RTEMS 5.2-rc1
Files | Functions
Workspace
file  support.h
file  workspace.c
 RTEMS Workspace Support.
bool rtems_workspace_get_information (Heap_Information_block *the_info)
 Gets Workspace Information. More...
bool rtems_workspace_allocate (size_t bytes, void **pointer)
 Allocates Memory from the Workspace. More...
bool rtems_workspace_free (void *pointer)
 Frees Memory Allocated from the Workspace. More...
void * rtems_workspace_greedy_allocate (const uintptr_t *block_sizes, size_t block_count)
 Greedy allocate that empties the workspace. More...
void * rtems_workspace_greedy_allocate_all_except_largest (uintptr_t *allocatable_size)
 Greedy allocate all blocks except the largest free block. More...
void rtems_workspace_greedy_free (void *opaque)
 Frees space of a greedy allocation. More...
Workspace definitions.
◆ rtems_workspace_allocate()
bool rtems_workspace_allocate ( size_t  bytes,
void **  pointer
A number of bytes bytes will be allocated from the RTEMS Executive Workspace and returned in pointer.
Returns true if successful, and false otherwise.
◆ rtems_workspace_free()
bool rtems_workspace_free ( void *  pointer)
This frees the memory indicated by pointer that was allocated from the RTEMS Executive Workspace.
◆ rtems_workspace_get_information()
bool rtems_workspace_get_information ( Heap_Information_block the_info)
Returns information about the heap that is used as the RTEMS Executive Workspace in the_info.
◆ rtems_workspace_greedy_allocate()
void * rtems_workspace_greedy_allocate ( const uintptr_t *  block_sizes,
size_t  block_count
Afterwards the heap has at most block_count allocatable blocks of sizes specified by block_sizes. The block_sizes must point to an array with block_count members. All other blocks are used.
See also
rtems_workspace_greedy_free().
◆ rtems_workspace_greedy_allocate_all_except_largest()
void * rtems_workspace_greedy_allocate_all_except_largest ( uintptr_t *  allocatable_size)
Afterwards the heap has at most one allocatable block. This block is the largest free block if it exists. The allocatable size of this block is stored in allocatable_size. All other blocks are used.
See also
◆ rtems_workspace_greedy_free()
void rtems_workspace_greedy_free ( void *  opaque)
The opaque argument must be the return value of rtems_workspace_greedy_allocate() or rtems_workspace_greedy_allocate_all_except_largest().
