RTEMS 5.2-rc1
Strong APA Scheduler. More...
Files | |
| file | schedulerstrongapa.h |
| Strong APA Scheduler API. | |
| file | schedulerstrongapa.c |
| Strong APA Scheduler Implementation. | |
| struct | Scheduler_strong_APA_Context |
| Scheduler context specialization for Strong APA schedulers. More... | |
| struct | Scheduler_strong_APA_Node |
| Scheduler node specialization for Strong APA schedulers. More... | |
| #define | SCHEDULER_STRONG_APA_ENTRY_POINTS |
| Entry points for the Strong APA Scheduler. More... | |
This is an implementation of the global fixed priority scheduler (G-FP). It uses one ready chain per priority to ensure constant time insert operations. The scheduled chain uses linear insert operations and has at most processor count entries. Since the processor and priority count are constants all scheduler operations complete in a bounded execution time.
The the_thread preempt mode will be ignored.
| #define SCHEDULER_STRONG_APA_ENTRY_POINTS |
| void _Scheduler_strong_APA_Add_processor | ( | const Scheduler_Control * | scheduler, |
| Thread_Control * | idle | ||
Adds the idle thread to a processor.
| scheduler | The scheduler control instance. | |
| [in,out] | The | idle thread to add to the processor. |
| bool _Scheduler_strong_APA_Ask_for_help | ( | const Scheduler_Control * | scheduler, |
| Thread_Control * | the_thread, | ||
| Scheduler_Node * | node | ||
Asks for help.
| the_thread | The thread that asks for help. |
| node | The node of the_thread. |
| true | The request for help was successful. |
| false | The request for help was not successful. |
| void _Scheduler_strong_APA_Block | ( | const Scheduler_Control * | scheduler, |
Blocks the thread.
| [in,out] | the_thread | The thread to block. |
| [in,out] | node | The node of the thread to block. |
| void _Scheduler_strong_APA_Initialize | ( | const Scheduler_Control * | scheduler | ) |
Initializes the scheduler.
| scheduler | The scheduler to initialize. |
| void _Scheduler_strong_APA_Node_initialize | ( | const Scheduler_Control * | scheduler, |
| Scheduler_Node * | node, | ||
| Priority_Control | priority | ||
Initializes the node with the given priority.
| [out] | node | The node to initialize. |
| the_thread | The thread of the node to initialize. | |
| priority | The priority for node. |
| void _Scheduler_strong_APA_Reconsider_help_request | ( | const Scheduler_Control * | scheduler, |
Reconsiders help request.
| the_thread | The thread to reconsider the help request of. | |
| [in,out] | node | The node of the_thread |
| Thread_Control * _Scheduler_strong_APA_Remove_processor | ( | const Scheduler_Control * | scheduler, |
| struct Per_CPU_Control * | cpu | ||
Removes an idle thread from the given cpu.
| scheduler | The scheduler instance. |
| cpu | The cpu control to remove from scheduler. |
| void _Scheduler_strong_APA_Unblock | ( | const Scheduler_Control * | scheduler, |
Unblocks the thread.
| [in,out] | the_thread | The thread to unblock. |
| [in,out] | node | The node of the thread to unblock. |
| void _Scheduler_strong_APA_Update_priority | ( | const Scheduler_Control * | scheduler, |
Updates the priority of the node.
| the_thread | The thread for the operation. | |
| [in,out] | node | The node to update the priority of. |
| void _Scheduler_strong_APA_Withdraw_node | ( | const Scheduler_Control * | scheduler, |
| Thread_Scheduler_state | next_state | ||
Withdraws the node.
| [in,out] | the_thread | The thread to change the state to next_state. |
| [in,out] | node | The node to withdraw. |
| next_state | The next state for the_thread. |
| void _Scheduler_strong_APA_Yield | ( | const Scheduler_Control * | scheduler, |
Performs a yield operation.
| the_thread | The thread to yield. | |
| [in,out] | node | The node of the_thread. |
