RTEMS 5.2-rc1
Files | Data Structures | Macros | Functions
Object Class Information
file  object.h
file  rtemsbuildid.c
 Build Object Id.
file  rtemsbuildname.c
 Build Thirty-Two Bit Object Name.
file  rtemsobjectapimaximumclass.c
 Get Highest Valid Class Value.
file  rtemsobjectapiminimumclass.c
 Get Lowest Valid Class Value.
file  rtemsobjectgetapiclassname.c
 Get Class Name.
file  rtemsobjectgetapiname.c
 Get API Name.
file  rtemsobjectgetclassicname.c
 Obtain Name of Object.
file  rtemsobjectgetclassinfo.c
 Get Class Information.
file  rtemsobjectgetname.c
 Obtain Object Name as String.
file  rtemsobjectidapimaximum.c
 Get Highest Valid API Index.
file  rtemsobjectidapiminimum.c
 Get Lowest Valid API Index.
file  rtemsobjectidgetapi.c
 Get API Portion of Object Id.
file  rtemsobjectidgetclass.c
 Get Class Portion of Object Id.
file  rtemsobjectidgetindex.c
 Get Index Portion of Object Id.
file  rtemsobjectidgetnode.c
 Get Node Portion of Object Id.
file  rtemsobjectsetname.c
 Set Name of Object.
struct  rtems_object_api_class_information
#define rtems_build_id(_api, _class, _node, _index)    _Objects_Build_id( _api, _class, _node, _index )
 Build Object Id. More...
#define rtems_build_name(_C1, _C2, _C3, _C4)    _Objects_Build_name( _C1, _C2, _C3, _C4 )
 Build Thirty-Two Bit Object Name. More...
#define rtems_object_id_get_api(_id)    _Objects_Get_API( _id )
 Get API Portion of Object Id. More...
#define rtems_object_id_get_class(_id)    _Objects_Get_class( _id )
 Get Class Portion of Object Id. More...
#define rtems_object_id_get_node(_id)    _Objects_Get_node( _id )
 Get Node Portion of Object Id. More...
#define rtems_object_id_get_index(_id)    _Objects_Get_index( _id )
 Get Index Portion of Object Id. More...
#define rtems_object_id_api_minimum()    OBJECTS_INTERNAL_API
 Get Lowest Valid API Index. More...
#define rtems_object_id_api_maximum()    OBJECTS_APIS_LAST
 Get Highest Valid API Index. More...
rtems_status_code rtems_object_get_classic_name (rtems_id id, rtems_name *name)
 Obtain Name of Object. More...
char * rtems_object_get_name (rtems_id id, size_t length, char *name)
 Obtain Object Name as String. More...
rtems_status_code rtems_object_set_name (rtems_id id, const char *name)
 Set Name of Object. More...
int rtems_object_api_minimum_class (int api)
 Get Lowest Valid Class Value. More...
int rtems_object_api_maximum_class (int api)
 Get Highest Valid Class Value. More...
int rtems_object_id_api_maximum_class (int api)
const char * rtems_object_get_api_name (int api)
 Get API Name. More...
const char * rtems_object_get_api_class_name (int the_api, int the_class)
 Get Class Name. More...
rtems_status_code rtems_object_get_class_information (int the_api, int the_class, rtems_object_api_class_information *info)
 Get Class Information. More...
RTEMS_INLINE_ROUTINE uint16_t rtems_object_get_local_node (void)
 Get the local MPCI node number. More...
This encapsulates functionality related to the Classic API Object Class Services.
◆ rtems_build_id
#define rtems_build_id (   _api,
  _class,
  _node,
  _index
Build Object Id.
This function returns an object id composed of the specified api, class, node, and index.
Parameters
[in]_apiindicates the api to use for the Id
[in]_classindicates the class to use for the Id
[in]_nodeindicates the node to use for the Id
[in]_indexindicates the index to use for the Id
Return values
Thismethod returns an object Id built from the specified values.
Note
A body is also provided.
◆ rtems_build_name
#define rtems_build_name (   _C1,
  _C2,
  _C3,
  _C4
RTEMS Object Helper – Build an Object Id
This function returns an object name composed of the four characters C1, C2, C3, and C4.
Parameters
[in]_C1is the first character of the name
[in]_C2is the second character of the name
[in]_C3is the third character of the name
[in]_C4is the fourth character of the name
Note
This must be implemented as a macro for use in Configuration Tables. A body is also provided.
◆ rtems_object_id_api_maximum
int rtems_object_id_api_maximum (   void)     OBJECTS_APIS_LAST
This method returns the highest valid value for the API portion of an RTEMS object Id.
Return values
Thismethod returns the greatest valid value for the API portion of an RTEMS object Id.
