RTEMS 5.2-rc1
lpc32xx.h
1
9/*
10 * Copyright (c) 2009, 2010
11 * embedded brains GmbH
12 * Obere Lagerstr. 30
13 * D-82178 Puchheim
14 * Germany
15 * <rtems@embedded-brains.de>
16 *
17 * The license and distribution terms for this file may be
18 * found in the file LICENSE in this distribution or at
19 * http:
20 */
21
22#ifndef LIBBSP_ARM_LPC32XX_LPC32XX_H
23#define LIBBSP_ARM_LPC32XX_LPC32XX_H
24
25#include <stdint.h>
26
27#include <bsp/utility.h>
28#include <bsp/lpc-timer.h>
29#include <bsp/lpc-dma.h>
30#include <bsp/lpc-i2s.h>
31#include <bsp/lpc-emc.h>
32
49#define LPC32XX_BASE_ADC 0x40048000
50#define LPC32XX_BASE_SYSCON 0x40004000
51#define LPC32XX_BASE_DEBUG_CTRL 0x40040000
52#define LPC32XX_BASE_DMA 0x31000000
53#define LPC32XX_BASE_EMC 0x31080000
54#define LPC32XX_BASE_EMC_CS_0 0xe0000000
55#define LPC32XX_BASE_EMC_CS_1 0xe1000000
56#define LPC32XX_BASE_EMC_CS_2 0xe2000000
57#define LPC32XX_BASE_EMC_CS_3 0xe3000000
58#define LPC32XX_BASE_EMC_DYCS_0 0x80000000
59#define LPC32XX_BASE_EMC_DYCS_1 0xa0000000
60#define LPC32XX_BASE_ETB_CFG 0x310c0000
61#define LPC32XX_BASE_ETB_DATA 0x310e0000
62#define LPC32XX_BASE_ETHERNET 0x31060000
63#define LPC32XX_BASE_GPIO 0x40028000
64#define LPC32XX_BASE_I2C_1 0x400a0000
65#define LPC32XX_BASE_I2C_2 0x400a8000
66#define LPC32XX_BASE_I2S_0 0x20094000
67#define LPC32XX_BASE_I2S_1 0x2009c000
68#define LPC32XX_BASE_IRAM 0x08000000
69#define LPC32XX_BASE_IROM 0x0c000000
70#define LPC32XX_BASE_KEYSCAN 0x40050000
71#define LPC32XX_BASE_LCD 0x31040000
72#define LPC32XX_BASE_MCPWM 0x400e8000
73#define LPC32XX_BASE_MIC 0x40008000
74#define LPC32XX_BASE_NAND_MLC 0x200a8000
75#define LPC32XX_BASE_NAND_SLC 0x20020000
76#define LPC32XX_BASE_PWM_1 0x4005c000
77#define LPC32XX_BASE_PWM_2 0x4005c004
78#define LPC32XX_BASE_PWM_3 0x4002c000
79#define LPC32XX_BASE_PWM_4 0x40030000
80#define LPC32XX_BASE_RTC 0x40024000
81#define LPC32XX_BASE_RTC_RAM 0x40024080
82#define LPC32XX_BASE_SDCARD 0x20098000
83#define LPC32XX_BASE_SIC_1 0x4000c000
84#define LPC32XX_BASE_SIC_2 0x40010000
85#define LPC32XX_BASE_SPI_1 0x20088000
86#define LPC32XX_BASE_SPI_2 0x20090000
87#define LPC32XX_BASE_SSP_0 0x20084000
88#define LPC32XX_BASE_SSP_1 0x2008c000
89#define LPC32XX_BASE_TIMER_0 0x40044000
90#define LPC32XX_BASE_TIMER_1 0x4004c000
91#define LPC32XX_BASE_TIMER_2 0x40058000
92#define LPC32XX_BASE_TIMER_3 0x40060000
93#define LPC32XX_BASE_TIMER_5 0x4002c000
94#define LPC32XX_BASE_TIMER_6 0x40030000
95#define LPC32XX_BASE_TIMER_HS 0x40038000
96#define LPC32XX_BASE_TIMER_MS 0x40034000
97#define LPC32XX_BASE_UART_1 0x40014000
