RTEMS 5.2-rc1
Processor Dependent Interrupt Management
i386 Interrupt Management More...
typedef void(* rtems_raw_irq_hdl) (void)
typedef void(* rtems_raw_irq_enable) (const struct __rtems_raw_irq_connect_data__ *)
typedef void(* rtems_raw_irq_disable) (const struct __rtems_raw_irq_connect_data__ *)
typedef int(* rtems_raw_irq_is_enabled) (const struct __rtems_raw_irq_connect_data__ *)
Interrupt Level Macros
#define i386_disable_interrupts(_level)
#define i386_enable_interrupts(_level)
#define i386_flash_interrupts(_level)
#define i386_get_interrupt_level(_level)
◆ i386_disable_interrupts
#define i386_disable_interrupts (   _level)
Value:
__asm__ volatile ( "pushf ; \ cli ; \ pop %0" \
: "=rm" ((_level)) \
◆ i386_enable_interrupts
#define i386_enable_interrupts (   _level)
Value:
__asm__ volatile ( "push %0 ; \ popf" \
: : "rm" ((_level)) : "cc" \
◆ i386_flash_interrupts
#define i386_flash_interrupts (   _level)
Value:
__asm__ volatile ( "push %0 ; \ popf ; \ cli" \
◆ i386_get_interrupt_level
#define i386_get_interrupt_level (   _level)
Value:
do { \
uint32_t _eflags; \
__asm__ volatile ( "pushf ; \ pop %0" \
: "=rm" ((_eflags)) \
_level = (_eflags & EFLAGS_INTR_ENABLE) ? 0 : 1; \
} while (0)
