RTEMS 5.2-rc1
#include <stdint.h>Go to the source code of this file.
| #define | GPNVBit_SecurityBit 0 |
| #define | GPNVBit_BootMode 1 |
| #define | GPNVBit_TCMBit1 6 |
| #define | GPNVBit_TCMBit2 7 |
| #define | FLASHD_IsSecurityBitSet() FLASHD_IsGPNVMSet(0) |
| #define | FLASHD_SetSecurityBit() FLASHD_SetGPNVM(0) |
| void | FLASHD_Initialize (uint32_t dwMCk, uint32_t dwUseIAP) |
| Initializes the flash driver. More... | |
| uint32_t | FLASHD_Erase (uint32_t dwAddress) |
| Erases the entire flash. More... | |
| uint32_t | FLASHD_EraseSector (uint32_t dwAddress) |
| Erases flash by sector. More... | |
| uint32_t | FLASHD_ErasePages (uint32_t dwAddress, uint32_t dwPageNum) |
| Erases flash by pages. More... | |
| uint32_t | FLASHD_Write (uint32_t dwAddress, const void *pvBuffer, uint32_t dwSize) |
| Writes a data buffer in the internal flash. More... | |
| uint32_t | FLASHD_Lock (uint32_t dwStart, uint32_t dwEnd, uint32_t *pdwActualStart, uint32_t *pdwActualEnd) |
| Locks all the regions in the given address range. The actual lock range is reported through two output parameters. More... | |
| uint32_t | FLASHD_Unlock (uint32_t dwStart, uint32_t dwEnd, uint32_t *pdwActualStart, uint32_t *pdwActualEnd) |
| Unlocks all the regions in the given address range. The actual unlock range is reported through two output parameters. More... | |
| uint32_t | FLASHD_IsLocked (uint32_t dwStart, uint32_t dwEnd) |
| Returns the number of locked regions inside the given address range. More... | |
| uint32_t | FLASHD_SetGPNVM (uint8_t gpnvm) |
| Sets the selected GPNVM bit. More... | |
| uint32_t | FLASHD_ClearGPNVM (uint8_t gpnvm) |
| Clears the selected GPNVM bit. More... | |
| uint32_t | FLASHD_IsGPNVMSet (uint8_t gpnvm) |
| Check if the given GPNVM bit is set or not. More... | |
| uint32_t | FLASHD_ReadUniqueID (uint32_t *pdwUniqueID) |
The flash driver provides the unified interface for flash program operations.
| uint32_t FLASHD_ClearGPNVM | ( | uint8_t | ucGPNVM | ) |
| gpnvm | GPNVM bit index. |
| uint32_t FLASHD_Erase | ( | uint32_t | dwAddress | ) |
| dwAddress | Flash start address. |
| uint32_t FLASHD_ErasePages | ( | uint32_t | dwAddress, |
| uint32_t | dwPageNum | ||
| dwAddress | Start address of be erased pages. |
| dwPageNum | Number of pages to be erased with EPA command (4, 8, 16, 32) |
| uint32_t FLASHD_EraseSector | ( | uint32_t | dwAddress | ) |
| dwAddress | Start address of be erased sector. |
| void FLASHD_Initialize | ( | uint32_t | dwMCk, |
| uint32_t | dwUseIAP | ||
| dwMCk | Master clock frequency in Hz. |
| dwUseIAP | 0: use EEFC controller interface, 1: use IAP interface. dwUseIAP should be set to 1 when running out of flash. |
| uint32_t FLASHD_IsGPNVMSet | ( | uint8_t | ucGPNVM | ) |
| uint32_t FLASHD_IsLocked | ( | uint32_t | start, |
| uint32_t | end | ||
| start | Start address of range |
| end | End address of range. |
| uint32_t FLASHD_Lock | ( | uint32_t | start, |
| uint32_t | end, | ||
| uint32_t * | pActualStart, | ||
| uint32_t * | pActualEnd | ||
| start | Start address of lock range. |
| end | End address of lock range. |
| pActualStart | Start address of the actual lock range (optional). |
| pActualEnd | End address of the actual lock range (optional). |
| uint32_t FLASHD_SetGPNVM | ( | uint8_t | ucGPNVM | ) |
| uint32_t FLASHD_Unlock | ( | uint32_t | start, |
| start | Start address of unlock range. |
| end | End address of unlock range. |
| pActualStart | Start address of the actual unlock range (optional). |
| pActualEnd | End address of the actual unlock range (optional). |
| uint32_t FLASHD_Write | ( | uint32_t | dwAddress, |
| const void * | pvBuffer, | ||
| uint32_t | dwSize | ||
| address | Write address. |
| pBuffer | Data buffer. |
| size | Size of data buffer in bytes. |