98#define LPC32XX_BASE_UART_2 0x40018000
99#define LPC32XX_BASE_UART_3 0x40080000
100#define LPC32XX_BASE_UART_4 0x40088000
101#define LPC32XX_BASE_UART_5 0x40090000
102#define LPC32XX_BASE_UART_6 0x40098000
103#define LPC32XX_BASE_UART_7 0x4001c000
104#define LPC32XX_BASE_USB 0x31020000
105#define LPC32XX_BASE_USB_OTG_I2C 0x31020300
106#define LPC32XX_BASE_WDT 0x4003c000
107
116#define LPC32XX_U3CLK (*(volatile uint32_t *) 0x400040d0)
117#define LPC32XX_U4CLK (*(volatile uint32_t *) 0x400040d4)
118#define LPC32XX_U5CLK (*(volatile uint32_t *) 0x400040d8)
119#define LPC32XX_U6CLK (*(volatile uint32_t *) 0x400040dc)
120#define LPC32XX_IRDACLK (*(volatile uint32_t *) 0x400040e0)
121#define LPC32XX_UART_CTRL (*(volatile uint32_t *) 0x40054000)
122#define LPC32XX_UART_CLKMODE (*(volatile uint32_t *) 0x40054004)
123#define LPC32XX_UART_LOOP (*(volatile uint32_t *) 0x40054008)
124#define LPC32XX_SW_INT (*(volatile uint32_t *) 0x400040a8)
125#define LPC32XX_MAC_CLK_CTRL (*(volatile uint32_t *) 0x40004090)
126#define LPC32XX_USB_DIV (*(volatile uint32_t *) 0x4000401c)
127#define LPC32XX_OTG_CLK_CTRL (*(volatile uint32_t *) 0x31020ff4)
128#define LPC32XX_OTG_CLK_STAT (*(volatile uint32_t *) 0x31020ff8)
129#define LPC32XX_OTG_STAT_CTRL (*(volatile uint32_t *) 0x31020110)
130#define LPC32XX_I2C_RX (*(volatile uint32_t *) 0x31020300)
131#define LPC32XX_I2C_TX (*(volatile uint32_t *) 0x31020300)
132#define LPC32XX_I2C_STS (*(volatile uint32_t *) 0x31020304)
133#define LPC32XX_I2C_CTL (*(volatile uint32_t *) 0x31020308)
134#define LPC32XX_I2C_CLKHI (*(volatile uint32_t *) 0x3102030c)
135#define LPC32XX_I2C_CLKLO (*(volatile uint32_t *) 0x31020310)
136#define LPC32XX_PWR_CTRL (*(volatile uint32_t *) 0x40004044)
137#define LPC32XX_OSC_CTRL (*(volatile uint32_t *) 0x4000404c)
138#define LPC32XX_SYSCLK_CTRL (*(volatile uint32_t *) 0x40004050)
139#define LPC32XX_PLL397_CTRL (*(volatile uint32_t *) 0x40004048)
140#define LPC32XX_HCLKPLL_CTRL (*(volatile uint32_t *) 0x40004058)
141#define LPC32XX_HCLKDIV_CTRL (*(volatile uint32_t *) 0x40004040)
142#define LPC32XX_TEST_CLK (*(volatile uint32_t *) 0x400040a4)
143#define LPC32XX_AUTOCLK_CTRL (*(volatile uint32_t *) 0x400040ec)
144#define LPC32XX_START_ER_PIN (*(volatile uint32_t *) 0x40004030)
145#define LPC32XX_START_ER_INT (*(volatile uint32_t *) 0x40004020)
146#define LPC32XX_P0_INTR_ER (*(volatile uint32_t *) 0x40004018)
147#define LPC32XX_START_SR_PIN (*(volatile uint32_t *) 0x40004038)
148#define LPC32XX_START_SR_INT (*(volatile uint32_t *) 0x40004028)
149#define LPC32XX_START_RSR_PIN (*(volatile uint32_t *) 0x40004034)
