RTEMS 5.2-rc1
tm27.h File Reference
#include <bsp/irq.h>
#define MUST_WAIT_FOR_INTERRUPT   1
#define Install_tm27_vector(handler)
#define Cause_tm27_intr()
#define Clear_tm27_intr()
#define Lower_tm27_intr()    mips_enable_in_interrupt_mask( 0xff01 );
◆ Cause_tm27_intr
#define Cause_tm27_intr (   void)
Value:
do { \
uint32_t _clicks = 20; \
TX3904_TIMER_WRITE( TX3904_TIMER0_BASE, TX3904_TIMER_CCDR, 0x3 ); \
TX3904_TIMER_WRITE( TX3904_TIMER0_BASE, TX3904_TIMER_CPRA, _clicks ); \
TX3904_TIMER_WRITE( TX3904_TIMER0_BASE, TX3904_TIMER_TISR, 0x00 ); \
TX3904_TIMER_WRITE( TX3904_TIMER0_BASE, TX3904_TIMER_ITMR, 0x8001 ); \
TX3904_TIMER_WRITE( TX3904_TIMER0_BASE, TX3904_TIMER_TCR, 0xC0 ); \
*((volatile uint32_t*) 0xFFFFC01C) = 0x00000700; \
} while(0)
◆ Clear_tm27_intr
#define Clear_tm27_intr (   void)
Value:
do { \
TX3904_TIMER_WRITE( TX3904_TIMER0_BASE, TX3904_TIMER_ITMR, 0x0001 ); \
} while(0)
◆ Install_tm27_vector
#define Install_tm27_vector (   handler)
Value:
TX3904_IRQ_TMR0, "benchmark", 0, \
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
rtems_status_code rtems_interrupt_handler_install(rtems_vector_number vector, const char *info, rtems_option options, rtems_interrupt_handler handler, void *arg)
Installs the interrupt handler routine handler for the interrupt vector with number vector.
Definition: irq.c:127
void(* rtems_interrupt_handler)(void *)
Interrupt handler routine type.
Definition: irq-extension.h:79
