RTEMS 5.2-rc1
Modules | Files | Data Structures | Macros | Functions
Serial Peripheral Interface (SPI) Driver
Serial Peripheral Interface (SPI) bus driver support. More...
 Linux SPI User-Space API
 RTEMS port of Linux SPI user-space API.
file  spi.h
 Serial Peripheral Interface (SPI) Driver API.
struct  spi_bus
 SPI bus control. More...
#define SPI_BUS_OBTAIN   _IO(SPI_IOC_MAGIC, 13)
 Obtains the bus. More...
#define SPI_BUS_RELEASE   _IO(SPI_IOC_MAGIC, 23)
 Releases the bus. More...
int spi_bus_init (spi_bus *bus)
 Initializes a bus control. More...
spi_busspi_bus_alloc_and_init (size_t size)
 Allocates a bus control from the heap and initializes it. More...
void spi_bus_destroy (spi_bus *bus)
 Destroys a bus control. More...
void spi_bus_destroy_and_free (spi_bus *bus)
 Destroys a bus control and frees its memory. More...
int spi_bus_register (spi_bus *bus, const char *bus_path)
 Registers a bus control. More...
◆ SPI_BUS_OBTAIN
Obtains the bus.
This command has no argument.
◆ SPI_BUS_RELEASE
Releases the bus.
◆ spi_bus_alloc_and_init()
spi_bus * spi_bus_alloc_and_init ( size_t  size)
After a sucessful allocation and initialization the bus control must be destroyed via spi_bus_destroy_and_free(). A registered bus control will be automatically destroyed in case the device file is unlinked. Make sure to call spi_bus_destroy_and_free() in a custom destruction handler.
Parameters
[in]sizeThe size of the bus control. This enables the addition of bus controller specific data to the base bus control. The bus control is zero initialized.
Return values
non-NULLThe new bus control.
NULLAn error occurred. The errno is set to indicate the error.
See also
spi_bus_register()
◆ spi_bus_destroy()
void spi_bus_destroy ( spi_bus bus)
Parameters
[in]busThe bus control.
◆ spi_bus_destroy_and_free()
void spi_bus_destroy_and_free ( spi_bus bus)
Parameters
◆ spi_bus_init()
int spi_bus_init ( spi_bus bus)
After a sucessful initialization the bus control must be destroyed via spi_bus_destroy(). A registered bus control will be automatically destroyed in case the device file is unlinked. Make sure to call spi_bus_destroy() in a custom destruction handler.
Parameters
Return values
0Successful operation.
-1An error occurred. The errno is set to indicate the error.
See also
spi_bus_register()
◆ spi_bus_register()
int spi_bus_register ( spi_bus bus,
const char *  bus_path
This function claims ownership of the bus control regardless if the registration is successful or not.
Parameters
[in]bus_pathThe path to the bus device file.
Return values
