RTEMS 5.2-rc1
Files | Data Structures | Macros | Typedefs | Functions
Timecounter Support
file  timecounter.h
 Timecounter API.
struct  rtems_timecounter_simple
 Simple timecounter to support legacy clock drivers. More...
#define RTEMS_TIMECOUNTER_QUALITY_CLOCK_DRIVER   100
 Timecounter quality for the clock drivers. More...
typedef void rtems_timecounter_simple_at_tick(rtems_timecounter_simple *tc)
 At tick handling done under protection of the timecounter lock.
typedef uint32_t rtems_timecounter_simple_get(rtems_timecounter_simple *tc)
 Returns the current value of a simple timecounter.
typedef bool rtems_timecounter_simple_is_pending(rtems_timecounter_simple *tc)
 Returns true if the interrupt of a simple timecounter is pending, and false otherwise.
RTEMS_INLINE_ROUTINE void rtems_timecounter_install (struct timecounter *tc)
 Installs the timecounter. More...
RTEMS_INLINE_ROUTINE void rtems_timecounter_tick (void)
 Performs a timecounter tick. More...
void rtems_timecounter_simple_install (rtems_timecounter_simple *tc, uint32_t counter_frequency_in_hz, uint32_t counter_ticks_per_clock_tick, timecounter_get_t *get_timecount)
 Initializes and installs a simple timecounter. More...
RTEMS_INLINE_ROUTINE uint32_t rtems_timecounter_simple_scale (const rtems_timecounter_simple *tc, uint32_t value)
 Maps a simple timecounter value into its binary frequency domain. More...
RTEMS_INLINE_ROUTINE void rtems_timecounter_simple_downcounter_tick (rtems_timecounter_simple *tc, rtems_timecounter_simple_get get, rtems_timecounter_simple_at_tick at_tick)
 Performs a simple timecounter tick for downcounters. More...
RTEMS_INLINE_ROUTINE void rtems_timecounter_simple_upcounter_tick (rtems_timecounter_simple *tc, rtems_timecounter_simple_get get, rtems_timecounter_simple_at_tick at_tick)
 Performs a simple timecounter tick for upcounters. More...
RTEMS_INLINE_ROUTINE uint32_t rtems_timecounter_simple_downcounter_get (struct timecounter *tc_base, rtems_timecounter_simple_get get, rtems_timecounter_simple_is_pending is_pending)
 Gets the simple timecounter value mapped to its binary frequency domain for downcounters. More...
RTEMS_INLINE_ROUTINE uint32_t rtems_timecounter_simple_upcounter_get (struct timecounter *tc_base, rtems_timecounter_simple_get get, rtems_timecounter_simple_is_pending is_pending)
 Gets the simple timecounter value mapped to its binary frequency domain for upcounters. More...
◆ RTEMS_TIMECOUNTER_QUALITY_CLOCK_DRIVER
Timecounter with higher quality value are used in favour of those with lower quality value.
◆ rtems_timecounter_install()
RTEMS_INLINE_ROUTINE void rtems_timecounter_install ( struct timecounter tc)
The timecounter structure must contain valid values in the fields tc_get_timecount, tc_counter_mask, tc_frequency and tc_quality. All other fields must be zero initialized.
Parameters
tcThe timecounter.
Below is an exemplary code snippet that shows the adjustable parameters and the following call of the install routine.
struct timecounter tc;
uint32_t get_timecount( struct timecounter *tc )
return some_free_running_counter;
void install( void )
tc.tc_get_timecount = get_timecount;
tc.tc_counter_mask = 0xffffffff;
tc.tc_frequency = 123456;
Definition: timecounter.h:47
RTEMS_INLINE_ROUTINE void rtems_timecounter_install(struct timecounter *tc)
Definition: timecounter.h:73
Definition: timetc.h:46
◆ rtems_timecounter_simple_downcounter_get()
RTEMS_INLINE_ROUTINE uint32_t rtems_timecounter_simple_downcounter_get ( struct timecounter tc_base,
Parameters
[in]tcThe simple timecounter.
