RTEMS 5.2-rc1
Files | |
| file | signal.h |
| Signals API. | |
| file | signalcatch.c |
| RTEMS Catch Signal. | |
| file | signalsend.c |
| RTEMS Send Signal. | |
| rtems_status_code | rtems_signal_catch (rtems_asr_entry asr_handler, rtems_mode mode_set) |
| RTEMS Catch Signal. More... | |
| rtems_status_code | rtems_signal_send (rtems_id id, rtems_signal_set signal_set) |
| RTEMS Send Signal. More... | |
Directives provided are:
| rtems_status_code rtems_signal_catch | ( | rtems_asr_entry | asr_handler, |
| rtems_mode | mode_set | ||
RTEMS Catch Signal.
This routine implements the rtems_signal_catch directive. This directive is used to establish asr_handler as the Asynchronous Signal Routine (RTEMS_ASR) for the calling task. The asr_handler will execute with a mode of mode_set.
| [in] | asr_handler | is the address of asynchronous signal routine (asr) ( NULL indicates asr is invalid ) |
| [in] | mode_set | is the mode value for asr |
| RTEMS_SUCCESSFUL |
| rtems_status_code rtems_signal_send | ( | rtems_id | id, |
| rtems_signal_set | signal_set | ||
RTEMS Send Signal.
This routine implements the rtems_signal_send directive. This directive sends the signal_set to the task specified by ID.
| [in] | id | is the thread thread id |
| [in] | signal_set | is the signal set |
| RTEMS_SUCCESSFUL | if successful or error code if unsuccessful |
