RTEMS 5.2-rc1
Modules | Files | Data Structures | Macros | Typedefs | Enumerations | Functions | Variables
RTEMS Per CPU Information
 Flexible Per-CPU Data
 Flexible Per-CPU Data.
file  percpu.c
 Allocate and Initialize Per CPU Structures.
struct  Per_CPU_Stats
 Per-CPU statistics. More...
struct  Per_CPU_Control
 Per CPU Core Structure. More...
struct  Per_CPU_Control_envelope
#define _Per_CPU_Acquire(cpu, lock_context)    _ISR_lock_Acquire( &( cpu )->Lock, lock_context )
#define _Per_CPU_Release(cpu, lock_context)    _ISR_lock_Release( &( cpu )->Lock, lock_context )
#define _Per_CPU_Get_snapshot()    ( &_Per_CPU_Information[ _SMP_Get_current_processor() ].per_cpu )
#define _Per_CPU_Get()   _Per_CPU_Get_snapshot()
#define _Thread_Dispatch_disable_level    _Per_CPU_Get()->thread_dispatch_disable_level
#define _Thread_Heir    _Per_CPU_Get()->heir
#define _Thread_Executing    _Per_CPU_Get_executing( _Per_CPU_Get() )
#define _ISR_Nest_level    _Per_CPU_Get()->isr_nest_level
#define _CPU_Interrupt_stack_low    _Per_CPU_Get()->interrupt_stack_low
#define _CPU_Interrupt_stack_high    _Per_CPU_Get()->interrupt_stack_high
#define _Thread_Dispatch_necessary    _Per_CPU_Get()->dispatch_necessary
typedef struct Per_CPU_Control Per_CPU_Control
enum  Per_CPU_Watchdog_index { PER_CPU_WATCHDOG_TICKS , PER_CPU_WATCHDOG_REALTIME , PER_CPU_WATCHDOG_MONOTONIC , PER_CPU_WATCHDOG_COUNT }
 Per-CPU watchdog header index. More...
RTEMS_INLINE_ROUTINE void _Per_CPU_Acquire_all (ISR_lock_Context *lock_context)
RTEMS_INLINE_ROUTINE void _Per_CPU_Release_all (ISR_lock_Context *lock_context)
RTEMS_INLINE_ROUTINE struct _Thread_Control_Thread_Get_executing (void)
 Returns the thread control block of the executing thread. More...
Per_CPU_Control_envelope _Per_CPU_Information[] CPU_STRUCTURE_ALIGNMENT
 Set of Per CPU Core Information. More...
This defines the per CPU state information required by RTEMS and the BSP. In an SMP configuration, there will be multiple instances of this data structure – one per CPU – and the current CPU number will be used as the index.
Typedef Documentation
◆ Per_CPU_Control
This structure is used to hold per core state information.
◆ Per_CPU_Watchdog_index
Index for tick clock per-CPU watchdog header.
The reference time point for the tick clock is the system start. The clock resolution is one system clock tick. It is used for the system clock tick based time services.
Index for realtime clock per-CPU watchdog header.
The reference time point for the realtime clock is the POSIX Epoch. The clock resolution is one nanosecond. It is used for the time of day services and the POSIX services using CLOCK_REALTIME.
Index for monotonic clock per-CPU watchdog header.
The reference time point for the monotonic clock is the system start. The clock resolution is one nanosecond. It is used for the POSIX services using CLOCK_MONOTONIC.
Count of per-CPU watchdog headers.
◆ _Thread_Get_executing()
RTEMS_INLINE_ROUTINE struct _Thread_Control * _Thread_Get_executing ( void  )
This function can be called in any thread context. On SMP configurations, interrupts are disabled to ensure that the processor index is used consistently if no CPU port specific method is available to get the executing thread.
Returns
The thread control block of the executing thread.
Variable Documentation
◆ CPU_STRUCTURE_ALIGNMENT
Per_CPU_Control_envelope _Per_CPU_Information [] CPU_STRUCTURE_ALIGNMENT
extern
This is an array of per CPU core information.
