RTEMS 5.2-rc1
Files | Macros | Typedefs | Functions
Thread States
SuperCore Thread States. More...
file  states.h
 Thread Execution State Information.
file  statesimpl.h
 Inlined Routines Associated with Thread State Information.
#define STATES_READY   0x00000000
#define STATES_WAITING_FOR_MUTEX   0x00000001
#define STATES_WAITING_FOR_SEMAPHORE   0x00000002
#define STATES_WAITING_FOR_EVENT   0x00000004
#define STATES_WAITING_FOR_SYSTEM_EVENT   0x00000008
#define STATES_WAITING_FOR_MESSAGE   0x00000010
#define STATES_WAITING_FOR_CONDITION_VARIABLE   0x00000020
#define STATES_WAITING_FOR_FUTEX   0x00000040
#define STATES_WAITING_FOR_BSD_WAKEUP   0x00000080
#define STATES_WAITING_FOR_TIME   0x00000100
 This macro corresponds to a task which is waiting for a relative or absolute timeout.
#define STATES_WAITING_FOR_PERIOD   0x00000200
#define STATES_WAITING_FOR_SIGNAL   0x00000400
#define STATES_WAITING_FOR_BARRIER   0x00000800
#define STATES_WAITING_FOR_RWLOCK   0x00001000
#define STATES_WAITING_FOR_JOIN_AT_EXIT   0x00002000
#define STATES_WAITING_FOR_JOIN   0x00004000
#define STATES_SUSPENDED   0x00008000
#define STATES_WAITING_FOR_SEGMENT   0x00010000
#define STATES_LIFE_IS_CHANGING   0x00020000
#define STATES_DEBUGGER   0x08000000
#define STATES_INTERRUPTIBLE_BY_SIGNAL   0x10000000
#define STATES_WAITING_FOR_RPC_REPLY   0x20000000
#define STATES_ZOMBIE   0x40000000
#define STATES_DORMANT   0x80000000
#define STATES_LOCALLY_BLOCKED
#define STATES_BLOCKED
#define STATES_ALL_SET   0xffffffff
typedef uint32_t States_Control
RTEMS_INLINE_ROUTINE States_Control _States_Set (States_Control states_to_set, States_Control current_state)
 Returns the result of setting the states to set to the given state. More...
RTEMS_INLINE_ROUTINE States_Control _States_Clear (States_Control states_to_clear, States_Control current_state)
 Clears the states into the passed current state and returns the result. More...
RTEMS_INLINE_ROUTINE bool _States_Is_ready (States_Control the_states)
 Checks if the state is ready. More...
RTEMS_INLINE_ROUTINE bool _States_Is_dormant (States_Control the_states)
 Checks if DORMANT state is set. More...
RTEMS_INLINE_ROUTINE bool _States_Is_suspended (States_Control the_states)
 Checks if SUSPENDED state is set. More...
RTEMS_INLINE_ROUTINE bool _States_Is_waiting_for_rpc_reply (States_Control the_states)
 Checks if WAITING_FOR_TIME state is set. More...
RTEMS_INLINE_ROUTINE bool _States_Is_waiting_for_join_at_exit (States_Control the_states)
 Checks if WAITING_FOR_JOIN_AT_EXIT state is set. More...
RTEMS_INLINE_ROUTINE bool _States_Is_interruptible_by_signal (States_Control the_states)
 Checks if the state is set to be interruptible. More...
RTEMS_INLINE_ROUTINE bool _States_Is_locally_blocked (States_Control the_states)
 Checks if the state is blocked waiting on a local resource. More...
This handler encapsulates functionality which relates to the management of the state bitmap associated with each thread.
◆ STATES_ALL_SET
All state bits set to one (provided for _Thread_Start())
◆ STATES_BLOCKED
Value:
STATES_WAITING_FOR_TIME | \
STATES_WAITING_FOR_PERIOD | \
STATES_WAITING_FOR_EVENT | \
STATES_WAITING_FOR_RPC_REPLY | \
STATES_WAITING_FOR_SYSTEM_EVENT | \
STATES_INTERRUPTIBLE_BY_SIGNAL )
Definition: statesimpl.h:122
This macro corresponds to a task waiting which is blocked.
◆ STATES_DEBUGGER
This macro corresponds to a task being held by the debugger.
◆ STATES_DORMANT
This macro corresponds to a task being created but not yet started.
◆ STATES_INTERRUPTIBLE_BY_SIGNAL
This macro corresponds to a task which is in an interruptible blocking state.
◆ STATES_LIFE_IS_CHANGING
This macro corresponds to a task those life is changing.
◆ STATES_LOCALLY_BLOCKED
Value:
STATES_WAITING_FOR_MESSAGE | \
STATES_WAITING_FOR_SEMAPHORE | \
STATES_WAITING_FOR_MUTEX | \
STATES_WAITING_FOR_CONDITION_VARIABLE | \
STATES_WAITING_FOR_JOIN | \
STATES_WAITING_FOR_SIGNAL | \
STATES_WAITING_FOR_BARRIER | \
STATES_WAITING_FOR_BSD_WAKEUP | \
STATES_WAITING_FOR_FUTEX | \
STATES_WAITING_FOR_RWLOCK )
Definition: statesimpl.h:99
This macro corresponds to a task waiting for a local object operation.
