RTEMS 5.2-rc1
Processor Dependent Bitfield Manipulation
#define CPU_USE_GENERIC_BITFIELD_CODE   TRUE
#define _CPU_Bitfield_Find_first_bit(_value, _output)
This set of routines are used to implement fast searches for the most important ready task.
This routine translates the bit numbers returned by _CPU_Bitfield_Find_first_bit into something suitable for use as a major or minor component of a priority. See the discussion for that routine.
Parameters
[in]_priorityis the major or minor number to translate
Port Specific Information:
XXX document implementation including references if appropriate
◆ _CPU_Bitfield_Find_first_bit
#define _CPU_Bitfield_Find_first_bit (   _value,
  _output
Value:
(_output) = 0; /* do something to prevent warnings */ \
This routine sets _output to the bit number of the first bit set in _value. _value is of CPU dependent type Priority_bit_map_Word. This type may be either 16 or 32 bits wide although only the 16 least significant bits will be used.
There are a number of variables in using a "find first bit" type instruction.
  1. What happens when run on a value of zero?
  2. Bits may be numbered from MSB to LSB or vice-versa.
  3. The numbering may be zero or one based.
  4. The "find first bit" instruction may search from MSB or LSB.
RTEMS guarantees that (1) will never happen so it is not a concern. (2),(3), (4) are handled by the macros _CPU_Priority_Mask and _CPU_Priority_bits_index. These three form a set of routines which must logically operate together. Bits in the _value are set and cleared based on masks built by _CPU_Priority_Mask. The basic major and minor values calculated by _Priority_Major and _Priority_Minor are "massaged" by _CPU_Priority_bits_index to properly range between the values returned by the "find first bit" instruction. This makes it possible for _Priority_Get_highest to calculate the major and directly index into the minor table. This mapping is necessary to ensure that 0 (a high priority major/minor) is the first bit found.
This entire "find first bit" and mapping process depends heavily on the manner in which a priority is broken into a major and minor components with the major being the 4 MSB of a priority and minor the 4 LSB. Thus (0 << 4) + 0 corresponds to priority 0 – the highest priority. And (15 << 4) + 14 corresponds to priority 254 – the next to the lowest priority.
If your CPU does not have a "find first bit" instruction, then there are ways to make do without it. Here are a handful of ways to implement this in software:
      - a series of 16 bit test instructions
      - a "binary search using if's"
      - _number = 0
        if _value > 0x00ff
          _value >>=8
          _number = 8;
        if _value > 0x0000f
          _value >=8
          _number += 4
        _number += bit_set_table[ _value ]
 where bit_set_table[ 16 ] has values which indicate the first
   bit set
Parameters
[in]_valueis the value to be scanned
[in]_outputis the first bit set
◆ CPU_USE_GENERIC_BITFIELD_CODE
This definition is set to TRUE if the port uses the generic bitfield manipulation implementation.
