RTEMS 5.2-rc1
DMA support API. More...
#include <bspopts.h>
#include <bsp/utility.h>
struct  lpc_dma_descriptor
 DMA descriptor item. More...
struct  lpc_dma_channel
 DMA channel block. More...
struct  lpc_dma
 DMA control block. More...
DMA Configuration Register
#define DMA_CFG_E   BSP_BIT32(0)
#define DMA_CFG_M_0   BSP_BIT32(1)
#define DMA_CFG_M_1   BSP_BIT32(2)
DMA Channel Control Register
#define DMA_CH_CTRL_TSZ(val)   BSP_FLD32(val, 0, 11)
#define DMA_CH_CTRL_TSZ_MAX   DMA_CH_CTRL_TSZ(0xfff)
#define DMA_CH_CTRL_SB(val)   BSP_FLD32(val, 12, 14)
#define DMA_CH_CTRL_SB_1   DMA_CH_CTRL_SB(0)
#define DMA_CH_CTRL_SB_4   DMA_CH_CTRL_SB(1)
#define DMA_CH_CTRL_SB_8   DMA_CH_CTRL_SB(2)
#define DMA_CH_CTRL_SB_16   DMA_CH_CTRL_SB(3)
#define DMA_CH_CTRL_SB_32   DMA_CH_CTRL_SB(4)
#define DMA_CH_CTRL_SB_64   DMA_CH_CTRL_SB(5)
#define DMA_CH_CTRL_SB_128   DMA_CH_CTRL_SB(6)
#define DMA_CH_CTRL_SB_256   DMA_CH_CTRL_SB(7)
#define DMA_CH_CTRL_DB(val)   BSP_FLD32(val, 15, 17)
#define DMA_CH_CTRL_DB_1   DMA_CH_CTRL_DB(0)
#define DMA_CH_CTRL_DB_4   DMA_CH_CTRL_DB(1)
#define DMA_CH_CTRL_DB_8   DMA_CH_CTRL_DB(2)
#define DMA_CH_CTRL_DB_16   DMA_CH_CTRL_DB(3)
#define DMA_CH_CTRL_DB_32   DMA_CH_CTRL_DB(4)
#define DMA_CH_CTRL_DB_64   DMA_CH_CTRL_DB(5)
#define DMA_CH_CTRL_DB_128   DMA_CH_CTRL_DB(6)
#define DMA_CH_CTRL_DB_256   DMA_CH_CTRL_DB(7)
#define DMA_CH_CTRL_SW(val)   BSP_FLD32(val, 18, 20)
#define DMA_CH_CTRL_SW_8   DMA_CH_CTRL_SW(0)
#define DMA_CH_CTRL_SW_16   DMA_CH_CTRL_SW(1)
#define DMA_CH_CTRL_SW_32   DMA_CH_CTRL_SW(2)
#define DMA_CH_CTRL_DW(val)   BSP_FLD32(val, 21, 23)
#define DMA_CH_CTRL_DW_8   DMA_CH_CTRL_DW(0)
#define DMA_CH_CTRL_DW_16   DMA_CH_CTRL_DW(1)
#define DMA_CH_CTRL_DW_32   DMA_CH_CTRL_DW(2)
#define DMA_CH_CTRL_S   BSP_BIT32(24)
#define DMA_CH_CTRL_D   BSP_BIT32(25)
#define DMA_CH_CTRL_SI   BSP_BIT32(26)
#define DMA_CH_CTRL_DI   BSP_BIT32(27)
#define DMA_CH_CTRL_PROT(val)   BSP_FLD32(val, 28, 30)
#define DMA_CH_CTRL_I   BSP_BIT32(31)
DMA Channel Configuration Register
#define DMA_CH_CFG_E   BSP_BIT32(0)
#define DMA_CH_CFG_SPER(val)   BSP_FLD32(val, 1, 5)
#define DMA_CH_CFG_DPER(val)   BSP_FLD32(val, 6, 10)
#define DMA_CH_CFG_FLOW(val)   BSP_FLD32(val, 11, 13)
#define DMA_CH_CFG_FLOW_MEM_TO_MEM_DMA   DMA_CH_CFG_FLOW(0)
#define DMA_CH_CFG_FLOW_MEM_TO_PER_DMA   DMA_CH_CFG_FLOW(1)
#define DMA_CH_CFG_FLOW_PER_TO_MEM_DMA   DMA_CH_CFG_FLOW(2)
#define DMA_CH_CFG_FLOW_PER_TO_PER_DMA   DMA_CH_CFG_FLOW(3)
#define DMA_CH_CFG_FLOW_PER_TO_PER_DEST   DMA_CH_CFG_FLOW(4)
#define DMA_CH_CFG_FLOW_MEM_TO_PER_PER   DMA_CH_CFG_FLOW(5)
#define DMA_CH_CFG_FLOW_PER_TO_MEM_PER   DMA_CH_CFG_FLOW(6)
#define DMA_CH_CFG_FLOW_PER_TO_PER_SRC   DMA_CH_CFG_FLOW(7)
#define DMA_CH_CFG_IE   BSP_BIT32(14)
#define DMA_CH_CFG_ITC   BSP_BIT32(15)
#define DMA_CH_CFG_L   BSP_BIT32(16)
#define DMA_CH_CFG_A   BSP_BIT32(17)
#define DMA_CH_CFG_H   BSP_BIT32(18)
LPC24XX DMA Peripherals
#define LPC24XX_DMA_PER_SSP_0_TX   0
#define LPC24XX_DMA_PER_SSP_0_RX   1
#define LPC24XX_DMA_PER_SSP_1_TX   2
#define LPC24XX_DMA_PER_SSP_1_RX   3
#define LPC24XX_DMA_PER_SD_MMC   4
#define LPC24XX_DMA_PER_I2S_CH_0   5
#define LPC24XX_DMA_PER_I2S_CH_1   6
LPC32XX DMA Peripherals
#define LPC32XX_DMA_PER_I2S_0_CH_0   0
#define LPC32XX_DMA_PER_I2S_0_CH_1   13
#define LPC32XX_DMA_PER_I2S_1_CH_0   2
#define LPC32XX_DMA_PER_I2S_1_CH_1   10
#define LPC32XX_DMA_PER_NAND_0   1
#define LPC32XX_DMA_PER_NAND_1   12
#define LPC32XX_DMA_PER_SD_MMC   4
#define LPC32XX_DMA_PER_SSP_0_RX   14
#define LPC32XX_DMA_PER_SSP_0_TX   15
#define LPC32XX_DMA_PER_SSP_1_RX   3
#define LPC32XX_DMA_PER_SSP_1_TX   11
#define LPC32XX_DMA_PER_UART_1_RX   6
#define LPC32XX_DMA_PER_UART_1_TX   5
#define LPC32XX_DMA_PER_UART_2_RX   8
#define LPC32XX_DMA_PER_UART_2_TX   7
#define LPC32XX_DMA_PER_UART_7_RX   10
#define LPC32XX_DMA_PER_UART_7_TX   9
DMA support API.
