access - Not implemented (use PCI Lib directly) */
126#define PCI_FUNC_CFG_R8 DRVMGR_RWFUNC(RW_SIZE_1|RW_READ|RW_CFG)
127#define PCI_FUNC_CFG_R16 DRVMGR_RWFUNC(RW_SIZE_2|RW_READ|RW_CFG)
128#define PCI_FUNC_CFG_R32 DRVMGR_RWFUNC(RW_SIZE_4|RW_READ|RW_CFG)
129#define PCI_FUNC_CFG_W8 DRVMGR_RWFUNC(RW_SIZE_1|RW_WRITE|RW_CFG)
130#define PCI_FUNC_CFG_W16 DRVMGR_RWFUNC(RW_SIZE_2|RW_WRITE|RW_CFG)
131#define PCI_FUNC_CFG_W32 DRVMGR_RWFUNC(RW_SIZE_4|RW_WRITE|RW_CFG)
132
133/* PCI I/O Register Access - Not implemented (use PCI Lib directly) */
134#define PCI_FUNC_IO_R8 DRVMGR_RWFUNC(RW_SIZE_1|RW_READ|RW_IO)
135#define PCI_FUNC_IO_R16 DRVMGR_RWFUNC(RW_SIZE_2|RW_READ|RW_IO)
136#define PCI_FUNC_IO_R32 DRVMGR_RWFUNC(RW_SIZE_4|RW_READ|RW_IO)
137#define PCI_FUNC_IO_W8 DRVMGR_RWFUNC(RW_SIZE_1|RW_WRITE|RW_IO)
138#define PCI_FUNC_IO_W16 DRVMGR_RWFUNC(RW_SIZE_2|RW_WRITE|RW_IO)
139#define PCI_FUNC_IO_W32 DRVMGR_RWFUNC(RW_SIZE_4|RW_WRITE|RW_IO)
140
141/* PCI Register Access over Memory Space (Little Endian) */
142#define PCI_FUNC_MREG_R8 DRVMGR_RWFUNC(RW_SIZE_1|RW_READ|RW_MEMREG)
143#define PCI_FUNC_MREG_R16 DRVMGR_RWFUNC(RW_SIZE_2|RW_READ|RW_MEMREG|RW_LITTLE)
144#define PCI_FUNC_MREG_R32 DRVMGR_RWFUNC(RW_SIZE_4|RW_READ|RW_MEMREG|RW_LITTLE)
145#define PCI_FUNC_MREG_W8 DRVMGR_RWFUNC(RW_SIZE_1|RW_WRITE|RW_MEMREG)
146#define PCI_FUNC_MREG_W16 DRVMGR_RWFUNC(RW_SIZE_2|RW_WRITE|RW_MEMREG|RW_LITTLE)
147#define PCI_FUNC_MREG_W32 DRVMGR_RWFUNC(RW_SIZE_4|RW_WRITE|RW_MEMREG|RW_LITTLE)
148
149/* Weak default PCI driver resources, override this from project configuration
150 * to set PCI Bus resources used to configure PCI device drivers.
151 */
152extern struct drvmgr_bus_res pcibus_drv_resources;
153
154/* Attach a PCI bus on top of a PCI Host device */
155extern int pcibus_register(struct drvmgr_dev *dev, struct pcibus_config *cfg);
156
157#ifdef __cplusplus
158}
159#endif
160
161#endif
Definition: rtemscompat1.h:15
Definition: drvmgr.h:214
Definition: drvmgr.h:273
Definition: drvmgr.h:303
Definition: drvmgr.h:225
Definition: pci_bus.h:60
Definition: pci_bus.h:52
Definition: pci_bus.h:92
Definition: pci.h:41
Definition: pci_bus.h:101
Definition: cfg.h:144
Definition: pci_bus.h:120
Definition: pci_bus.h:108
Definition: pci_bus.h:86
