RTEMS
5.2-rc1
bsps
m68k
include
mcf548x
mcdma_glue.h
1
2
| Project: RTEMS generic MFC548x BSP |
3
4
| Copyright (c) 2004-2009 |
5
| Embedded Brains GmbH |
6
| Obere Lagerstr. 30 |
7
| D-82178 Puchheim |
8
| Germany |
9
| rtems@embedded-brains.de |
10
11
| The license and distribution terms for this file may be |
12
| found in the file LICENSE in this distribution or at |
13
14
| http://www.rtems.org/license/LICENSE. |
15
16
17
| this file declares glue functions to the Freescale Mcdma API |
18
19
#ifndef _MCDMA_GLUE_H
20
#define _MCDMA_GLUE_H
21
22
rtems.h
23
rtems/irq.h
24
#include <mcf548x/mcf548x.h>
25
26
#define MCDMA_CLR_PENDING(chan) (MCF548X_DMA_DIPR = (1 << (chan)))
27
#define MCDMA_GET_PENDING(chan) (MCF548X_DMA_DIPR & (1 << (chan)))
28
29
30
| Function: |
31
32
void
mcdma_glue_irq_enable
33
34
35
| Purpose: |
36
| enable interrupt for given task number |
37
38
| Input Parameters: |
39
40
int
mcdma_taskno
/* task number to enable */
41
42
43
| Return Value: |
44
| none |
45
46
47
48
| Function: |
49
50
void
mcdma_glue_irq_disable
51
52
53
| Purpose: |
54
| disable interrupt for given task number |
55
56
| Input Parameters: |
57
58
int
mcdma_taskno
/* task number to disable */
59
60
61
| Return Value: |
62
| none |
63
64
65
66
| Function: |
67
68
void
mcdma_glue_irq_install
69
70
71
| Purpose: |
72
| install given function as mcdma interrupt handler |
73
74
| Input Parameters: |
75
76
int
mcdma_taskno,
/* task number for handler */
77
void
(*the_handler)(rtems_irq_hdl_param),
/* function to call */
78
void
*the_param
79
80
81
| Return Value: |
82
| none |
83
84
85
86
| Function: |
87
88
void
mcdma_glue_init
89
90
91
| Purpose: |
92
| initialize the mcdma module (if not yet done): |
93
| - load code |
94
| - initialize registers |
95
| - initialize bus arbiter |
96
| - initialize interrupt control |
97
98
| Input Parameters: |
99
100
void
*sram_base
/* base address for SRAM, to be used for DMA task */
101
102
103
| Return Value: |
104
| none |
105
106
107
#endif
/* _MCDMA_GLUE_H */
irq.h
rtems.h
