RTEMS 5.2-rc1
#define ctz(u)
 Counts the trailing zero bits of the given value considered as a 32-bit integer. More...
Interrupt Service Routine definition
#define Enable_global_interrupt()   cpu_irq_enable()
#define Disable_global_interrupt()   cpu_irq_disable()
#define Is_global_interrupt_enabled()   cpu_irq_is_enabled()
Usual Constants
#define DISABLE   0
#define ENABLE   1
#define DISABLED   0
#define ENABLED   1
#define OFF   0
#define ON   1
#define FALSE   0
#define TRUE   1
#define false   FALSE
#define true   TRUE
#define KO   0
#define OK   1
#define PASS   0
#define FAIL   1
#define LOW   0
#define HIGH   1
#define CLR   0
#define SET   1
◆ ctz
#define ctz (   u)
Parameters
uValue of which to count the trailing zero bits.
Returns
The count of trailing zero bits in u.