◆ STATES_READY
This macro corresponds to a task being ready.
◆ STATES_SUSPENDED
This macro corresponds to a task being suspended.
◆ STATES_WAITING_FOR_BARRIER
This macro corresponds to a task waiting for a barrier.
◆ STATES_WAITING_FOR_BSD_WAKEUP
This macro corresponds to a task waiting for BSD wakeup.
◆ STATES_WAITING_FOR_CONDITION_VARIABLE
This macro corresponds to a task waiting for a condition variable.
◆ STATES_WAITING_FOR_EVENT
This macro corresponds to a task waiting for an event.
◆ STATES_WAITING_FOR_FUTEX
This macro corresponds to a task waiting for a futex.
◆ STATES_WAITING_FOR_JOIN
This macro corresponds to a task waiting for a join.
◆ STATES_WAITING_FOR_JOIN_AT_EXIT
This macro corresponds to a task waiting for a join while exiting.
◆ STATES_WAITING_FOR_MESSAGE
This macro corresponds to a task waiting for a message.
◆ STATES_WAITING_FOR_MUTEX
This macro corresponds to a task waiting for a mutex.
◆ STATES_WAITING_FOR_PERIOD
This macro corresponds to a task waiting for a period.
◆ STATES_WAITING_FOR_RPC_REPLY
This macro corresponds to a task waiting for a reply to an MPCI request.
◆ STATES_WAITING_FOR_RWLOCK
This macro corresponds to a task waiting for a RWLock.
◆ STATES_WAITING_FOR_SEGMENT
This macro corresponds to a task waiting for a fixed size segment.
◆ STATES_WAITING_FOR_SEMAPHORE
This macro corresponds to a task waiting for a semaphore.
◆ STATES_WAITING_FOR_SIGNAL
This macro corresponds to a task waiting for a signal.
◆ STATES_WAITING_FOR_SYSTEM_EVENT
This macro corresponds to a task waiting for a system event.
◆ STATES_ZOMBIE
This macro corresponds to a task being a zombie.
Typedef Documentation
◆ States_Control
The following type defines the control block used to manage a thread's state.
◆ _States_Clear()
RTEMS_INLINE_ROUTINE States_Control _States_Clear ( States_Control  states_to_clear,
This function clears the given states_to_clear into the current_state passed in. The result is returned to the user in current_state.
Parameters
states_to_clearThe state bits to clear.
current_stateThe state set to remove them from.
Returns
This method returns the updated states value.
◆ _States_Is_dormant()
RTEMS_INLINE_ROUTINE bool _States_Is_dormant ( States_Control  the_states)
This function returns true if the DORMANT state is set in the_states, and false otherwise.
Parameters
the_statesThe task state set to test.
Return values
trueDORMANT state is set in the_states.
falseDORMANT state is not set in the_states.
◆ _States_Is_interruptible_by_signal()
RTEMS_INLINE_ROUTINE bool _States_Is_interruptible_by_signal ( States_Control  the_states)
This function returns true if the task's state is set in way that allows it to be interrupted by a signal.
Parameters
Return values
truethe_states is interruptible.
falsethe_states is not interruptible.
◆ _States_Is_locally_blocked()
RTEMS_INLINE_ROUTINE bool _States_Is_locally_blocked ( States_Control  the_states)
This function returns true if one of the states which indicates that a task is blocked waiting for a local resource is set in the_states, and false otherwise.
Parameters
Return values
trueThe state indicates that the task is blocked waiting on a local resource.
falseThe state indicates that the task is not blocked waiting on a local resource.
◆ _States_Is_ready()
RTEMS_INLINE_ROUTINE bool _States_Is_ready ( States_Control  the_states)
This function returns true if the_states indicates that the state is READY, and false otherwise.
Parameters
Return values
trueThe state is ready.
falseThe state is not ready.
◆ _States_Is_suspended()
RTEMS_INLINE_ROUTINE bool _States_Is_suspended ( States_Control  the_states)
This function returns true if the SUSPENDED state is set in the_states, and false otherwise.
Parameters
Return values
trueSUSPENDED state is set in the_states.
falseSUSPENDED state is not set in the_states.
◆ _States_Is_waiting_for_join_at_exit()
RTEMS_INLINE_ROUTINE bool _States_Is_waiting_for_join_at_exit ( States_Control  the_states)
This function returns true if the WAITING_FOR_JOIN_AT_EXIT state is set in the_states, and false otherwise.
Parameters
Return values
trueWAITING_FOR_JOIN_AT_EXIT state is set in the_states.
falseWAITING_FOR_JOIN_AT_EXIT state is not set in the_states.
◆ _States_Is_waiting_for_rpc_reply()
RTEMS_INLINE_ROUTINE bool _States_Is_waiting_for_rpc_reply ( States_Control  the_states)
This function returns true if the WAITING_FOR_TIME state is set in the_states, and false otherwise.
Parameters
Return values
trueWAITING_FOR_TIME state is set in the_states.
falseWAITING_FOR_TIME state is not set in the_states.
◆ _States_Set()
RTEMS_INLINE_ROUTINE States_Control _States_Set ( States_Control  states_to_set,
This function sets the given states_to_set into the current_state passed in. The result is returned to the user in current_state.
Parameters
states_to_setThe state bits to set.
current_stateThe state set to add them to.
Returns
