RTEMS 5.2-rc1
RTEMS Test Framework Implementation
Implementation details. More...
struct  T_case_context
struct  T_check_context
struct  T_check_context_msg
#define T_CHECK_STOP   1U
#define T_CHECK_QUIET   2U
#define T_CHECK_STEP_FLAG   4U
#define T_CHECK_STEP_TO_FLAGS(step)   ((unsigned int)(step) << 8)
#define T_CHECK_STEP_FROM_FLAGS(flags)   ((flags) >> 8)
#define T_CHECK_STEP(step)   (T_CHECK_STEP_TO_FLAGS(step) | T_CHECK_STEP_FLAG)
#define T_flags_true(a, flags, ...)
#define T_flags_eq(a, e, flags, ...)    T_flags_true((a) == (e), flags, __VA_ARGS__)
#define T_flags_ne(a, e, flags, ...)    T_flags_true((a) != (e), flags, __VA_ARGS__)
#define T_flags_eq_ptr(a, e, flags, sa, se)
#define T_flags_ne_ptr(a, e, flags, sa, se)
#define T_flags_null(a, flags, sa)
#define T_flags_not_null(a, flags, sa)
#define T_flags_eq_mem(a, e, n, flags, sa, se, sn)
#define T_flags_ne_mem(a, e, n, flags, sa, se, sn)
#define T_flags_eq_str(a, e, flags)
#define T_flags_ne_str(a, e, flags)
#define T_flags_eq_nstr(a, e, n, flags)
#define T_flags_ne_nstr(a, e, n, flags)
#define T_flags_eq_char(a, e, flags)
#define T_flags_ne_char(a, e, flags)
#define T_flags_eq_int(a, e, flags)
#define T_flags_ne_int(a, e, flags)
#define T_flags_ge_int(a, e, flags)
#define T_flags_gt_int(a, e, flags)
#define T_flags_le_int(a, e, flags)
#define T_flags_lt_int(a, e, flags)
#define T_flags_eq_uint(a, e, flags)
#define T_flags_ne_uint(a, e, flags)
#define T_flags_ge_uint(a, e, flags)
#define T_flags_gt_uint(a, e, flags)
#define T_flags_le_uint(a, e, flags)
#define T_flags_lt_uint(a, e, flags)
#define T_flags_eq_long(a, e, flags)
#define T_flags_ne_long(a, e, flags)
#define T_flags_ge_long(a, e, flags)
#define T_flags_gt_long(a, e, flags)
#define T_flags_le_long(a, e, flags)
#define T_flags_lt_long(a, e, flags)
#define T_flags_eq_ulong(a, e, flags)
#define T_flags_ne_ulong(a, e, flags)
#define T_flags_ge_ulong(a, e, flags)
#define T_flags_gt_ulong(a, e, flags)
#define T_flags_le_ulong(a, e, flags)
#define T_flags_lt_ulong(a, e, flags)
#define T_flags_eq_ll(a, e, flags)
#define T_flags_ne_ll(a, e, flags)
#define T_flags_ge_ll(a, e, flags)
#define T_flags_gt_ll(a, e, flags)
#define T_flags_le_ll(a, e, flags)
#define T_flags_lt_ll(a, e, flags)
#define T_flags_eq_ull(a, e, flags)
#define T_flags_ne_ull(a, e, flags)
#define T_flags_ge_ull(a, e, flags)
#define T_flags_gt_ull(a, e, flags)
#define T_flags_le_ull(a, e, flags)
#define T_flags_lt_ull(a, e, flags)
#define T_flags_eno(a, e, flags)
#define T_flags_eno_success(a, flags)
#define T_flags_psx_error(a, eno, flags)
#define T_flags_psx_success(a, flags)
typedef struct T_case_context T_case_context
void T_case_register (T_case_context *)
void T_check_true (bool, const T_check_context *, const char *,...)