150#define LPC32XX_START_RSR_INT (*(volatile uint32_t *) 0x40004024)
151#define LPC32XX_START_APR_PIN (*(volatile uint32_t *) 0x4000403c)
152#define LPC32XX_START_APR_INT (*(volatile uint32_t *) 0x4000402c)
153#define LPC32XX_USB_CTRL (*(volatile uint32_t *) 0x40004064)
154#define LPC32XX_USBDIV_CTRL (*(volatile uint32_t *) 0x4000401c)
155#define LPC32XX_MS_CTRL (*(volatile uint32_t *) 0x40004080)
156#define LPC32XX_DMACLK_CTRL (*(volatile uint32_t *) 0x400040e8)
157#define LPC32XX_FLASHCLK_CTRL (*(volatile uint32_t *) 0x400040c8)
158#define LPC32XX_MACCLK_CTRL (*(volatile uint32_t *) 0x40004090)
159#define LPC32XX_LCDCLK_CTRL (*(volatile uint32_t *) 0x40004054)
160#define LPC32XX_I2S_CTRL (*(volatile uint32_t *) 0x4000407c)
161#define LPC32XX_SSP_CTRL (*(volatile uint32_t *) 0x40004078)
162#define LPC32XX_SPI_CTRL (*(volatile uint32_t *) 0x400040c4)
163#define LPC32XX_I2CCLK_CTRL (*(volatile uint32_t *) 0x400040ac)
164#define LPC32XX_TIMCLK_CTRL1 (*(volatile uint32_t *) 0x400040c0)
165#define LPC32XX_TIMCLK_CTRL (*(volatile uint32_t *) 0x400040bc)
166#define LPC32XX_ADCLK_CTRL (*(volatile uint32_t *) 0x400040b4)
167#define LPC32XX_ADCLK_CTRL1 (*(volatile uint32_t *) 0x40004060)
168#define LPC32XX_KEYCLK_CTRL (*(volatile uint32_t *) 0x400040b0)
169#define LPC32XX_PWMCLK_CTRL (*(volatile uint32_t *) 0x400040b8)
170#define LPC32XX_UARTCLK_CTRL (*(volatile uint32_t *) 0x400040e4)
171#define LPC32XX_POS0_IRAM_CTRL (*(volatile uint32_t *) 0x40004110)
172#define LPC32XX_POS1_IRAM_CTRL (*(volatile uint32_t *) 0x40004114)
173#define LPC32XX_SDRAMCLK_CTRL (*(volatile uint32_t *) 0x40004068)
174
183#define PWR_STOP BSP_BIT32(0)
184#define PWR_HIGHCORE_ALWAYS BSP_BIT32(1)
185#define PWR_NORMAL_RUN_MODE BSP_BIT32(2)
186#define PWR_SYSCLKEN_ALWAYS BSP_BIT32(3)
187#define PWR_SYSCLKEN_HIGH BSP_BIT32(4)
188#define PWR_HIGHCORE_HIGH BSP_BIT32(5)
189#define PWR_SDRAM_AUTO_REFRESH BSP_BIT32(7)
190#define PWR_UPDATE_EMCSREFREQ BSP_BIT32(8)
191#define PWR_EMCSREFREQ BSP_BIT32(9)
192#define PWR_HCLK_USES_PERIPH_CLK BSP_BIT32(10)
193
202#define HCLK_PLL_LOCK BSP_BIT32(0)
203#define HCLK_PLL_M(val) BSP_FLD32(val, 1, 8)
204#define HCLK_PLL_M_GET(reg) BSP_FLD32GET(reg, 1, 8)
205#define HCLK_PLL_N(val) BSP_FLD32(val, 9, 10)
206#define HCLK_PLL_N_GET(reg) BSP_FLD32GET(reg, 9, 10)
207#define HCLK_PLL_P(val) BSP_FLD32(val, 11, 12)
208#define HCLK_PLL_P_GET(reg) BSP_FLD32GET(reg, 11, 12)
209#define HCLK_PLL_FBD_FCLKOUT BSP_BIT32(13)
210#define HCLK_PLL_DIRECT BSP_BIT32(14)
211#define HCLK_PLL_BYPASS BSP_BIT32(15)
212#define HCLK_PLL_POWER BSP_BIT32(16)
213
