RTEMS 5.2-rc1
Files | Functions
Protected Heap Handler
Provides protected heap services. More...
file  protectedheap.h
 Protected Heap Handler API.
file  pheapallocate.c
 Protected Heap Handler implementation.
file  pheapextend.c
file  pheapfree.c
file  pheapgetblocksize.c
file  pheapgetfreeinfo.c
file  pheapgetinfo.c
file  pheapgetsize.c
file  pheapinit.c
file  pheapiterate.c
 _Heap_Iterate() implementation.
file  pheapresizeblock.c
file  pheapwalk.c
RTEMS_INLINE_ROUTINE uintptr_t _Protected_heap_Initialize (Heap_Control *heap, void *area_begin, uintptr_t area_size, uintptr_t page_size)
 Initializes the protected heap. More...
bool _Protected_heap_Extend (Heap_Control *heap, void *area_begin, uintptr_t area_size)
 Extends the protected heap. More...
void * _Protected_heap_Allocate_aligned_with_boundary (Heap_Control *heap, uintptr_t size, uintptr_t alignment, uintptr_t boundary)
 Allocates an aligned memory area with boundary constraint for the protected heap. More...
RTEMS_INLINE_ROUTINE void * _Protected_heap_Allocate_aligned (Heap_Control *heap, uintptr_t size, uintptr_t alignment)
 Allocates an aligned memory area. More...
RTEMS_INLINE_ROUTINE void * _Protected_heap_Allocate (Heap_Control *heap, uintptr_t size)
 Allocates a memory area. More...
bool _Protected_heap_Get_block_size (Heap_Control *heap, void *addr, uintptr_t *size)
 Returns the size of the allocatable memory area. More...
bool _Protected_heap_Resize_block (Heap_Control *heap, void *addr, uintptr_t size)
 Resizes the block of the allocated memory area. More...
bool _Protected_heap_Free (Heap_Control *heap, void *addr)
 Frees the allocated memory area. More...
bool _Protected_heap_Walk (Heap_Control *heap, int source, bool dump)
 Verifies the integrity of the heap. More...
void _Protected_heap_Iterate (Heap_Control *heap, Heap_Block_visitor visitor, void *visitor_arg)
 Iterates over all blocks of the heap. More...
bool _Protected_heap_Get_information (Heap_Control *heap, Heap_Information_block *info)
 Returns information about used and free blocks for the heap. More...
bool _Protected_heap_Get_free_information (Heap_Control *heap, Heap_Information *info)
 Returns information about free blocks for the heap. More...
uintptr_t _Protected_heap_Get_size (Heap_Control *heap)
 Returns the size of the allocatable area in bytes. More...
The ScoreAllocatorMutex is used to protect the heap accesses.
◆ _Protected_heap_Allocate()
RTEMS_INLINE_ROUTINE void * _Protected_heap_Allocate ( Heap_Control heap,
uintptr_t  size
A size value of zero will return a unique address which may be freed with _Heap_Free(). This method first locks the allocator and after the allocation of the memory area, unlocks it again.
Parameters
[in,out]heapThe heap to allocate a memory are from.
sizeThe size of the desired memory are in bytes.
Return values
pointerThe starting address of the allocated memory area.
NULLNo memory is available of the parameters are inconsistent.
◆ _Protected_heap_Allocate_aligned()
RTEMS_INLINE_ROUTINE void * _Protected_heap_Allocate_aligned ( Heap_Control heap,
uintptr_t  size,
uintptr_t  alignment
Parameters
alignmentThe allocated memory area will begin at an address aligned by this value.
Return values
◆ _Protected_heap_Allocate_aligned_with_boundary()
void * _Protected_heap_Allocate_aligned_with_boundary ( Heap_Control heap,
uintptr_t  size,
uintptr_t  boundary
Parameters
boundaryThe allocated memory area will fulfill a boundary constraint, if this value is not equal to zero. The boundary value specifies the set of addresses which are aligned by the boundary value. The interior of the allocated memory area will not contain an element of this set. The begin or end address of the area may be a member of the set.