void T_check_eq_ptr (const void *, const T_check_context_msg *, const void *)
void T_check_ne_ptr (const void *, const T_check_context_msg *, const void *)
void T_check_null (const void *, const T_check_context_msg *)
void T_check_not_null (const void *, const T_check_context_msg *)
void T_check_eq_mem (const void *, const T_check_context_msg *, const void *, size_t)
void T_check_ne_mem (const void *, const T_check_context_msg *, const void *, size_t)
void T_check_eq_str (const char *, const T_check_context *, const char *)
void T_check_ne_str (const char *, const T_check_context *, const char *)
void T_check_eq_nstr (const char *, const T_check_context *, const char *, size_t)
void T_check_ne_nstr (const char *, const T_check_context *, const char *, size_t)
void T_check_eq_char (char, const T_check_context *, char)
void T_check_ne_char (char, const T_check_context *, char)
void T_check_eq_int (int, const T_check_context *, int)
void T_check_ne_int (int, const T_check_context *, int)
void T_check_ge_int (int, const T_check_context *, int)
void T_check_gt_int (int, const T_check_context *, int)
void T_check_le_int (int, const T_check_context *, int)
void T_check_lt_int (int, const T_check_context *, int)
void T_check_eq_uint (unsigned int, const T_check_context *, unsigned int)
void T_check_ne_uint (unsigned int, const T_check_context *, unsigned int)
void T_check_ge_uint (unsigned int, const T_check_context *, unsigned int)
void T_check_gt_uint (unsigned int, const T_check_context *, unsigned int)
void T_check_le_uint (unsigned int, const T_check_context *, unsigned int)
void T_check_lt_uint (unsigned int, const T_check_context *, unsigned int)
void T_check_eq_long (long, const T_check_context *, long)
void T_check_ne_long (long, const T_check_context *, long)
void T_check_ge_long (long, const T_check_context *, long)
void T_check_gt_long (long, const T_check_context *, long)
void T_check_le_long (long, const T_check_context *, long)
void T_check_lt_long (long, const T_check_context *, long)
void T_check_eq_ulong (unsigned long, const T_check_context *, unsigned long)
void T_check_ne_ulong (unsigned long, const T_check_context *, unsigned long)
void T_check_ge_ulong (unsigned long, const T_check_context *, unsigned long)
void T_check_gt_ulong (unsigned long, const T_check_context *, unsigned long)
void T_check_le_ulong (unsigned long, const T_check_context *, unsigned long)
void T_check_lt_ulong (unsigned long, const T_check_context *, unsigned long)
void T_check_eq_ll (long long, const T_check_context *, long long)
void T_check_ne_ll (long long, const T_check_context *, long long)
void T_check_ge_ll (long long, const T_check_context *, long long)
void T_check_gt_ll (long long, const T_check_context *, long long)
void T_check_le_ll (long long, const T_check_context *, long long)
void T_check_lt_ll (long long, const T_check_context *, long long)
void T_check_eq_ull (unsigned long long, const T_check_context *, unsigned long long)
void T_check_ne_ull (unsigned long long, const T_check_context *, unsigned long long)
void T_check_ge_ull (unsigned long long, const T_check_context *, unsigned long long)
void T_check_gt_ull (unsigned long long, const T_check_context *, unsigned long long)
void T_check_le_ull (unsigned long long, const T_check_context *, unsigned long long)
void T_check_lt_ull (unsigned long long, const T_check_context *, unsigned long long)