222#define HCLK_DIV_HCLK(val) BSP_FLD32(val, 0, 1)
223#define HCLK_DIV_HCLK_GET(reg) BSP_FLD32GET(reg, 0, 1)
224#define HCLK_DIV_PERIPH_CLK(val) BSP_FLD32(val, 2, 6)
225#define HCLK_DIV_PERIPH_CLK_GET(reg) BSP_FLD32GET(reg, 2, 6)
226#define HCLK_DIV_DDRAM_CLK(val) BSP_FLD32(val, 7, 8)
227#define HCLK_DIV_DDRAM_CLK_GET(reg) BSP_FLD32GET(reg, 7, 8)
228
237#define TIMCLK_CTRL_WDT BSP_BIT32(0)
238#define TIMCLK_CTRL_HST BSP_BIT32(1)
239
242#define LPC32XX_FILL(a, b, s) uint8_t reserved_ ## b [b - a - sizeof(s)]
243#define LPC32XX_RESERVE(a, b) uint8_t reserved_ ## b [b - a]
244
245typedef struct {
247
248typedef struct {
250
251typedef struct {
253
254typedef struct {
256
257typedef struct {
259
260typedef struct {
262
263typedef struct {
265
266typedef struct {
268
269typedef struct {
271
272typedef struct {
274
275typedef struct {
277
278typedef struct {
280
287#define WDTTIM_INT_MATCH_INT BSP_BIT32(0)
288
297#define WDTTIM_CTRL_COUNT_ENAB BSP_BIT32(0)
298#define WDTTIM_CTRL_RESET_COUNT BSP_BIT32(1)
299#define WDTTIM_CTRL_PAUSE_EN BSP_BIT32(2)
300
309#define WDTTIM_MCTRL_MR0_INT BSP_BIT32(0)
310#define WDTTIM_MCTRL_RESET_COUNT0 BSP_BIT32(1)
311#define WDTTIM_MCTRL_STOP_COUNT0 BSP_BIT32(2)
312#define WDTTIM_MCTRL_M_RES1 BSP_BIT32(3)
313#define WDTTIM_MCTRL_M_RES2 BSP_BIT32(4)
314#define WDTTIM_MCTRL_RESFRC1 BSP_BIT32(5)
315#define WDTTIM_MCTRL_RESFRC2 BSP_BIT32(6)
316
325#define WDTTIM_EMR_EXT_MATCH0 BSP_BIT32(0)
326#define WDTTIM_EMR_MATCH_CTRL(val) BSP_FLD32(val, 4, 5)
327#define WDTTIM_EMR_MATCH_CTRL_SET(reg, val) BSP_FLD32SET(reg, val, 4, 5)
328
337#define WDTTIM_RES_WDT BSP_BIT32(0)
338
341typedef struct {
342 uint32_t intr;
343 uint32_t ctrl;
344 uint32_t counter;
345 uint32_t mctrl;
346 uint32_t match0;
347 uint32_t emr;
348 uint32_t pulse;
349 uint32_t res;
351
352typedef struct {
354
355typedef struct {
357
358typedef struct {
360
361typedef struct {
363
364typedef struct {
366
367typedef struct {
368 uint32_t mac1;
369 uint32_t mac2;
370 uint32_t ipgt;
371 uint32_t ipgr;
372 uint32_t clrt;
373 uint32_t maxf;
374 uint32_t supp;
375 uint32_t test;
376 uint32_t mcfg;
377 uint32_t mcmd;
378 uint32_t madr;
379 uint32_t mwtd;
380 uint32_t mrdd;
381 uint32_t mind;
382 uint32_t reserved_0 [2];
383 uint32_t sa0;
384 uint32_t sa1;
385 uint32_t sa2;
386 uint32_t reserved_1 [45];
387 uint32_t command;
388 uint32_t status;
389 uint32_t rxdescriptor;
390 uint32_t rxstatus;
391 uint32_t rxdescriptornum;
392 uint32_t rxproduceindex;
393 uint32_t rxconsumeindex;
394 uint32_t txdescriptor;
395 uint32_t txstatus;
396 uint32_t txdescriptornum;
397 uint32_t txproduceindex;
