RTEMS 5.2-rc1
Files | Data Structures | Typedefs | Functions
Fatal
The Fatal Manager provides functions for fatal system states and or irrecoverable errors. More...
file  fatal.c
 Invokes the internal error handler with a source of INTERNAL_ERROR_RTEMS_API and is internal set to false.
file  fatalsrctext.c
 Implementation of rtems_fatal_source_text()
file  interrtext.c
 Returns a text for an internal error code.
struct  rtems_assert_context
 Assert context. More...
typedef CPU_Exception_frame rtems_exception_frame
 Exception frame.
void rtems_fatal_error_occurred (uint32_t the_error) RTEMS_NO_RETURN
 Invokes the internal error handler with a source of INTERNAL_ERROR_RTEMS_API and is internal set to false. More...
RTEMS_NO_RETURN RTEMS_INLINE_ROUTINE void rtems_fatal (rtems_fatal_source fatal_source, rtems_fatal_code error_code)
 Terminates the system. More...
RTEMS_NO_RETURN void rtems_panic (const char *fmt,...) RTEMS_PRINTFLIKE(1
 Prints the specified message via printk() and terminates the system. More...
RTEMS_NO_RETURN void const char * rtems_fatal_source_text (rtems_fatal_source source)
 Returns a text for a fatal source. More...
const char * rtems_internal_error_text (rtems_fatal_code error)
 Returns a text for an internal error code. More...
◆ rtems_fatal()
RTEMS_NO_RETURN RTEMS_INLINE_ROUTINE void rtems_fatal ( rtems_fatal_source  fatal_source,
Parameters
[in]fatal_sourceThe fatal source.
[in]error_codeThe error code.
See also
_Terminate().
◆ rtems_fatal_error_occurred()
void rtems_fatal_error_occurred ( uint32_t  the_error)
Parameters
[in]the_erroris a 32-bit fatal error code.
See also
_Terminate().
◆ rtems_fatal_source_text()
RTEMS_NO_RETURN void const char * rtems_fatal_source_text ( rtems_fatal_source  source)
The text for each fatal source is the enumerator constant.
Parameters
[in]sourceis the fatal source.
Return values
textThe fatal source text.
?The passed fatal source is invalid.
◆ rtems_internal_error_text()
const char * rtems_internal_error_text ( rtems_fatal_code  error)
The text for each internal error code is the enumerator constant.
Parameters
[in]erroris the error code.
Return values
textThe error code text.
?The passed error code is invalid.
◆ rtems_panic()
RTEMS_NO_RETURN void rtems_panic ( const char *  fmt,
Parameters
[in]fmtThe message format.
[in]...The message parameters.
See also
_Terminate().
