RTEMS 5.2-rc1
This source file contains the legacy interrupt controller support implementation. More...
| int | BSP_get_current_rtems_irq_handler (rtems_irq_connect_data *cd) |
| int | BSP_install_rtems_irq_handler (const rtems_irq_connect_data *cd) |
| int | BSP_install_rtems_shared_irq_handler (const rtems_irq_connect_data *cd) |
| int | BSP_remove_rtems_irq_handler (const rtems_irq_connect_data *cd) |
| int | BSP_rtems_irq_mngt_set (rtems_irq_global_settings *config) |
| int | BSP_rtems_irq_mngt_get (rtems_irq_global_settings **config) |
| int BSP_get_current_rtems_irq_handler | ( | rtems_irq_connect_data * | cd | ) |
| int BSP_install_rtems_irq_handler | ( | const rtems_irq_connect_data * | cd | ) |
| int BSP_install_rtems_shared_irq_handler | ( | const rtems_irq_connect_data * | cd | ) |
| int BSP_remove_rtems_irq_handler | ( | const rtems_irq_connect_data * | cd | ) |
| int BSP_rtems_irq_mngt_get | ( | rtems_irq_global_settings ** | config | ) |
| int BSP_rtems_irq_mngt_set | ( | rtems_irq_global_settings * | config | ) |