[in]getThe method to get the value of the simple timecounter.
[in]is_pendingThe method which indicates if the interrupt of the simple timecounter is pending.
◆ rtems_timecounter_simple_downcounter_tick()
RTEMS_INLINE_ROUTINE void rtems_timecounter_simple_downcounter_tick ( rtems_timecounter_simple tc,
Parameters
[in]at_tickThe method to perform work under timecounter lock protection at this tick, e.g. clear a pending flag.
◆ rtems_timecounter_simple_install()
void rtems_timecounter_simple_install ( rtems_timecounter_simple tc,
timecounter_get_t *  get_timecount
A simple timecounter can be used if the hardware provides no free running counter. A periodic hardware counter must be provided. The counter period must be synchronous to the clock tick. The counter ticks per clock tick is scaled up to the next power of two.
Parameters
[in]tcZero initialized simple timecounter.
[in]counter_frequency_in_hzThe hardware counter frequency in Hz.
[in]counter_ticks_per_clock_tickThe hardware counter ticks per clock tick.
[in]get_timecountThe method to get the current time count.
static rtems_timecounter_simple some_tc;
static uint32_t some_tc_get( rtems_timecounter_simple *tc )
return some.value;
static bool some_tc_is_pending( rtems_timecounter_simple *tc )
return some.is_pending;
static uint32_t some_tc_get_timecount( struct timecounter *tc )
tc,
some_tc_get,
some_tc_is_pending
static void some_tc_tick( void )
void some_tc_init( void )
uint64_t us_per_tick;
uint32_t counter_frequency_in_hz;
uint32_t counter_ticks_per_clock_tick;
us_per_tick = rtems_configuration_get_microseconds_per_tick();
counter_frequency_in_hz = some_tc_get_frequency();
counter_ticks_per_clock_tick =
(uint32_t) ( counter_frequency_in_hz * us_per_tick ) / 1000000;
some_tc_init_hardware( counter_ticks_per_clock_tick );
some_tc_init_clock_tick_interrupt( some_tc_tick );
&some_tc,
void rtems_timecounter_simple_install(rtems_timecounter_simple *tc, uint32_t counter_frequency_in_hz, uint32_t counter_ticks_per_clock_tick, timecounter_get_t *get_timecount)
Definition: tcsimpleinstall.c:21
RTEMS_INLINE_ROUTINE uint32_t rtems_timecounter_simple_downcounter_get(struct timecounter *tc_base, rtems_timecounter_simple_get get, rtems_timecounter_simple_is_pending is_pending)
Definition: timecounter.h:278
RTEMS_INLINE_ROUTINE void rtems_timecounter_simple_downcounter_tick(rtems_timecounter_simple *tc, rtems_timecounter_simple_get get, rtems_timecounter_simple_at_tick at_tick)
Definition: timecounter.h:222
Definition: timecounter.h:91
Timecounter API.
See also
rtems_timecounter_simple_downcounter_get(), rtems_timecounter_simple_downcounter_tick(), rtems_timecounter_simple_upcounter_get() and rtems_timecounter_simple_upcounter_tick().
◆ rtems_timecounter_simple_scale()
RTEMS_INLINE_ROUTINE uint32_t rtems_timecounter_simple_scale ( const rtems_timecounter_simple tc,
uint32_t  value
Parameters
[in]valueThe value of the simple timecounter.
Returns
The scaled value.
◆ rtems_timecounter_simple_upcounter_get()
RTEMS_INLINE_ROUTINE uint32_t rtems_timecounter_simple_upcounter_get ( struct timecounter tc_base,
Parameters
◆ rtems_timecounter_simple_upcounter_tick()
RTEMS_INLINE_ROUTINE void rtems_timecounter_simple_upcounter_tick ( rtems_timecounter_simple tc,
Parameters
◆ rtems_timecounter_tick()
RTEMS_INLINE_ROUTINE void rtems_timecounter_tick ( void  )