void T_check_eno (int, const T_check_context *, int)
void T_check_eno_success (int, const T_check_context *)
void T_check_psx_error (int, const T_check_context *, int)
void T_check_psx_success (int, const T_check_context *)
◆ T_flags_eno
#define T_flags_eno (   a,
  e,
  flags
Value:
static const T_check_context T_check_instance = { \
T_FILE_NAME, __LINE__, flags }; \
T_check_eno(a, &T_check_instance, e); \
Definition: t.h:111
unsigned e
Definition: tlb.h:13
◆ T_flags_eno_success
#define T_flags_eno_success (   a,
  flags
Value:
T_check_eno_success(a, &T_check_instance); \
◆ T_flags_eq_char
#define T_flags_eq_char (   a,
  e,
  flags
Value:
T_check_eq_char(a, &T_check_instance, e); \
◆ T_flags_eq_int
#define T_flags_eq_int (   a,
  e,
  flags
Value:
T_check_eq_int(a, &T_check_instance, e); \
◆ T_flags_eq_ll
#define T_flags_eq_ll (   a,
  e,
  flags
Value:
T_check_eq_ll(a, &T_check_instance, e); \
◆ T_flags_eq_long
#define T_flags_eq_long (   a,
  e,
  flags
Value:
T_check_eq_long(a, &T_check_instance, e); \
◆ T_flags_eq_mem
#define T_flags_eq_mem (   a,
  e,
  n,
  flags,
  sa,
  se,
  sn
Value:
static const T_check_context_msg T_check_instance = { \
{ T_FILE_NAME, __LINE__, flags }, \
"memcmp(" sa ", " se ", " sn ") == 0" }; \
T_check_eq_mem(a, &T_check_instance, e, n); \
Definition: t.h:117
◆ T_flags_eq_nstr
#define T_flags_eq_nstr (   a,
  e,
  n,
  flags
Value:
T_check_eq_nstr(a, &T_check_instance, e, n); \
◆ T_flags_eq_ptr
#define T_flags_eq_ptr (   a,
  e,
  flags,
  sa,
  se
Value:
{ T_FILE_NAME, __LINE__, flags }, sa " == " se }; \
T_check_eq_ptr(a, &T_check_instance, e); \
◆ T_flags_eq_str
#define T_flags_eq_str (   a,
  e,
  flags
Value:
T_check_eq_str(a, &T_check_instance, e); \
◆ T_flags_eq_uint
#define T_flags_eq_uint (   a,
  e,
  flags
Value:
T_check_eq_uint(a, &T_check_instance, e); \
◆ T_flags_eq_ull
#define T_flags_eq_ull (   a,
  e,
  flags
Value:
T_check_eq_ull(a, &T_check_instance, e); \
◆ T_flags_eq_ulong
#define T_flags_eq_ulong (   a,
  e,
  flags
Value:
T_check_eq_ulong(a, &T_check_instance, e); \
◆ T_flags_ge_int
#define T_flags_ge_int (   a,
  e,
  flags
Value:
T_check_ge_int(a, &T_check_instance, e); \
◆ T_flags_ge_ll
#define T_flags_ge_ll (   a,
  e,
  flags
Value:
T_check_ge_ll(a, &T_check_instance, e); \
◆ T_flags_ge_long
#define T_flags_ge_long (   a,
  e,
  flags
Value:
T_check_ge_long(a, &T_check_instance, e); \
◆ T_flags_ge_uint
#define T_flags_ge_uint (   a,
  e,
  flags
Value:
T_check_ge_uint(a, &T_check_instance, e); \
◆ T_flags_ge_ull
#define T_flags_ge_ull (   a,
  e,
  flags
Value:
T_check_ge_ull(a, &T_check_instance, e); \
◆ T_flags_ge_ulong
#define T_flags_ge_ulong (   a,
  e,
  flags
Value:
T_check_ge_ulong(a, &T_check_instance, e); \
◆ T_flags_gt_int
#define T_flags_gt_int (   a,
  e,
  flags
Value:
T_check_gt_int(a, &T_check_instance, e); \
◆ T_flags_gt_ll
#define T_flags_gt_ll (   a,
  e,
  flags
Value:
T_check_gt_ll(a, &T_check_instance, e); \
◆ T_flags_gt_long
#define T_flags_gt_long (   a,
  e,
  flags
Value:
T_check_gt_long(a, &T_check_instance, e); \
◆ T_flags_gt_uint
#define T_flags_gt_uint (   a,
  e,
  flags
Value:
T_check_gt_uint(a, &T_check_instance, e); \
◆ T_flags_gt_ull
#define T_flags_gt_ull (   a,
  e,
  flags
Value:
T_check_gt_ull(a, &T_check_instance, e); \
◆ T_flags_gt_ulong
#define T_flags_gt_ulong (   a,
  e,
