RTEMS 5.2-rc1
isi.h File Reference
struct  ISI_Descriptors
struct  ISI_FrameBufferDescriptors
struct  ISI_Y2R
struct  ISI_R2Y
#define YUV_INPUT   0
#define RGB_INPUT   1
#define GRAYSCALE_INPUT   2
void ISI_Enable (void)
 Enable ISI.
void ISI_Disable (void)
 Disable ISI.
void ISI_DmaChannelEnable (uint32_t channel)
 Enable ISI Dma channel. More...
void ISI_DmaChannelDisable (uint32_t channel)
 Disable ISI Dma channel. More...
void ISI_EnableInterrupt (uint32_t flag)
 Enable ISI interrupt. More...
void ISI_DisableInterrupt (uint32_t flag)
 Disable ISI interrupt. More...
void ISI_CodecPathFull (void)
 Enable Codec path for capture next frame.
void ISI_SetFrameRate (uint32_t frame)
 Set frame rate. More...
uint8_t ISI_BytesForOnePixel (uint8_t bmpRgb)
 Get the number of byte per pixels. More...
void ISI_Reset (void)
 Reset ISI.
void ISI_Init (pIsi_Video pVideo)
uint32_t ISI_StatusRegister (void)
 Return ISI status register. More...
void ISI_SetBlank (uint8_t hBlank, uint8_t vBlank)
 Set the windows blank. More...
void ISI_SetSensorSize (uint32_t hSize, uint32_t vSize)
 Set vertical and horizontal Size of the Image Sensor. More...
void ISI_RgbPixelMapping (uint32_t wRgbPixelMapping)
 Defines RGB pattern when RGB_MODE is set to 1. More...
void ISI_RgbSwapMode (uint32_t swapMode)
 Enables RGB swap. More...
void ISI_YCrCbFormat (uint32_t wYuvSwapMode)
 Defines YCrCb swap format. More...
void ISI_setGrayScaleMode (uint32_t wPixelFormat)
 Input image is assumed to be grayscale-coded. More...
void ISI_setInputStream (uint32_t wStreamMode)
 Set data stream format. More...
void ISI_setPreviewSize (uint32_t hSize, uint32_t vSize)
 Set preview size. More...
void ISI_calcScalerFactor (void)
 calculate scaler factor automatically. More...
void ISI_setDmaInPreviewPath (uint32_t baseFrameBufDesc, uint32_t dmaCtrl, uint32_t frameBufferStartAddr)
 Configure DMA for preview path. More...
void ISI_setDmaInCodecPath (uint32_t baseFrameBufDesc, uint32_t dmaCtrl, uint32_t frameBufferStartAddr)
 Configure DMA for Codec path. More...
void ISI_SetMatrix4Yuv2Rgb (ISI_Y2R *yuv2rgb)
 ISI set matrix for YUV to RGB color space for preview path. More...
void ISI_SetMatrix4Rgb2Yuv (ISI_R2Y *rgb2yuv)
 ISI set matrix for RGB to YUV color space for codec path. More...
◆ ISI_BytesForOnePixel()
uint8_t ISI_BytesForOnePixel ( uint8_t  bmpRgb)
Parameters
bmpRgbBMP type can be YUV or RGB
◆ ISI_calcScalerFactor()
void ISI_calcScalerFactor ( void  )
Note
The sensor size and preview size for LCD was configured before this setting.
◆ ISI_DisableInterrupt()
void ISI_DisableInterrupt ( uint32_t  flag)
Parameters
flagof interrupt to disable
◆ ISI_DmaChannelDisable()
void ISI_DmaChannelDisable ( uint32_t  channel)
Parameters
channelto be disabled
◆ ISI_DmaChannelEnable()
void ISI_DmaChannelEnable ( uint32_t  channel)
Parameters
channelto be enabled
◆ ISI_EnableInterrupt()
void ISI_EnableInterrupt ( uint32_t  flag)
Parameters
flagof interrupt to enable
◆ ISI_RgbPixelMapping()
void ISI_RgbPixelMapping ( uint32_t  wRgbPixelMapping)
Parameters
wRgbPixelMappingRGB pattern
◆ ISI_RgbSwapMode()
void ISI_RgbSwapMode ( uint32_t  swapMode)
Enables RGB swap.
Parameters
swapMode0: D7-R7, 1: D0-R7
◆ ISI_SetBlank()
void ISI_SetBlank ( uint8_t  hBlank,
uint8_t  vBlank
Parameters
hBlankpixel clock periods to wait before the beginning of a line.
vBlanklines are skipped at the beginning of the frame.
◆ ISI_setDmaInCodecPath()
void ISI_setDmaInCodecPath ( uint32_t  baseFrameBufDesc,
uint32_t  dmaCtrl,
Parameters
baseFrameBufDescPreview Descriptor Address.
dmaCtrlDMA Preview Control.
frameBufferStartAddrDMA Preview Base Address.
◆ ISI_setDmaInPreviewPath()
void ISI_setDmaInPreviewPath ( uint32_t  baseFrameBufDesc,
uint32_t  dmaCtrl,
Parameters
◆ ISI_SetFrameRate()
void ISI_SetFrameRate ( uint32_t  frame)
Set frame rate.
Parameters
frameframe rate capture
◆ ISI_setGrayScaleMode()
void ISI_setGrayScaleMode ( uint32_t  wPixelFormat)
Parameters
wPixelFormat0: 2 pixels per word, 1:1 pixel per word.
◆ ISI_setInputStream()
void ISI_setInputStream ( uint32_t  wStreamMode)
Parameters
wStreamMode0: YUV input, 1: RGB 8:8:8/5:6:5 input
◆ ISI_SetMatrix4Rgb2Yuv()
void ISI_SetMatrix4Rgb2Yuv ( ISI_R2Y rgb2yuv)
Parameters
rgb2yuvstructure of RGB to YUV parameters.
◆ ISI_SetMatrix4Yuv2Rgb()
void ISI_SetMatrix4Yuv2Rgb ( ISI_Y2R yuv2rgb)
Parameters
yuv2rgbstructure of YUV to RBG parameters.
◆ ISI_setPreviewSize()
void ISI_setPreviewSize ( uint32_t  hSize,
uint32_t  vSize
Set preview size.
Parameters
hSizeHorizontal Preview size (640 max only in RGB mode).
vSizeVertical Preview size (480 max only in RGB mode).
◆ ISI_SetSensorSize()
void ISI_SetSensorSize ( uint32_t  hSize,
uint32_t  vSize
Parameters
hSizeHorizontal size of the Image sensor [0..2047].
vSizeVertical size of the Image sensor [0..2047].
◆ ISI_StatusRegister()
uint32_t ISI_StatusRegister ( void  )
Returns
Status of ISI register
◆ ISI_YCrCbFormat()
void ISI_YCrCbFormat ( uint32_t  wYuvSwapMode)
Parameters
wYuvSwapModeYUV Swap format
