RTEMS 5.2-rc1
mon-command.c File Reference
Command support routines for RTEMS monitor. More...
#include <rtems/monitor.h>
struct  rtems_monitor_command_lookup_entry
#define MAX_HELP_LINE_LENGTH   (75 - max_cmd_len - 2)
void rtems_monitor_command_usage (const rtems_monitor_command_entry_t *table, const char *command_name)
void rtems_monitor_help_cmd (int argc, char **argv, const rtems_monitor_command_arg_t *command_arg, bool verbose RTEMS_UNUSED)
const rtems_monitor_command_entry_trtems_monitor_command_lookup (const char *name)
 Looks for a command with the name name in the list of registered commands. More...
◆ rtems_monitor_command_lookup()
const rtems_monitor_command_entry_t * rtems_monitor_command_lookup ( const char *  name)
The parameter name must not be NULL.
Returns the corresponding command entry or NULL if no command is found.