  flags
Value:
T_check_gt_ulong(a, &T_check_instance, e); \
◆ T_flags_le_int
#define T_flags_le_int (   a,
  e,
  flags
Value:
T_check_le_int(a, &T_check_instance, e); \
◆ T_flags_le_ll
#define T_flags_le_ll (   a,
  e,
  flags
Value:
T_check_le_ll(a, &T_check_instance, e); \
◆ T_flags_le_long
#define T_flags_le_long (   a,
  e,
  flags
Value:
T_check_le_long(a, &T_check_instance, e); \
◆ T_flags_le_uint
#define T_flags_le_uint (   a,
  e,
  flags
Value:
T_check_le_uint(a, &T_check_instance, e); \
◆ T_flags_le_ull
#define T_flags_le_ull (   a,
  e,
  flags
Value:
T_check_le_ull(a, &T_check_instance, e); \
◆ T_flags_le_ulong
#define T_flags_le_ulong (   a,
  e,
  flags
Value:
T_check_le_ulong(a, &T_check_instance, e); \
◆ T_flags_lt_int
#define T_flags_lt_int (   a,
  e,
  flags
Value:
T_check_lt_int(a, &T_check_instance, e); \
◆ T_flags_lt_ll
#define T_flags_lt_ll (   a,
  e,
  flags
Value:
T_check_lt_ll(a, &T_check_instance, e); \
◆ T_flags_lt_long
#define T_flags_lt_long (   a,
  e,
  flags
Value:
T_check_lt_long(a, &T_check_instance, e); \
◆ T_flags_lt_uint
#define T_flags_lt_uint (   a,
  e,
  flags
Value:
T_check_lt_uint(a, &T_check_instance, e); \
◆ T_flags_lt_ull
#define T_flags_lt_ull (   a,
  e,
  flags
Value:
T_check_lt_ull(a, &T_check_instance, e); \
◆ T_flags_lt_ulong
#define T_flags_lt_ulong (   a,
  e,
  flags
Value:
T_check_lt_ulong(a, &T_check_instance, e); \
◆ T_flags_ne_char
#define T_flags_ne_char (   a,
  e,
  flags
Value:
T_check_ne_char(a, &T_check_instance, e); \
◆ T_flags_ne_int
#define T_flags_ne_int (   a,
  e,
  flags
Value:
T_check_ne_int(a, &T_check_instance, e); \
◆ T_flags_ne_ll
#define T_flags_ne_ll (   a,
  e,
  flags
Value:
T_check_ne_ll(a, &T_check_instance, e); \
◆ T_flags_ne_long
#define T_flags_ne_long (   a,
  e,
  flags
Value:
T_check_ne_long(a, &T_check_instance, e); \
◆ T_flags_ne_mem
#define T_flags_ne_mem (   a,
  e,
  n,
  flags,
  sa,
  se,
  sn
Value:
"memcmp(" sa ", " se ", " sn ") != 0" }; \
T_check_ne_mem(a, &T_check_instance, e, n); \
◆ T_flags_ne_nstr
#define T_flags_ne_nstr (   a,
  e,
  n,
  flags
Value:
T_check_ne_nstr(a, &T_check_instance, e, n); \
◆ T_flags_ne_ptr
#define T_flags_ne_ptr (   a,
  e,
  flags,
  sa,
  se
Value:
{ T_FILE_NAME, __LINE__, flags }, sa " != " se }; \
T_check_ne_ptr(a, &T_check_instance, e); \
◆ T_flags_ne_str
#define T_flags_ne_str (   a,
  e,
  flags
Value:
T_check_ne_str(a, &T_check_instance, e); \
◆ T_flags_ne_uint
#define T_flags_ne_uint (   a,
  e,
  flags
Value:
T_check_ne_uint(a, &T_check_instance, e); \
◆ T_flags_ne_ull
#define T_flags_ne_ull (   a,
  e,
  flags
Value:
T_check_ne_ull(a, &T_check_instance, e); \
◆ T_flags_ne_ulong
#define T_flags_ne_ulong (   a,
  e,
  flags
Value:
T_check_ne_ulong(a, &T_check_instance, e); \
◆ T_flags_not_null
#define T_flags_not_null (   a,
  flags,
  sa
Value:
{ T_FILE_NAME, __LINE__, flags }, sa }; \
T_check_not_null(a, &T_check_instance); \
◆ T_flags_null
#define T_flags_null (   a,
  flags,
  sa
Value:
T_check_null(a, &T_check_instance); \
◆ T_flags_psx_error
#define T_flags_psx_error (   a,
  eno,
  flags
Value:
T_check_psx_error(a, &T_check_instance, eno); \
◆ T_flags_psx_success
#define T_flags_psx_success (   a,
  flags
Value:
T_check_psx_success(a, &T_check_instance); \
◆ T_flags_true
#define T_flags_true (   a,
  flags,
Value:
T_check_true(a, &T_check_instance, __VA_ARGS__); \
