RTEMS 5.2-rc1
Modules | Files | Macros | Functions
NXP MPC5200 Board Support Package. More...
 BestComm Support
 BestComm support.
 MSCAN
file  bsp.h
 Global BSP definitions.
#define NEED_LOW_LEVEL_INIT
#define RTEMS_BSP_NETWORK_DRIVER_NAME   "eth1"
#define RTEMS_BSP_NETWORK_DRIVER_ATTACH   rtems_mpc5200_fec_driver_attach_detach
#define RTEMS_BSP_HAS_IDE_DRIVER
#define ATA_USE_INT
#define IPB_CLOCK   33000000 /* 33 MHz */
#define XLB_CLOCK   66000000 /* 66 MHz */
#define G2_CLOCK   231000000 /* 231 MHz */
#define GEN5200_CONSOLE_BAUD   115200
#define BSP_Convert_decrementer(_value)    (int) (((_value) * 4000) / (XLB_CLOCK/10000))
#define USE_SLICETIMER_0   TRUE
#define USE_SLICETIMER_1   FALSE
#define BSP_IDLE_TASK_BODY   bsp_idle_thread
 LINKER_SYMBOL (bsp_ram_start)
 LINKER_SYMBOL (bsp_ram_end)
 LINKER_SYMBOL (bsp_ram_size)
 LINKER_SYMBOL (bsp_rom_start)
 LINKER_SYMBOL (bsp_rom_end)
 LINKER_SYMBOL (bsp_rom_size)
 LINKER_SYMBOL (bsp_dpram_start)
 LINKER_SYMBOL (bsp_dpram_end)
 LINKER_SYMBOL (bsp_dpram_size)
 LINKER_SYMBOL (bsp_section_text_start)
 LINKER_SYMBOL (bsp_section_text_end)
 LINKER_SYMBOL (bsp_section_text_size)
 LINKER_SYMBOL (bsp_section_data_start)
 LINKER_SYMBOL (bsp_section_data_end)
 LINKER_SYMBOL (bsp_section_data_size)
 LINKER_SYMBOL (bsp_section_bss_start)
 LINKER_SYMBOL (bsp_section_bss_end)
 LINKER_SYMBOL (bsp_section_bss_size)
 LINKER_SYMBOL (bsp_work_area_start)
 LINKER_SYMBOL (MBAR)
int rtems_mpc5200_fec_driver_attach_detach (struct rtems_bsdnet_ifconfig *config, int attaching)
void * bsp_idle_thread (uintptr_t ignored)
 Optimized idle task. More...
void BSP_IRQ_Benchmarking_Reset (void)
void BSP_IRQ_Benchmarking_Report (void)
void cpu_init (void)
int mpc5200_eth_mii_read (int phyAddr, void *arg, unsigned regAddr, uint32_t *retVal)
◆ bsp_idle_thread()
void * bsp_idle_thread ( uintptr_t  ignored)
This BSP provides its own IDLE thread to override the RTEMS one.
This idle task sets the power mode to idle. This causes the processor clock to be stopped, while on-chip peripherals remain active. Any enabled interrupt from a peripheral or an external interrupt source will cause the processor to resume execution.
To enable the idle task use the following in the system configuration:
#include <bsp.h>
#define CONFIGURE_INIT
#define CONFIGURE_IDLE_TASK_BODY bsp_idle_thread
#include <confdefs.h>
Evaluate Configuration Options.
The MSR[POW] bit is set to put the CPU into the low power mode defined in HID0. HID0 is set during starup in start.S.
#include <bsp.h>
