RTEMS 5.2-rc1
Mutex Handler. More...
Files | |
| file | coremutex.h |
| CORE Mutex API. | |
| file | coremuteximpl.h |
| CORE Mutex Implementation. | |
| file | coremutexseize.c |
| Seize Mutex with Blocking. | |
| struct | CORE_mutex_Control |
| Control block used to manage each mutex. More... | |
| struct | CORE_recursive_mutex_Control |
| The recursive mutex control. More... | |
| struct | CORE_ceiling_mutex_Control |
| The recursive mutex control with priority ceiling protocol support. More... | |
| #define | CORE_MUTEX_TQ_OPERATIONS &_Thread_queue_Operations_priority |
| #define | CORE_MUTEX_TQ_PRIORITY_INHERIT_OPERATIONS &_Thread_queue_Operations_priority_inherit |
Mutex Handler.
This handler encapsulates functionality which provides the foundation Mutex services used in all of the APIs supported by RTEMS.
| RTEMS_INLINE_ROUTINE Priority_Control _CORE_ceiling_mutex_Get_priority | ( | const CORE_ceiling_mutex_Control * | the_mutex | ) |
Gets the priority of the ceiling mutex.
| the_mutex | The mutex to get the priority from. |
| RTEMS_INLINE_ROUTINE const Scheduler_Control * _CORE_ceiling_mutex_Get_scheduler | ( | const CORE_ceiling_mutex_Control * | the_mutex | ) |
Gets the scheduler of the ceiling mutex.
| the_mutex | The ceiling mutex to get the scheduler from. |
| RTEMS_INLINE_ROUTINE void _CORE_ceiling_mutex_Initialize | ( | CORE_ceiling_mutex_Control * | the_mutex, |
| const Scheduler_Control * | scheduler, | ||
| Priority_Control | priority_ceiling | ||
initializes a ceiling mutex.
| [out] | the_mutex | The ceiling mutex to initialize. |
| scheduler | The scheduler for the new ceiling mutex. Only needed if RTEMS_SMP is defined | |
| priority_ceiling | The priority ceiling for the initialized mutex. |
| RTEMS_INLINE_ROUTINE Status_Control _CORE_ceiling_mutex_Seize | ( | CORE_ceiling_mutex_Control * | the_mutex, |
| Thread_Control * | executing, | ||
| bool | wait, | ||
| Status_Control(*)(CORE_recursive_mutex_Control *) | nested, | ||
| Thread_queue_Context * | queue_context | ||
Seizes the ceiling mutex.
| [in,out] | the_mutex | The mutex to seize. |
| executing | The executing thread. | |
| wait | Indicates whether the calling thread is willing to wait. | |
| nested | Function that returns the status of the recursive mutex | |
| queue_context | The thread queue context. |
| STATUS_SUCCESSFUL | The owner of the mutex was changed successfully. |
| STATUS_NOT_DEFINED | If the scheduler of the executing thread is not equal to the owner of the_mutex . |
| STATUS_MUTEX_CEILING_VIOLATED | The owners wait priority is smaller than the priority of the ceiling mutex. |
| other | Return value of nested. |
| RTEMS_INLINE_ROUTINE Status_Control _CORE_ceiling_mutex_Set_owner | ( | CORE_ceiling_mutex_Control * | the_mutex, |
| Thread_Control * | owner, | ||
Sets the owner of the ceiling mutex.
| [in,out] | the_mutex | The mutex to set the owner of. |
| owner | The new owner of the_mutex. | |
| RTEMS_INLINE_ROUTINE void _CORE_ceiling_mutex_Set_priority | ( | CORE_ceiling_mutex_Control * | the_mutex, |
| Priority_Control | priority_ceiling, | ||
Sets the priority of the ceiling mutex.
| [out] | the_mutex | The ceiling mutex to set the priority of. |
| priority_ceiling | The new priority ceiling of the mutex. | |
| RTEMS_INLINE_ROUTINE Status_Control _CORE_ceiling_mutex_Surrender | ( | CORE_ceiling_mutex_Control * | the_mutex, |
Surrenders the ceiling mutex.
| [in,out] | the_mutex | The ceiling mutex to surrender. |
| STATUS_SUCCESSFUL | The ceiling mutex was successfullysurrendered. |
| STATUS_NOT_OWNER | The executing thread is not the owner of the_mutex. |
| RTEMS_INLINE_ROUTINE void _CORE_mutex_Acquire_critical | ( | CORE_mutex_Control * | the_mutex, |
Acquires the mutex critical.
