RTEMS 5.2-rc1
Files | Data Structures | Macros | Variables
POSIX Semaphore Private Support
file  psxsemaphore.c
 POSIX Semaphore Information with Zero Objects.
struct  POSIX_Semaphore_Control
#define POSIX_SEMAPHORE_INFORMATION_DEFINE(max)
 Macro to define the objects information for the POSIX Semaphore objects. More...
Objects_Information _POSIX_Semaphore_Information
 The POSIX Semaphore objects information.
This defines the internal implementation support for POSIX semaphores.
◆ POSIX_SEMAPHORE_INFORMATION_DEFINE
#define POSIX_SEMAPHORE_INFORMATION_DEFINE (   max)
Value:
_POSIX_Semaphore, \
OBJECTS_POSIX_API, \
OBJECTS_POSIX_SEMAPHORES, \
max, \
_POSIX_PATH_MAX, \
NULL \
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
#define OBJECTS_INFORMATION_DEFINE(name, api, cls, type, max, nl, ex)
Statically initializes an objects information.
Definition: objectdata.h:427
Definition: semaphore.h:44
This macro should only be used by <rtems/confdefs.h>.
Parameters
maxThe configured object maximum (the OBJECTS_UNLIMITED_OBJECTS flag may be set).
