RTEMS 5.2-rc1
The Version API provides functions to return the version or parts of the version of RTEMS you are using. More...
Files | |
| file | version.c |
| Creates the version strings from the various pieces of version information. The main version number is part of the build system and is stamped into rtems/score/cpuopts.h. The version control key string is extracted from the version control tool when the code is being built and is updated if it has changed. The key may indicate there are local modification. | |
| const char * | rtems_version (void) |
| Returns the version string. More... | |
| int | rtems_version_major (void) |
| Returns the version's major number. More... | |
| int | rtems_version_minor (void) |
| Returns the version's minor number. More... | |
| int | rtems_version_revision (void) |
| Returns the version's revision number. More... | |
| const char * | rtems_version_control_key (void) |
| Returns the version control key for the current version of code that has been built. More... | |
| const char * | rtems_board_support_package (void) |
| Returns the board support package name. More... | |
A branch in the version control system will always fall back to a NOT-RELEASED version number with a minor number of 0. Only the release archives have a VERSION file with a final release number. That means for example that the 5 development branch will still show a version 5.0.0 even after the 5.1 release.
The reason for that are the following:
| const char * rtems_board_support_package | ( | void | ) |
| const char * rtems_version | ( | void | ) |
| text | The version as a string. |
| const char * rtems_version_control_key | ( | void | ) |
The key is specific to the version control system being used and allows the built version to be identified.
Use rtems_version_control_key_is_valid() to check if the version control key is valid.
| int rtems_version_major | ( | void | ) |
| int | The version's major number. |
| int rtems_version_minor | ( | void | ) |
| int | The version's minor number. |
| int rtems_version_revision | ( | void | ) |
| int | The version's revision number. |
