RTEMS 5.2-rc1
gr_rasta_io.h
1/* GR-RASTA-IO PCI Target driver.
2 *
3 * COPYRIGHT (c) 2008.
4 * Cobham Gaisler AB.
5 *
6 * Configures the GR-RASTA-IO interface PCI board.
7 * This driver provides a AMBA PnP bus by using the general part
8 * of the AMBA PnP bus driver (ambapp_bus.c).
9 *
10 * Driver resources for the AMBA PnP bus provided can be set using
11 * gr_rasta_io_set_resources().
12 *
13 * The license and distribution terms for this file may be
14 * found in found in the file LICENSE in this distribution or at
15 * http://www.rtems.org/license/LICENSE.
16 */
17
18#ifndef __GR_RASTA_IO_H__
19#define __GR_RASTA_IO_H__
20
21#include <drvmgr/drvmgr.h>
22
23#ifdef __cplusplus
24extern "C" {
25#endif
26
27/* An array of pointers to GR-RASTA-IO resources. The resources will be
28 * used by the drivers controlling the cores on the GR-RASTA-IO target AMBA bus.
29 *
30 * The gr_rasta_io_resources is declared weak so that the user can override the
31 * default configuration. The array must be terminated with a NULL resource.
32 */
33extern struct drvmgr_bus_res *gr_rasta_io_resources[];
34
35/* Options to gr_rasta_io_print function */
36#define RASTA_IO_OPTIONS_AMBA 0x01 /* Print AMBA bus devices */
37#define RASTA_IO_OPTIONS_IRQ 0x02 /* Print current IRQ setup */
38
39/* Print information about GR-RASTA-IO PCI boards */
40void gr_rasta_io_print(int options);
41
42/* Print information about a GR-RASTA-IO PCI board */
43void gr_rasta_io_print_dev(struct drvmgr_dev *dev, int options);
44
45/* Register GR-RASTA-IO driver */
46void gr_rasta_io_register_drv(void);
47
48#ifdef __cplusplus
49}
50#endif
51
52#endif
Definition: drvmgr.h:214
Definition: drvmgr.h:273