Note
◆ rtems_object_id_api_minimum
int rtems_object_id_api_minimum (   void)     OBJECTS_INTERNAL_API
This method returns the lowest valid value for the API portion of an RTEMS object Id.
Return values
Thismethod returns the least valid value for the API portion of an RTEMS object Id.
Note
◆ rtems_object_id_get_api
#define rtems_object_id_get_api (   _id)     _Objects_Get_API( _id )
RTEMS Object Helper – Extract API From Id
This function returns the API portion of the Id.
Parameters
[in]_idis the Id of the object to obtain the API from
Return values
Thismethod returns the API portion of the provided _id.
Note
This method does NOT validate the _id provided.
◆ rtems_object_id_get_class
#define rtems_object_id_get_class (   _id)     _Objects_Get_class( _id )
This function returns the class portion of the _id ID.
Parameters
[in]_idis the Id of the object to obtain the class from
Return values
Thismethod returns the class portion of the provided _id.
Note
◆ rtems_object_id_get_index
#define rtems_object_id_get_index (   _id)     _Objects_Get_index( _id )
This function returns the index portion of the ID.
Parameters
[in]_idis the Id of the object to obtain the index from
Return values
Thismethod returns the index portion of the provided _id.
Note
◆ rtems_object_id_get_node
#define rtems_object_id_get_node (   _id)     _Objects_Get_node( _id )
This function returns the node portion of the ID.
Parameters
[in]_idis the Id of the object to obtain the node from
Return values
Thismethod returns the node portion of the provided _id.
Note
◆ rtems_object_api_maximum_class()
int rtems_object_api_maximum_class ( int  api)
This method returns the highest valid value Class for the specified api. Each API supports a different number of object classes.
Parameters
[in]apiis the API to obtain the maximum class of
Return values
Thismethod returns the greatet valid value for class number for the specified api.
◆ rtems_object_api_minimum_class()
int rtems_object_api_minimum_class ( int  api)
This method returns the lowest valid value Class for the specified api. Each API supports a different number of object classes.
Parameters
[in]apiis the API to obtain the minimum class of
Return values
Thismethod returns the least valid value for class number for the specified api. RTEMS Object Helper – Get Least Valid Class for an API
◆ rtems_object_get_api_class_name()
const char * rtems_object_get_api_class_name ( int  the_api,
int  the_class
Get Class Name.
This method returns a string containing the name of the class from the specified api.
Parameters
[in]the_apiis the API for the class
[in]the_classis the class to obtain the name of
Return values
Ifsuccessful, this method returns the name of the specified class. Otherwise, it returns the string "BAD CLASS"
◆ rtems_object_get_api_name()
const char * rtems_object_get_api_name ( int  api)
Get API Name.
This method returns a string containing the name of the specified api.
Parameters
[in]apiis the API to obtain the name of
Return values
Ifsuccessful, this method returns the name of the specified api. Otherwise, it returns the string "BAD API"
◆ rtems_object_get_class_information()
rtems_status_code rtems_object_get_class_information ( int  the_api,
int  the_class,
rtems_object_api_class_information info
This method returns a string containing the name of the the_class from the specified api.
Parameters
[in]the_classis the class to obtain information about
[in]infopoints to the information structure to fill in
Return values
Ifsuccessful, this method returns the name of RTEMS_SUCCESSFUL with *info filled in. Otherwise, a status is returned to indicate the error.
◆ rtems_object_get_classic_name()
rtems_status_code rtems_object_get_classic_name ( rtems_id  id,
rtems_name name
This directive returns the name associated with the specified object ID.
Parameters
[in]idis the Id of the object to obtain the name of.
[out]namewill be set to the name of the object
Note
The object must be have a name of the 32-bit form.
Return values
a *name will contain user defined object name
Return values
a RTEMS_SUCCESSFUL - if successful
Return values
errorcode - if unsuccessful
◆ rtems_object_get_local_node()
RTEMS_INLINE_ROUTINE uint16_t rtems_object_get_local_node ( void  )
Returns
The local MPCI node number.
◆ rtems_object_get_name()
char * rtems_object_get_name ( rtems_id  id,
size_t  length,
char *  name
Parameters
[in]lengthis the length of the output name buffer
Return values
Return values
a name - if successful
Return values
a NULL - if unsuccessful
◆ rtems_object_id_api_maximum_class()
int rtems_object_id_api_maximum_class ( int  api)
Parameters
Return values
◆ rtems_object_set_name()
rtems_status_code rtems_object_set_name ( rtems_id  id,
const char *  name
Set Name of Object.
This method allows the caller to set the name of an object. This can be used to set the name of objects which do not have a naming scheme per their API.
RTEMS Object Helper – Set Name of Object as String
Parameters
Return values
Return values
Return values