398 uint32_t txconsumeindex;
399 uint32_t reserved_2 [10];
400 uint32_t tsv0;
401 uint32_t tsv1;
402 uint32_t rsv;
403 uint32_t reserved_3 [3];
404 uint32_t flowcontrolcnt;
405 uint32_t flowcontrolsts;
406 uint32_t reserved_4 [34];
407 uint32_t rxfilterctrl;
408 uint32_t rxfilterwolsts;
409 uint32_t rxfilterwolclr;
410 uint32_t reserved_5 [1];
411 uint32_t hashfilterl;
412 uint32_t hashfilterh;
413 uint32_t reserved_6 [882];
414 uint32_t intstatus;
415 uint32_t intenable;
416 uint32_t intclear;
417 uint32_t intset;
418 uint32_t reserved_7 [1];
419 uint32_t powerdown;
421
422typedef struct {
423 uint32_t er;
424 uint32_t rsr;
425 uint32_t sr;
426 uint32_t apr;
427 uint32_t atr;
428 uint32_t itr;
430
431typedef struct {
432 uint32_t p3_inp_state;
433 uint32_t p3_outp_set;
434 uint32_t p3_outp_clr;
435 uint32_t p3_outp_state;
436 uint32_t p2_dir_set;
437 uint32_t p2_dir_clr;
438 uint32_t p2_dir_state;
439 uint32_t p2_inp_state;
440 uint32_t p2_outp_set;
441 uint32_t p2_outp_clr;
442 uint32_t p2_mux_set;
443 uint32_t p2_mux_clr;
444 uint32_t p2_mux_state;
445 LPC32XX_RESERVE(0x034, 0x040);
446 uint32_t p0_inp_state;
447 uint32_t p0_outp_set;
448 uint32_t p0_outp_clr;
449 uint32_t p0_outp_state;
450 uint32_t p0_dir_set;
451 uint32_t p0_dir_clr;
452 uint32_t p0_dir_state;
453 LPC32XX_RESERVE(0x05c, 0x060);
454 uint32_t p1_inp_state;
455 uint32_t p1_outp_set;
456 uint32_t p1_outp_clr;
457 uint32_t p1_outp_state;
458 uint32_t p1_dir_set;
459 uint32_t p1_dir_clr;
460 uint32_t p1_dir_state;
461 LPC32XX_RESERVE(0x07c, 0x110);
462 uint32_t p3_mux_set;
463 uint32_t p3_mux_clr;
464 uint32_t p3_mux_state;
465 LPC32XX_RESERVE(0x11c, 0x120);
466 uint32_t p0_mux_set;
467 uint32_t p0_mux_clr;
468 uint32_t p0_mux_state;
469 LPC32XX_RESERVE(0x12c, 0x130);
470 uint32_t p1_mux_set;
471 uint32_t p1_mux_clr;
472 uint32_t p1_mux_state;
474
475typedef struct {
476 uint32_t rx_or_tx;
477 uint32_t stat;
478 uint32_t ctrl;
479 uint32_t clk_hi;
480 uint32_t clk_lo;
481 uint32_t adr;
482 uint32_t rxfl;
483 uint32_t txfl;
484 uint32_t rxb;
485 uint32_t txb;
486 uint32_t s_tx;
487 uint32_t s_txfl;
489
490typedef struct {
491 uint32_t ucount;
492 uint32_t dcount;
493 uint32_t match0;
494 uint32_t match1;
495 uint32_t ctrl;
496 uint32_t intstat;
497 uint32_t key;
498 uint32_t sram [32];
500
501typedef struct {
502 uint32_t control;
503 uint32_t status;
504 uint32_t timeout;
505 uint32_t reserved_0 [5];
507
508typedef struct {
509 union {
510 uint32_t w32;
511 uint16_t w16;
512 uint8_t w8;
513 } buff;
514 uint32_t reserved_0 [8191];
515 union {
516 uint32_t w32;
517 uint16_t w16;
