RTEMS
5.2-rc1
bsps
include
libchip
ns16550_p.h
1
6
7
* COPYRIGHT (c) 1998 by Radstone Technology
8
9
10
* THIS FILE IS PROVIDED TO YOU, THE USER, "AS IS", WITHOUT WARRANTY OF ANY
11
* KIND, EITHER EXPRESSED OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, THE
12
* IMPLIED WARRANTY OF FITNESS FOR A PARTICULAR PURPOSE. THE ENTIRE RISK
13
* AS TO THE QUALITY AND PERFORMANCE OF ALL CODE IN THIS FILE IS WITH YOU.
14
15
* You are hereby granted permission to use, copy, modify, and distribute
16
* this file, provided that this notice, plus the above copyright notice
17
* and disclaimer, appears in all copies. Radstone Technology will provide
18
* no support for this code.
19
20
* COPYRIGHT (c) 1989-2012.
21
* On-Line Applications Research Corporation (OAR).
22
23
* The license and distribution terms for this file may be
24
* found in the file LICENSE in this distribution or at
25
* http://www.rtems.org/license/LICENSE.
26
27
28
#ifndef _NS16550_P_H_
29
#define _NS16550_P_H_
30
31
#ifndef ASM
32
libchip/serial.h
33
#endif
34
35
#ifdef __cplusplus
36
extern
"C"
37
#endif
38
39
40
* Define NS16550_STATIC to nothing while debugging so the entry points
41
* will show up in the symbol table.
42
43
44
#define NS16550_STATIC static
45
46
#define NS16550_RECEIVE_BUFFER 0
47
#define NS16550_TRANSMIT_BUFFER 0
48
#define NS16550_DIVISOR_LATCH_L 0
49
#define NS16550_INTERRUPT_ENABLE 1
50
#define NS16550_DIVISOR_LATCH_M 1
51
#define NS16550_INTERRUPT_ID 2
52
#define NS16550_FIFO_CONTROL 2
53
#define NS16550_LINE_CONTROL 3
54
#define NS16550_MODEM_CONTROL 4
55
#define NS16550_LINE_STATUS 5
56
#define NS16550_MODEM_STATUS 6
57
#define NS16550_SCRATCH_PAD 7
58
#define NS16550_FRACTIONAL_DIVIDER 10
59
60
61
* Define serial port interrupt enable register structure.
62
63
64
#define SP_INT_RX_ENABLE 0x01
65
#define SP_INT_TX_ENABLE 0x02
66
#define SP_INT_LS_ENABLE 0x04
67
#define SP_INT_MS_ENABLE 0x08
68
69
#define NS16550_ENABLE_ALL_INTR (SP_INT_RX_ENABLE | SP_INT_TX_ENABLE)
70
#define NS16550_DISABLE_ALL_INTR 0x00
71
#define NS16550_ENABLE_ALL_INTR_EXCEPT_TX (SP_INT_RX_ENABLE)
72
73
74
* Define serial port interrupt ID register structure.
75
76
77
#define SP_IID_0 0x01
78
#define SP_IID_1 0x02
79
#define SP_IID_2 0x04
80
#define SP_IID_3 0x08
81
82
83
* Define serial port fifo control register structure.
84
85
86
#define SP_FIFO_ENABLE 0x01
87
#define SP_FIFO_RXRST 0x02
88
#define SP_FIFO_TXRST 0x04
89
#define SP_FIFO_DMA 0x08
90
#define SP_FIFO_RXLEVEL 0xc0
91
92
#define SP_FIFO_SIZE 16
93
94
95
* Define serial port line control register structure.
96
97
98
#define SP_LINE_SIZE 0x03
99
#define SP_LINE_STOP 0x04
100
#define SP_LINE_PAR 0x08
101
#define SP_LINE_ODD 0x10
102
#define SP_LINE_STICK 0x20
103
#define SP_LINE_BREAK 0x40
104
#define SP_LINE_DLAB 0x80
105
106
107
* Line status register character size definitions.
108
109
110
#define FIVE_BITS 0x0
/* five bits per character */
111
#define SIX_BITS 0x1
/* six bits per character */
112
#define SEVEN_BITS 0x2
/* seven bits per character */
113
#define EIGHT_BITS 0x3
/* eight bits per character */
114
115
116
* Define serial port modem control register structure.
117
118
119
#define SP_MODEM_DTR 0x01
120
#define SP_MODEM_RTS 0x02
121
#define SP_MODEM_IRQ 0x08
122
#define SP_MODEM_LOOP 0x10
123
#define SP_MODEM_DIV4 0x80
124
125
126
* Define serial port line status register structure.
127
128
129
#define SP_LSR_RDY 0x01
130
#define SP_LSR_EOVRUN 0x02
131
#define SP_LSR_EPAR 0x04
132
#define SP_LSR_EFRAME 0x08
133
#define SP_LSR_BREAK 0x10
134
#define SP_LSR_THOLD 0x20
135
#define SP_LSR_TX 0x40
136
#define SP_LSR_EFIFO 0x80
137
138
#ifdef __cplusplus
139
140
#endif
141
142
#endif
/* _NS16550_P_H_ */
serial.h
The generic libchip serial driver interface.
