RTEMS 5.2-rc1
mppkt.h
1
15/*
16 * COPYRIGHT (c) 1989-2011.
17 * On-Line Applications Research Corporation (OAR).
18 *
19 * The license and distribution terms for this file may be
20 * found in the file LICENSE in this distribution or at
21 * http://www.rtems.org/license/LICENSE.
22 */
23
24#ifndef _RTEMS_SCORE_MPPKT_H
25#define _RTEMS_SCORE_MPPKT_H
26
27#include <rtems/score/object.h>
30
31#ifdef __cplusplus
32extern "C" {
33#endif
34
56typedef enum {
57 MP_PACKET_MPCI_INTERNAL = 0,
58 MP_PACKET_TASKS = 1,
59 MP_PACKET_MESSAGE_QUEUE = 2,
60 MP_PACKET_SEMAPHORE = 3,
61 MP_PACKET_PARTITION = 4,
62 MP_PACKET_REGION = 5,
63 MP_PACKET_EVENT = 6,
64 MP_PACKET_SIGNAL = 7
66
70#define MP_PACKET_CLASSES_FIRST MP_PACKET_MPCI_INTERNAL
71
75#define MP_PACKET_CLASSES_LAST MP_PACKET_SIGNAL
76
85typedef struct {
95 uint32_t return_code;
97 uint32_t length;
99 uint32_t to_convert;
103
107#define MP_PACKET_MINIMUM_PACKET_SIZE 64
108
116#define MP_PACKET_MINIMUN_HETERO_CONVERSION \
117 ( sizeof( MP_packet_Prefix ) / sizeof( uint32_t ) )
118
121#ifdef __cplusplus
122}
123#endif
124
125#endif
126/* end of include file */
MP_packet_Classes
Definition: mppkt.h:56
uint32_t Objects_Id
Definition: object.h:80
uint32_t Watchdog_Interval
Type is used to specify the length of intervals.
Definition: watchdogticks.h:38
Priority Handler API.
Constants and Structures Associated with the Object Handler.
Definition: mppkt.h:85
Objects_Id source_tid
Definition: mppkt.h:91
uint32_t source_priority
Definition: mppkt.h:93
Objects_Id id
Definition: mppkt.h:89
MP_packet_Classes the_class
Definition: mppkt.h:87
uint32_t to_convert
Definition: mppkt.h:99
Watchdog_Interval timeout
Definition: mppkt.h:101
uint32_t length
Definition: mppkt.h:97
Definition: mppkt.h:95
Constants for the watchdog ticks.