518 uint8_t w8;
519 } data;
520 uint32_t reserved_1 [8191];
521 uint32_t cmd;
522 uint32_t addr;
523 uint32_t ecc_enc;
524 uint32_t ecc_dec;
525 uint32_t ecc_auto_enc;
526 uint32_t ecc_auto_dec;
527 uint32_t rpr;
528 uint32_t wpr;
529 uint32_t rubp;
530 uint32_t robp;
531 uint32_t sw_wp_add_low;
532 uint32_t sw_wp_add_hig;
533 uint32_t icr;
534 uint32_t time;
535 uint32_t irq_mr;
536 uint32_t irq_sr;
537 uint32_t reserved_2;
538 uint32_t lock_pr;
539 uint32_t isr;
540 uint32_t ceh;
542
543typedef struct {
544 lpc32xx_nand_slc nand_slc;
545 LPC32XX_FILL(0x20020000, 0x20084000, lpc32xx_nand_slc);
546 lpc32xx_ssp ssp_0;
547 LPC32XX_FILL(0x20084000, 0x20088000, lpc32xx_ssp);
548 lpc32xx_spi spi_1;
549 LPC32XX_FILL(0x20088000, 0x2008c000, lpc32xx_spi);
550 lpc32xx_ssp ssp_1;
551 LPC32XX_FILL(0x2008c000, 0x20090000, lpc32xx_ssp);
552 lpc32xx_spi spi_2;
553 LPC32XX_FILL(0x20090000, 0x20094000, lpc32xx_spi);
554 lpc_i2s i2s_0;
555 LPC32XX_FILL(0x20094000, 0x20098000, lpc_i2s);
556 lpc32xx_sd_card sd_card;
557 LPC32XX_FILL(0x20098000, 0x2009c000, lpc32xx_sd_card);
558 lpc_i2s i2s_1;
559 LPC32XX_FILL(0x2009c000, 0x200a8000, lpc_i2s);
560 lpc32xx_nand_mlc nand_mlc;
561 LPC32XX_FILL(0x200a8000, 0x31000000, lpc32xx_nand_mlc);
562 lpc_dma dma;
563 LPC32XX_FILL(0x31000000, 0x31020000, lpc_dma);
564 lpc32xx_usb usb;
565 LPC32XX_FILL(0x31020000, 0x31040000, lpc32xx_usb);
567 LPC32XX_FILL(0x31040000, 0x31060000, lpc32xx_lcd);
568 lpc32xx_eth eth;
569 LPC32XX_FILL(0x31060000, 0x31080000, lpc32xx_eth);
570 lpc_emc emc;
571 LPC32XX_FILL(0x31080000, 0x31080400, lpc_emc);
572 lpc32xx_emc_ahb emc_ahb [5];
573 LPC32XX_FILL(0x31080400, 0x310c0000, lpc32xx_emc_ahb [5]);
574 lpc32xx_etb etb;
575 LPC32XX_FILL(0x310c0000, 0x40004000, lpc32xx_etb);
576 lpc32xx_syscon syscon;
577 LPC32XX_FILL(0x40004000, 0x40008000, lpc32xx_syscon);
578 lpc32xx_irq mic;
579 LPC32XX_FILL(0x40008000, 0x4000c000, lpc32xx_irq);
580 lpc32xx_irq sic_1;
581 LPC32XX_FILL(0x4000c000, 0x40010000, lpc32xx_irq);
582 lpc32xx_irq sic_2;
583 LPC32XX_FILL(0x40010000, 0x40014000, lpc32xx_irq);
584 lpc32xx_uart uart_1;
585 LPC32XX_FILL(0x40014000, 0x40018000, lpc32xx_uart);
586 lpc32xx_uart uart_2;
587 LPC32XX_FILL(0x40018000, 0x4001c000, lpc32xx_uart);
588 lpc32xx_uart uart_7;
589 LPC32XX_FILL(0x4001c000, 0x40024000, lpc32xx_uart);
590 lpc32xx_rtc rtc;
591 LPC32XX_FILL(0x40024000, 0x40028000, lpc32xx_rtc);
592 lpc32xx_gpio gpio;
593 LPC32XX_FILL(0x40028000, 0x4002c000, lpc32xx_gpio);
594 lpc_timer timer_4;
595 LPC32XX_FILL(0x4002c000, 0x40030000, lpc_timer);
596 lpc_timer timer_5;