| [in,out] | the_mutex | The mutex to acquire critical. |
| queue_context | The queue context. |
| RTEMS_INLINE_ROUTINE void _CORE_mutex_Destroy | ( | CORE_mutex_Control * | the_mutex | ) |
Destroys the mutex.
| [out] | the_mutex | the mutex to destroy. |
| RTEMS_INLINE_ROUTINE Thread_Control * _CORE_mutex_Get_owner | ( | const CORE_mutex_Control * | the_mutex | ) |
Gets the owner of the mutex.
| the_mutex | The mutex to get the owner from. |
| RTEMS_INLINE_ROUTINE void _CORE_mutex_Initialize | ( | CORE_mutex_Control * | the_mutex | ) |
Initializes the mutex.
| [out] | the_mutex | The mutex to initialize. |
| RTEMS_INLINE_ROUTINE bool _CORE_mutex_Is_locked | ( | const CORE_mutex_Control * | the_mutex | ) |
Checks if the mutex is locked.
This routine returns true if the specified mutex is locked and false otherwise.
| the_mutex | The mutex to check if it is locked. |
| true | The mutex is locked. |
| false | The mutex is not locked. |
| RTEMS_INLINE_ROUTINE bool _CORE_mutex_Is_owner | ( | const CORE_mutex_Control * | the_mutex, |
| const Thread_Control * | the_thread | ||
Checks if the the thread is the owner of the mutex.
| the_mutex | The mutex to check the owner of. |
| the_thread | The thread to check if it is the owner of the_mutex. |
| true | the_thread is the owner of the_mutex. |
| false | the_thread is not the owner of the_mutex. |
| RTEMS_INLINE_ROUTINE void _CORE_mutex_Release | ( | CORE_mutex_Control * | the_mutex, |
Releases the mutex.
| [in,out] | the_mutex | The mutex to release. |
| Status_Control _CORE_mutex_Seize_slow | ( | CORE_mutex_Control * | the_mutex, |
| const Thread_queue_Operations * | operations, | ||
| bool | wait, | ||
Seize the mutex slowly.
| operations | The thread queue operations. | |
| executing | The calling thread. | |
| _Thread_Wait_get_status | The status of the executing thread. |
| STATUS_UNAVAILABLE | The calling thread is not willing to wait. |
| RTEMS_INLINE_ROUTINE void _CORE_mutex_Set_owner | ( | CORE_mutex_Control * | the_mutex, |
| Thread_Control * | owner | ||
Sets the owner of the mutex.
| [out] | the_mutex | The mutex to set the owner from. |
| owner | The new owner of the mutex. |
| RTEMS_INLINE_ROUTINE void _CORE_recursive_mutex_Initialize | ( | CORE_recursive_mutex_Control * | the_mutex | ) |
Initializes a recursive mutex.
| [out] | the_mutex | The recursive mutex to initialize. |
| RTEMS_INLINE_ROUTINE Status_Control _CORE_recursive_mutex_Seize | ( | CORE_recursive_mutex_Control * | the_mutex, |
| bool | wait, | ||
Seizes the recursive mutex.
| [in,out] | the_mutex | The recursive mutex to seize. |
| [out] | executing | The executing thread. |
| nested | Returns the status of a recursive mutex. | |
| STATUS_SUCCESSFUL | The owner of the mutex was NULL, successful seizing of the mutex. |
| RTEMS_INLINE_ROUTINE Status_Control _CORE_recursive_mutex_Seize_nested | ( | CORE_recursive_mutex_Control * | the_mutex | ) |
Seizes the recursive mutex nested.
| [out] | the_mutex | The recursive mutex to seize nested. |
| RTEMS_INLINE_ROUTINE Status_Control _CORE_recursive_mutex_Surrender | ( | CORE_recursive_mutex_Control * | the_mutex, |
Surrenders the recursive mutex.
| [in,out] | the_mutex | The recursive mutex to surrender. |
| queue_context | the thread queue context. |
| STATUS_SUCCESSFUL | the_mutex is successfully surrendered. |
| STATUS_NOT_OWNER | The executing thread does not own the_mutex. |
