RTEMS 5.2-rc1
Files | Data Structures | Macros | Enumerations
MP Packet Handler
MP Packte Handler. More...
file  mppkt.h
 Specification for the Packet Handler.
struct  MP_packet_Prefix
#define MP_PACKET_CLASSES_FIRST   MP_PACKET_MPCI_INTERNAL
#define MP_PACKET_CLASSES_LAST   MP_PACKET_SIGNAL
#define MP_PACKET_MINIMUM_PACKET_SIZE   64
#define MP_PACKET_MINIMUN_HETERO_CONVERSION    ( sizeof( MP_packet_Prefix ) / sizeof( uint32_t ) )
enum  MP_packet_Classes {
  MP_PACKET_MPCI_INTERNAL = 0 , MP_PACKET_TASKS = 1 , MP_PACKET_MESSAGE_QUEUE = 2 , MP_PACKET_SEMAPHORE = 3 ,
  MP_PACKET_PARTITION = 4 , MP_PACKET_REGION = 5 , MP_PACKET_EVENT = 6 , MP_PACKET_SIGNAL = 7
MP Packte Handler.
This handler encapsulates the primary definition of MPCI packets. This handler defines the part of the packet that is common to all remote operations.
◆ MP_PACKET_CLASSES_FIRST
This constant defines the first entry in the MP_packet_Classes enumeration.
◆ MP_PACKET_CLASSES_LAST
This constant defines the last entry in the MP_packet_Classes enumeration.
◆ MP_PACKET_MINIMUM_PACKET_SIZE
An MPCI must support packets of at least this size.
◆ MP_PACKET_MINIMUN_HETERO_CONVERSION
The following constant defines the number of uint32_t's in a packet which must be converted to native format in a heterogeneous system. In packets longer than MP_PACKET_MINIMUN_HETERO_CONVERSION uint32_t's, some of the "extra" data may a user message buffer which is not automatically endian swapped.
◆ MP_packet_Classes
The following enumerated type defines the packet classes.
Note
In general, each class corresponds to a manager which supports global operations. Each manager defines the set of supported operations.