597 LPC32XX_FILL(0x40030000, 0x40034000, lpc_timer);
598 lpc32xx_ms_timer ms_timer;
599 LPC32XX_FILL(0x40034000, 0x40038000, lpc32xx_ms_timer);
600 lpc32xx_hs_timer hs_timer;
601 LPC32XX_FILL(0x40038000, 0x4003c000, lpc32xx_hs_timer);
602 lpc32xx_wdt wdt;
603 LPC32XX_FILL(0x4003c000, 0x40040000, lpc32xx_wdt);
604 lpc32xx_debug debug;
605 LPC32XX_FILL(0x40040000, 0x40044000, lpc32xx_debug);
606 lpc_timer timer_0;
607 LPC32XX_FILL(0x40044000, 0x40048000, lpc_timer);
608 lpc32xx_adc adc;
609 LPC32XX_FILL(0x40048000, 0x4004c000, lpc32xx_adc);
610 lpc_timer timer_1;
611 LPC32XX_FILL(0x4004c000, 0x40050000, lpc_timer);
612 lpc32xx_keyscan keyscan;
613 LPC32XX_FILL(0x40050000, 0x40054000, lpc32xx_keyscan);
614 lpc32xx_uart_ctrl uart_ctrl;
615 LPC32XX_FILL(0x40054000, 0x40058000, lpc32xx_uart_ctrl);
616 lpc_timer timer_2;
617 LPC32XX_FILL(0x40058000, 0x4005c000, lpc_timer);
618 lpc32xx_pwm pwm_1_and_pwm_2;
619 LPC32XX_FILL(0x4005c000, 0x40060000, lpc32xx_pwm);
620 lpc_timer timer3;
621 LPC32XX_FILL(0x40060000, 0x40080000, lpc_timer);
622 lpc32xx_uart uart_3;
623 LPC32XX_FILL(0x40080000, 0x40088000, lpc32xx_uart);
624 lpc32xx_uart uart_4;
625 LPC32XX_FILL(0x40088000, 0x40090000, lpc32xx_uart);
626 lpc32xx_uart uart_5;
627 LPC32XX_FILL(0x40090000, 0x40098000, lpc32xx_uart);
628 lpc32xx_uart uart_6;
629 LPC32XX_FILL(0x40098000, 0x400a0000, lpc32xx_uart);
630 lpc32xx_i2c i2c_1;
631 LPC32XX_FILL(0x400a0000, 0x400a8000, lpc32xx_i2c);
632 lpc32xx_i2c i2c_2;
633 LPC32XX_FILL(0x400a8000, 0x400e8000, lpc32xx_i2c);
634 lpc32xx_mcpwm mcpwm;
636
637extern volatile lpc32xx_registers lpc32xx;
638
641#endif /* LIBBSP_ARM_LPC32XX_LPC32XX_H */
Utility macros.
DMA support API.
EMC support API.
I2S API.
Timer API.
Definition: intercom.c:74
Definition: 8xx_immap.h:201
Definition: lpc32xx.h:355
Definition: lpc32xx.h:352
Definition: lpc32xx.h:501
Definition: lpc32xx.h:263
Definition: lpc32xx.h:367
Definition: lpc32xx.h:431
Definition: lpc32xx.h:278
Definition: lpc32xx.h:475
Definition: lpc32xx.h:422
Definition: lpc32xx.h:358
Definition: lpc32xx.h:260
Definition: lpc32xx.h:364
Definition: lpc32xx.h:275
Definition: lpc32xx.h:508
Definition: lpc32xx.h:245
Definition: lpc32xx.h:361
Definition: lpc32xx.h:543
Definition: lpc32xx.h:490
Definition: lpc32xx.h:254
Definition: lpc32xx.h:251
Definition: lpc32xx.h:248
Definition: lpc32xx.h:266
Definition: lpc32xx.h:269
Definition: lpc32xx.h:272
Definition: lpc32xx.h:257
Definition: lpc32xx.h:341
DMA control block.
Definition: lpc-dma.h:66
Definition: lpc-emc.h:135
I2S control block.
Definition: lpc-i2s.h:46
Timer control block.
Definition: lpc-timer.h:133
