RTEMS 5.2-rc1
Macros | Functions
#define ALT_I2C_RX_FIFO_NUM_ENTRIES   64
ALT_STATUS_CODE alt_i2c_rx_fifo_is_empty (ALT_I2C_DEV_t *i2c_dev)
ALT_STATUS_CODE alt_i2c_rx_fifo_is_full (ALT_I2C_DEV_t *i2c_dev)
ALT_STATUS_CODE alt_i2c_rx_fifo_level_get (ALT_I2C_DEV_t *i2c_dev, uint32_t *num_entries)
ALT_STATUS_CODE alt_i2c_rx_fifo_threshold_get (ALT_I2C_DEV_t *i2c_dev, uint8_t *threshold)
ALT_STATUS_CODE alt_i2c_rx_fifo_threshold_set (ALT_I2C_DEV_t *i2c_dev, const uint8_t threshold)
The receive FIFO has a configurable threshold value that controls the level of entries (or above) that sets the RX_FULL status condition and triggers an interrupt. The valid range is 0 - (ALT_I2C_RX_FIFO_NUM_ENTRIES-1), with the additional restriction that I2C controller does not allow this value to be set to a value larger than the depth of the buffer. If an attempt is made to do that, the actual value set will be the maximum depth of the buffer. A value of 0 sets the threshold for 1 entry, and a value of (ALT_I2C_RX_FIFO_NUM_ENTRIES-1) sets the threshold for ALT_I2C_RX_FIFO_NUM_ENTRIES entries.
◆ ALT_I2C_RX_FIFO_NUM_ENTRIES
The number of entries (depth) of the I2C controller receive FIFO.
◆ alt_i2c_rx_fifo_is_empty()
ALT_STATUS_CODE alt_i2c_rx_fifo_is_empty ( ALT_I2C_DEV_t i2c_dev)
Returns ALT_E_TRUE when the receive FIFO is empty.
Parameters
i2c_devA pointer to the I2C controller device block instance.
Return values
ALT_E_SUCCESSSuccessful status.
ALT_E_ERRORDetails about error status code
◆ alt_i2c_rx_fifo_is_full()
ALT_STATUS_CODE alt_i2c_rx_fifo_is_full ( ALT_I2C_DEV_t i2c_dev)
Returns ALT_E_TRUE when the receive FIFO is completely full.
Parameters
Return values
◆ alt_i2c_rx_fifo_level_get()
ALT_STATUS_CODE alt_i2c_rx_fifo_level_get ( ALT_I2C_DEV_t i2c_dev,
uint32_t *  num_entries
Returns the number of valid entries in the receive FIFO.
Parameters
num_entries[out] The number of entries in the receive FIFO.
Return values
◆ alt_i2c_rx_fifo_threshold_get()
ALT_STATUS_CODE alt_i2c_rx_fifo_threshold_get ( ALT_I2C_DEV_t i2c_dev,
uint8_t *  threshold
Gets the current receive FIFO threshold level value.
Parameters
threshold[out] The current threshold value.
Return values
◆ alt_i2c_rx_fifo_threshold_set()
ALT_STATUS_CODE alt_i2c_rx_fifo_threshold_set ( ALT_I2C_DEV_t i2c_dev,
Sets the current receive FIFO threshold level value.
Parameters
thresholdThe threshold value.
Return values
