RTEMS 5.2-rc1
Files | Data Structures | Macros | Functions | Variables
Classic Region Manager Implementation
file  regiondata.h
 Classic Region Manager Data Structures.
file  regionimpl.h
 Classic Region Manager Implementation.
struct  Region_Control
#define REGION_INFORMATION_DEFINE(max)
 Macro to define the objects information for the Classic Region objects. More...
#define REGION_OF_THREAD_QUEUE_QUEUE(queue)    RTEMS_CONTAINER_OF( queue, Region_Control, Wait_queue.Queue )
RTEMS_INLINE_ROUTINE Region_Control_Region_Allocate (void)
 Region_Allocate. More...
RTEMS_INLINE_ROUTINE void _Region_Free (Region_Control *the_region)
 Region_Free. More...
RTEMS_INLINE_ROUTINE Region_Control_Region_Get_and_lock (Objects_Id id)
RTEMS_INLINE_ROUTINE void _Region_Unlock (Region_Control *the_region)
RTEMS_INLINE_ROUTINE void * _Region_Allocate_segment (Region_Control *the_region, uintptr_t size)
 Region_Allocate_segment. More...
RTEMS_INLINE_ROUTINE bool _Region_Free_segment (Region_Control *the_region, void *the_segment)
 Region_Free_segment. More...
void _Region_Process_queue (Region_Control *the_region)
 Process Region Queue. More...
Objects_Information _Region_Information
 The Classic Region objects information.
◆ REGION_INFORMATION_DEFINE
#define REGION_INFORMATION_DEFINE (   max)
Value:
_Region, \
OBJECTS_CLASSIC_API, \
OBJECTS_RTEMS_REGIONS, \
max, \
NULL \
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
#define OBJECTS_NO_STRING_NAME
Constant for the object information string name length to indicate that this object class has no stri...
Definition: objectdata.h:101
#define OBJECTS_INFORMATION_DEFINE(name, api, cls, type, max, nl, ex)
Statically initializes an objects information.
Definition: objectdata.h:427
Definition: regiondata.h:40
This macro should only be used by <rtems/confdefs.h>.
Parameters
maxThe configured object maximum (the OBJECTS_UNLIMITED_OBJECTS flag may be set).
◆ _Region_Allocate()
RTEMS_INLINE_ROUTINE Region_Control * _Region_Allocate ( void  )
Region_Allocate.
This function allocates a region control block from the inactive chain of free region control blocks.
◆ _Region_Allocate_segment()
RTEMS_INLINE_ROUTINE void * _Region_Allocate_segment ( Region_Control the_region,
uintptr_t  size
This function attempts to allocate a segment from the_region. If successful, it returns the address of the allocated segment. Otherwise, it returns NULL.
◆ _Region_Free()
RTEMS_INLINE_ROUTINE void _Region_Free ( Region_Control the_region)
Region_Free.
This routine frees a region control block to the inactive chain of free region control blocks.
◆ _Region_Free_segment()
RTEMS_INLINE_ROUTINE bool _Region_Free_segment ( Region_Control the_region,
void *  the_segment
This function frees the_segment to the_region.
◆ _Region_Process_queue()
void _Region_Process_queue ( Region_Control the_region)
This is a helper routine which is invoked any time memory is freed. It looks at the set of waiting tasks and attempts to satisfy all outstanding requests.
Parameters
[in]the_regionis the the region
