RTEMS 5.2-rc1
#include <chip.h>Functions | |
| void | MPU_Enable (uint32_t dwMPUEnable) |
| Enables the MPU module. More... | |
| void | MPU_SetRegionNum (uint32_t dwRegionNum) |
| Set active memory region. More... | |
| void | MPU_DisableRegion (void) |
| Disable the current active region. | |
| void | MPU_SetRegion (uint32_t dwRegionBaseAddr, uint32_t dwRegionAttr) |
| Setup a memory region. More... | |
| uint32_t | MPU_CalMPURegionSize (uint32_t dwActualSizeInBytes) |
| Calculate region size for the RASR. | |
| void | MPU_UpdateRegions (uint32_t dwRegionNum, uint32_t dwRegionBaseAddr, uint32_t dwRegionAttr) |
| Update MPU regions. More... | |
| void MPU_Enable | ( | uint32_t | dwMPUEnable | ) |
| dwMPUEnable | Enable/Disable the memory region. |
| void MPU_SetRegion | ( | uint32_t | dwRegionBaseAddr, |
| uint32_t | dwRegionAttr | ||
| dwRegionBaseAddr | Memory region base address. |
| dwRegionAttr | Memory region attributes. |
| void MPU_SetRegionNum | ( | uint32_t | dwRegionNum | ) |
| dwRegionNum | The memory region to be active. |
| void MPU_UpdateRegions | ( | uint32_t | dwRegionNum, |
| uint32_t | dwRegionBaseAddr, | ||
Update MPU regions.