Return values
◆ _Protected_heap_Extend()
bool _Protected_heap_Extend ( Heap_Control heap,
void *  area_begin,
uintptr_t  area_size
Parameters
[in,out]heapThe heap to extend.
area_beginThe starting addres of the area to extend heap with.
area_sizeThe size of the heap area.
Return values
trueThe operation succeeded.
falseThe operation failed.
◆ _Protected_heap_Free()
bool _Protected_heap_Free ( Heap_Control heap,
void *  addr
Inappropriate values for addr may corrupt the heap. This method first locks the allocator and after the free operation, unlocks it again.
Parameters
[in,out]heapThe heap of the allocated memory area.
addrThe starting address of the memory area to be freed.
Return values
trueThe allocated memory area was successfully freed.
falseThe method failed.
◆ _Protected_heap_Get_block_size()
bool _Protected_heap_Get_block_size ( Heap_Control heap,
void *  addr,
uintptr_t *  size
The size value may be greater than the initially requested size in _Heap_Allocate_aligned_with_boundary().
Inappropriate values for addr will not corrupt the heap, but may yield invalid size values.
This method first locks the allocator and after the operation, unlocks it again.
Parameters
heapThe heap to operate upon.
addrThe starting address of the allocatable memory area.
[out]sizeStores the size of the allocatable memory area after the method call.
Return values
trueThe operation was successful.
falseThe operation was not successful.
◆ _Protected_heap_Get_free_information()
bool _Protected_heap_Get_free_information ( Heap_Control heap,
Heap_Information info
Parameters
heapThe heap to get the information from.
[out]infoStores the information about free blocks of heap after the method call.
◆ _Protected_heap_Get_information()
bool _Protected_heap_Get_information ( Heap_Control heap,
Heap_Information_block info
Parameters
[out]infoStores the information of the heap after the method call.
◆ _Protected_heap_Get_size()
uintptr_t _Protected_heap_Get_size ( Heap_Control heap)
This value is an integral multiple of the page size.
Parameters
heapThe heap to get the allocatable area from.
Returns
The size of the allocatable area in heap in bytes.
◆ _Protected_heap_Initialize()
RTEMS_INLINE_ROUTINE uintptr_t _Protected_heap_Initialize ( Heap_Control heap,
void *  area_begin,
uintptr_t  page_size
Parameters
[out]heapThe heap to initialize.
area_beginThe starting address of the heap area.
page_sizeThe page size for the heap.
◆ _Protected_heap_Iterate()
void _Protected_heap_Iterate ( Heap_Control heap,
void *  visitor_arg
Parameters
[in,out]heapThe heap to iterate over.
visitorThis will be called for each heap block with the argument visitor_arg.
[in,out]visitor_argThe argument for all calls of visitor.
◆ _Protected_heap_Resize_block()
bool _Protected_heap_Resize_block ( Heap_Control heap,
void *  addr,
uintptr_t  size
This method first locks the allocator and after the resize, unlocks it again.
Parameters
[in,out]heapThe heap to operate upon.
addrThe starting address of the allocated memory area to be resized.
sizeThe least possible size for the new memory area. Resize may be impossible and depends on the current heap usage.
[out]old_sizeStores the size available for allocation in the current block before the resize after the method call.
[out]new_sizeStores the size available for allocation in the resized block after the method call. In the case of an unsuccessful resize, zero is returned in this parameter
Return values
HEAP_RESIZE_SUCCESSFULThe resize was successful.
HEAP_RESIZE_UNSATISFIEDThe least possible size size was too big. Resize not possible.
HEAP_RESIZE_FATAL_ERRORThe block starting at addr is not part of the heap.
◆ _Protected_heap_Walk()
bool _Protected_heap_Walk ( Heap_Control heap,
int  source,
bool  dump
Walks the heap to verify its integrity. This method first locks the allocator and after the operation, unlocks it again, if the thread dispatch is enabled.
Parameters
heapThe heap whose integrity is to be verified.
sourceIf dump is true, this is used to mark the output lines.
dumpIndicates whether diagnostic messages will be printed to standard output.
Return values
trueNo errors occured, the heap“s integrity is not violated.
falseThe heap is corrupt.
