RTEMS 5.2-rc1
Data Structures | Typedefs | Functions
irq.h File Reference
struct  __rtems_irq_connect_data__
struct  rtems_irq_global_settings
typedef unsigned char rtems_irq_prio
typedef unsigned int rtems_irq_number
typedef void * rtems_irq_hdl_param
typedef void(* rtems_irq_hdl) (rtems_irq_hdl_param)
typedef void(* rtems_irq_enable) (const struct __rtems_irq_connect_data__ *)
typedef void(* rtems_irq_disable) (const struct __rtems_irq_connect_data__ *)
typedef int(* rtems_irq_is_enabled) (const struct __rtems_irq_connect_data__ *)
typedef struct __rtems_irq_connect_data__ rtems_irq_connect_data
int BSP_install_rtems_irq_handler (const rtems_irq_connect_data *)
int BSP_get_current_rtems_irq_handler (rtems_irq_connect_data *ptr)
int BSP_remove_rtems_irq_handler (const rtems_irq_connect_data *)
int BSP_rtems_int_connect (rtems_irq_number n, rtems_irq_hdl hdl, rtems_irq_hdl_param p)
int BSP_rtems_int_disconnect (rtems_irq_number n, rtems_irq_hdl hdl, rtems_irq_hdl_param p)
int BSP_rtems_irq_mngt_set (rtems_irq_global_settings *config)
int BSP_rtems_irq_mngt_get (rtems_irq_global_settings **)
This include file describe the data structure and the functions implemented by rtems to write interrupt handlers.
◆ BSP_get_current_rtems_irq_handler()
int BSP_get_current_rtems_irq_handler ( rtems_irq_connect_data cd)
Deprecated:
Obsolete.
◆ BSP_install_rtems_irq_handler()
int BSP_install_rtems_irq_handler ( const rtems_irq_connect_data cd)
◆ BSP_remove_rtems_irq_handler()
int BSP_remove_rtems_irq_handler ( const rtems_irq_connect_data cd)
◆ BSP_rtems_irq_mngt_get()
int BSP_rtems_irq_mngt_get ( rtems_irq_global_settings **  config)
Deprecated:
Obsolete.
◆ BSP_rtems_irq_mngt_set()
int BSP_rtems_irq_mngt_set ( rtems_irq_global_settings config)
